LG WM2016CW Front Load Washer Logo
A
Anonymous Posted on Jan 04, 2014
Loud noise is heared when the washer drains
When the washer drains a loud intermittent sound is heard....sounds like it is trying to drain but makes a sound like it is bound up
5 Related Answers
Anonymous
  • 1543 Answers
  • Posted on Nov 16, 2008
SOURCE: LG WM-2277HB washer does not drain and make rattling noise.
You will need to replace the drain pump motor. The pump impeller has separated from the motor shaft. You can push it back on, but it will just come off again. I have not tried adding adhesive because I didn't want a call back. That may work if you want to try it. To replace pump motor:
Take the rectangular recess out by using a putty knife on the left or right side, Remove phillips screws mounting pump. Pull machine forward about two feet to allow you to tilt the machine back to lean it against the wall. Reach under to access the pump. It is held in place by a plastic tab you can depress to remove, but if you break the tab, don't worry, as the mounting screws will hold your pump in place just fine when reinstalled. Remove pump by disconnecting hoses and electrical plug. Change out pump motor (three phillips head screws)
Anonymous
  • 10865 Answers
  • Posted on Mar 08, 2010
SOURCE: Need to buy drain pump for LG washer WM1812CW but
Hello. you can order the LG parts from any home depot.
nomess
  • 343 Answers
  • Posted on Apr 18, 2010
SOURCE: During the spin cycle the washer makes a loud
If the 'loud noise' water sloshing you should first check that the pump filter isn't blocked. This sometimes stops the pump altogether. Coins, etc..If the noise is metallic it could mean bearings...Check the pump via the small door at floor level...Mind the water inside the machine. You may be able to drain first with a small hose which is inside the pump access door.....Nomess
Anonymous
  • 43501 Answers
  • Posted on May 17, 2010
SOURCE: my LG washer wm2277hw does not drain water and
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing Machine not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Anonymous
  • Posted on Aug 03, 2010
SOURCE: lg-wm1832cw front loader washer won't spin and drain
did anyone solve this problem? Mine is doing the same thing... uggh!
Washer is a Samsung WWF337AAW-XAC. Just prior to the spin cycle we hear a rattling or grating noise and then it rattles throughout the spin cycle. It will sometimes rattle at the end of the rinse cycle but...
hi Rick.
Reasons a washer will make noise during spin mode:
1. Main tub bearing faulty
2. Main drive pulley
3. Motor coupling worn
4. Bad clutch
5. Worn out drive belt
6. Clogged or damaged drain pump
7. Transmission is worn out
8. Shock absorber (front loader washers)
9. Springs or dampening straps (top load washers)
10. Agitator directional cogs aka "agitator dogs" (top load washers
When the washer spins, it rides on a bearing that allows the tub to move freely with zero resistance. If this bearing is worn out, a loud noise will be heard when the washer spins. A good way to tell if your washer problem is the main tub bearing will be that the washer noise will get worse or louder as time goes on. This means the bearing is becoming more worn out and close to complete failure. The bearing in your washing machine is a circular metal object that has many small little metal balls inside. These small metal balls inside the bearing sit in a track and move when the washer is spinning. If the tub bearing begins to wear out, usually the small metal balls inside can fall out one by one causing the noise you hear. (If your washing machine is a front load washer, open the door and turn the drum by hand. If you hear a rubbing sound or the drum spins uneven, then the main tub bearing is most likely bad and needs replaced.)
Washing machine tub bearing
Washer has noise during spin cycle
The bearing may also be without lubrication. If the sound you hear is more of a squeaking noise than a grinding noise, it may mean the bearing needs to be lubricated with a mechanical grease. If the sound is more of a grinding noise, then this usually means the bearing is falling apart and will need to be replaced ASAP. If you suspect your washers main tub bearing is worn out, the repair process is one of the most difficult to perform yourself. A worn bearing can also damage the tub of the washer. This means the tub (inner or outer) may need to be replaced also.
A washer making a loud noise during spin cycle can also be caused by a faulty drive pulley. The pulley is what the belt (if applicable to your washer) rides on to spin your washers tub. The pulley can be made of plastic or metal. It could be simply worn out or just loose. To find out if the drive pulley is causing the noise, you will need to take the washer apart and inspect the pulley for signs of damage.
WASHER MOTOR PULLEY
The motor coupling could also be the cause of the loud noise. The motor coupling in your washer connects the washers transmission to the motor. It is made of plastic and built to break if the washer gets overloaded. This is so the motor and the transmission do not become damaged. The motor coupling is an easier repair and can be done by most people.
Washer Washing Machine Motor Drive Coupling Coupler
The clutch in a washing machine connects the inner wash tub to the transmission. The clutch lets the washer get to the proper spin RPM in a gradual way. If the clutch is worn it can make noise when the washer is spinning. A bad clutch needs to be removed and replaced to stop the noise.
