Black & Decker 50 Watt Electromate with Radio and Lantern #PS50LRB Logo
A
Anonymous Posted on Jan 04, 2014
How to change light bulb in trail tracker sports radio
Where can I get a replacement battery for the trail tracker, emergency radio lantern, yellow?
Trail Tracker Sport Lantern/Weather Radio doesn't charge using the hand crank dynamo for my Power on Board Trail Tracker lantern/radio, You most likely need a new battery, you can purchase one from Black...
More information please open this link:-- Best Manuals
How do you change brake light bulb on 96 geo tracker
Remove 2 phillip head screws at bottom of taillight.Gently pull outwards on each bottom corner as light comes out drop downward so tabs at top of light can clear . Now you can access light bulbs.Install in reverse order
All interior lights, alarm and radio are not working
Maybe the burned bulb is shorting out to ground?
1helpful
How to change license plate bulb in chevy tracker ?
The light socket goes in from the back it's rubber and only truns a quarter of a turn and pull out. the bulb is a 194 and most all dept stores and auto parts stores will have them they are a very common bulb. a 168 will also fit.
2answers
Where can I get a replacement battery for the trail tracker Sport lantern?
You can get a replacement at your local Interstate battery store. I purchased one for $30
2helpful
How to replace headlight on a 2003 Chevy Tracker
There are two black plastic clips behind the the air filter, remove them and release the whole assembly to access the lights.
If you still get in troubles, have it replaced at a petrol station, they will help you in fitting the bulb, and it won't be expensive.
Here follows
2003 Chevrolet Tracker Light Bulb Size Chart
Low Beam Headlight Bulb Size: 9003/HB2
High Beam Headlamp Light Bulb Size: 9003/HB2
Parking Light Bulb Size: 1157A
Front Turn Signal Light Bulb Size: 1157A
Rear Turn Signal Light Bulb Size: 921
Tail Light Bulb Size: 7443
Stop Light Bulb Size: 7443
High Mount Stop Light Bulb Size: 168 Or 921
License Plate Light Bulb Size: 168
Back Up Light Bulb Size: 921
Front Sidemarker Light Bulb Size: 194
Ash Tray Light Bulb Size: 74
Step/Courtesy Light Bulb Size: 168
Trunk/Cargo Area Light Bulb Size: 168
Instrument-General Light Bulb Size: 158 or 74
Check Engine Indicator Light Bulb Size: 74
Hi-Beam Indicator Light Bulb Size: 74
Seat Belt Indicator Light Bulb Size: 74
Brake Warning Light Bulb Size: 74
Automatic Transmission Indicator Light Bulb Size: 74
Directional Signal Indicator Light Bulb Size: 74
5helpful
Changing license plate lamps on the tracker
There's no need to take the whole back panel off to do it, the light cover on the bulb twists out, and it might take some elbow grease to twist it, then the bulb is easy to change.
Good luck,
Eitan.
Top Black & Decker Camping, Backpacking & Hiking Experts
ADMIN Andrew
ADMIN Andrew
Kardoc
Are you a Black & Decker Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
