Question about Creative Labs Zen Micro MP3 Player
NEED FIRMWARE CREATIVE LABS NO DAP--MD00004 OR SOMETHING TO HELP IT WORK, IT'S STUCK
5 Related Answers
Anonymous
SOURCE: firmware problem
i have a muvo2 fm and reloaded the firmware off the creative website..
Posted on May 27, 2007
Benimur
Louie Role
  • 6966 Answers
SOURCE: Creative Nomad Jukebox zen xtra says Firmware problem
Hi and welcome to FixYa,
It would appear that the fix requires a Windows machine. Solution then would be two fold:
  • download the firmware update/fix even meant for Windows;
  • install and run Windows inside your Mac.
The last could be achieved by:
Of course the easiest is to use a Windows based computer of a friend.
Your Creative Zen Nomad Xtra mp3 player uses a memory system similar to a flash/thumb drive much like the hard disk of any computer. Just as a computer on certain instances freezes/hangs, the same would happen to your MP3. Like again the computer, the OS would need to be re-installed. In your MP3 the OS is the firmware which has to be reloaded/updated.
Good luck and thank you for using FixYa.
Posted on Feb 14, 2009
Anonymous
SOURCE: firmware update went wrong
What operating system are you using? The Zen Touch firmware update will fail in Vista or 7 -- you need to run the update from an XP install. Once you successfully get the 2.11 firmware on the Touch, it will then interface with those later OS's without difficulty. Also, what version of Windows Media Player are you running? Believe it or not, this makes a BIG difference. The latest Media Player 11 will cause the firmware flash to fail, as will WMP <= 9. I have three separate players that have experienced this problem, including one that had been disassembled THREE YEARS AGO after a failed flash, and was able to resurrect all utilizing this method:
(1) Uninstall everything Creative: the driver, Jukebox, etc. Delete the Creative folder from Program Files. (Some amendment to these instructions may be in order if you have a Creative sound card -- I have built-in Realtek sound so it didn't apply in my case). A restart may or may not be required: go ahead and do so to be safe.
(2) Plug the device in after restart. Windows will want to find drivers for it -- cancel that process. Open the Device Manager. The Touch should come up with an exclamation point next to it (since the drivers were not uninstalled): right-click and select "Uninstall." I have seen instructions on the Web to also uninstall all USB root hubs, but I have found that unnecessary and a pain if you have a USB keyboard and/or mouse. Unplug the device. Restart.
(2) If you are running a version of Windows Media Player not equal to 10, either install 10 (if you have 9 or below) or roll back from 11 if you have that. Restart.
(3) Plug the device back in. My supposition is that this is particular to WMP 10, hence the problems with other versions. The device should pop up as "Creative Zen Touch:" if Windows asks to find drivers, cancel that process, and the device should now come up as an "MTP device."
(4) Since the firmware flash failed, the Zen is probably in recovery mode. Launch the firmware updater software on the computer, and stay at the language selection screen. Choose option 3, "reload firmware," from the recovery menu. It will inform you that it is "deleting old firmware" and then will give you a short period of time with a dialog saying "start firmware update" on the Zen screen. During this time period (about 2 secs), press the language selection of your choice on the computer in order to start the update. It should go through successfully this time.
Posted on Jun 10, 2009
Anonymous
  • 803 Answers
SOURCE: Creative Labs Model Dap Md0004 firmware
http://www.filebuzz.com/findsoftware/Creative_Labs_Inc_Dap_Md0004_Drivers/1.html
Here you go.
Posted on Sep 29, 2009
muntejaya
Muntejaya Ginting
  • 10422 Answers
SOURCE: driver
Hi, you can get it here : www.nodevice.com/driver/.../Creative-Labs/MP3_Player.html
www.creative.com/language.asp?sDestUrl=/support/
Regards
Posted on Feb 15, 2011
Creative dap md0004
support.creative.com/Products/ProductDetails.aspx?catID..
Aug 26, 2014 | Creative Labs Zen Micro MP3 Player
I have a Creative Zen Micro Model DAP-MD00004 MP3 player, just got a new computer with Window 7 on it, tried to install software from CD and nothing happens. Program starts but does not install. Please let...
You have to down load new software from Creative in order for the Zen to work in W7 as most of the existing software on CDs only work with WXP. Unless you bought your Zen in the last year, the software needs updating to play on W7. You need to get a better description of your Zen and search the following site. http://support.creative.com/Products/product_list.aspx?catID=948&CatName=Entertainment+Devices+%2f+MP3+Players#
Mar 20, 2011 | Creative Labs Zen Micro MP3 Player
How do i get a firmware of creative DAP-MD0004
goto creativelabs.com and under the support section there should be some options for downloads and firmware for your mp3 player go there and find your model and the flashing utility and there you go :)
Oct 19, 2009 | Creative Labs Zen Touch MP3 Player
Installer for creative micro zen dap-md0004
My Micro Zen is having problem with the firmware does anyone know how to solve it.
Oct 26, 2008 | Creative Labs Zen Micro MP3 Player
Creative Labs Zen Micro MP3 Player Logo
77 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
ThaMp3Doctor
ThaMp3Doctor
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
