Question about Cell Phones
Nokia manual where is the log off button?
Roch Tremblay
    New Friend:
Je voudrais savoir s'il y a un guide pour l'utilisation de mon Nokia 635, guide en fran?ais.
Merci
Roch
Posted on Mar 04, 2015
Hello how do i display the list of received calls for my N70..ie which button shows it??
just go to log (call log) in that go to options select settings you'll find log duration change it for 30days
Regards,
Roger
// Feel free to vote this answer with 4 thumbs up //
N70 phone manual: http://nds1.nokia.com/phones/files/guides/Nokia_N70_1_UG_en.pdf
Sep 02, 2011 | Nokia N70 Cellular Phone
My Nokia C3-01 keeps freezing, can't log in to get
This solution should help fix the issue. I advise you use the Nokia PC Suite to backup your phone data prior to doing this reset. Also, you should download and install Nokia Software Updater and use this to update your phones firmware and software in the future.
  1. Enter *#7370# code from the keypad. and press the Dial button.
  2. Type unlock code 12345 press continue.
  3. Restart your phone.
  4. You should check for updates on the phone at this time Enter *#0000# from the keypad and press the dial button
  5. Select "Options" and then select "Check for updates".
Remember to backup your phone before performing these functions.
May 15, 2011 | Nokia Cell Phones
How can i delete one single entry from my nokia e72 log
Download from Nokia Ovi Store the tiny tool "Delete Single Log", this is what you want. It can delete individual call log / sms log entry.
Mar 15, 2011 | Nokia E72 Smartphone
I cant delete my call log history on my nokia x3
This option restores the original operating system from the ROM.
Formats the C: partition and deletes all data including the memory
card. Key Code *#7370# (click this combination of keys on the keyboard
in the mobile)
You can also achieve Total Reset by pressing and holding down following keys:
* + 3 + Green Button (call) immediately after turning the mobile on.
Important: To proceed to reset, the battery must be full and the
mobile device connected to the charger. If during the course of reset,
the mobile stop receiving electricity it can ruin the internal flash
memory of the mobile device and stop function.
If this does not work then contact your carrier.
Mar 05, 2011 | Nokia X3 Cell Phone
How do I access the unreadable communication log for all calls and SMS on my nokia n95 please?
all you have to do is to go to menu, then look for log(as in call logs) but it is written as log and after you find this select it. it will show some items like recent calls etc which can be read but to get what you need, just press the right button of the d-pad button and you would see a log of both recent calls, sms, mms, and data services for the past 30 days. hope this was helpful?
please rate
Nov 30, 2010 | Nokia N95 Cellular Phone
Hi i m ashish... i hve nokia 5800XM... my phone's some shortcut keys are not working properly...like shortcut menu bar....diller, contact key...call log by green button ..plz help me....
Hi Ashish
I am having a similar problem with my phone currently, it is a firmware issue that can be solved by doing a factory reset on the phone, however i am not doing it for now, because a new Firmware from Nokia has come for 5800 which is v40.0.005 and it is not yet out for the Indian phones so i am waiting to upgrade to this version.
Meanwhile to access the call log you can try this option, change the home screen theme to contacts bar from settings and then when you press the phonebook shortcut key or dialler shortcut key it would work
After you press the dialler shortcut key and you see the dialler on the phone screen press the green button it would show the call log.
Feb 04, 2010 | Nokia 5800 XpressMusic Smartphone
Nokia N95 wont display Log
Resetting to factory settings will probably sort it out. But you might loose the data stored on the phone. You'll find the reset in the menu, tools, settings.
I'm assuming that you switch your phone off sometimes, if you don't, try a restart first.
Feb 11, 2008 | Nokia N95 Cellular Phone
Nokia 6288 stop working
software problem,you need to update it,i get many of these every day
Sep 02, 2007 | Nokia 6288 Cellular Phone
Cell Phones Logo
520 people viewed this question
Top Cell Phones Experts
Muntejaya Ginting
Muntejaya Ginting
Ekse
Marvin
Marvin
Are you a Cell Phone Expert? Answer questions, earn points and help others