Washing Machine Clutch
The belt in your washer can become worn and cause noise while spinning. If worn out, replace the belt. Replacing the drive belt on a washing machine is an easy task and can be ordered online for less.
Washing machine belt
The drain pump in your washer that drains the water out could be clogged or damaged. While in spin mode, your washer may drain out the water by using the drain pump. If the loud noise only happens at certain intervals during the spin cycle, it may be the drain pump. Usually this can be fixed by simply removing the drain pump and removing any debris that may be clogging it up causing the noise.
Drain Pump for Washing Machine
The next part of your washer that can be causing a loud noise is the transmission. If the transmission is bad, usually the cost to fix this outweighs the cost of a new washer.
If you have a front loading washing machine, they all have shock absorbers. The shock absorbers are used to center the tub movement while in the spin cycle. These shock absorbers are connected from the washer frame to the outer tub. If the shock absorbers in your front loader become weak the washer will make a loud banging sound during the spinning cycle.
Shock Absorber for washing machine
Top load washers usually have springs or dampening straps holding the tub centered. If a spring or strap falls off or becomes weak, a loud noise will be heard in spin mode. Simply replace the strap, spring, or springs to remedy this issue.
Washing machine suspension springs
Agitator directional cogs are used to operate the upper part of dual action agitators (Top load washers). They engage the cogs on the inner area of the agitator as it turns in one direction. They release when the agitator reverses its direction. This lets the top part of the agitator to ratchet in only one direction. The bottom part will agitate in both directions. The cogs are made of plastic and wear out with regular use. They will start slipping and make a grinding noise. Another way to be sure that this part is bad is if you notice the top portion of the agitator does not move in a smooth motion. Removing the top half of the agitator to see if the cogs are worn out.
1helpful
Groaning sounds when draining
HI. You may have a problem with the water pump such as a frozen pulley or a broken impeller. This actual section of the pump is not designed to be repaired. You will need to replace the entire pump device, asap. Once replaced, the unit will operate properly, and without the noise.
Ge triton xl makes loud noise when filling with water - water pump proboem ? or other possible cause? easy fix?
GE Triton dishwasher loud noise after draining water. We started to hear a sustained and loud noise after water is drained. This noise is not heard during washing and draining times. What is wrong? Thanks a lot!
1helpful
Admiral aav-1 makes loud grinding will not spin or drain
Hi, the drain pump impeller is damaged. you will need to replace the entire pump(drain) in this case.
You will hear this noise when the impeller become separated from the actual drive stud or, shaft.
7helpful
Whirlpool Duet Washer Making Loud Grinding Noise
not nesseccarrily your pump, possible you have a rear bearing going bad, which will sound as if a helicopter is coming through your laundry room. ( noisy pump can be the issue , honestly a better and cheapre problem to have) in order to determine if its apump problem you can remove the lower access panel and unplug the pump then start the spinn cycle, if it still loud the pumpms not hte issue.
4helpful
3answers
Washer not spinning or draining. Making LOUD grinding noise.
i started a load it aggetates but when it gets to next cycle it does nothing . i can hear timer switch to next cycle but it doesnt soin or drain .what can it be?
Kenmore washing machine
Does the washer drain? If so, you may have a broken motor coupling. This may be the noise you're hearing. This is a common problem and is inexpensive to repair. The following link explains how:
http://www.fixya.com/support/r385250-replacing_motor_coupling_kenmore_top
If you do an inspection of the washer and find that it is not the coupler, you may have a more serious issue of a gearcase (transmission) or clutch failure. Both of these repairs can be performed without the aid of a repairman as well.
Please doublecheck your symptoms, and get back to me. Your intial description, however, sounds like a simple motor coupling problem.
NOTES:
A bad Motor Coupling will allow the washer to fill normally, but when it gets ready to agitate, a loud rattling sound can be heard. The washer will drain, however. There's usually the presence of black filings under your washer.
A bad Gearcase may will have similar symptoms, but there may be the presence of a honey colored oil under the washer and very loud grinding noise.
A bad Clutch will also exhibit similar symptoms. This is usually a little harder to diagnose without operating the washer without the outside case on. The clutch is located on top of the gearcase directly under the wash tub. If the clutch fails, the drive motor will turn the gearcase, but the clutch will usually slip and not engage the basket drive.
Let me know if any of my explanations sound correct. If not, post back with your complete model number and update me on what your washer is doing, so I can assist you further. I hope this helps you.
1helpful
Nd error essage
nd= no drain. loud buzzing noise sounds like something stuck in pump assy.remove the door(2screws) adn other 2 screws oppisite side, and hte front panel comes off giving you acess to the drain pump, pull the hoses and look for the obstruction
2answers
Does not drain & makes a loud buzzing sound(KENMORE 44042)
this sounds like something has gone into the pump, coins or whatever, the objects need to be removed, also check the hoses, remove the plug to work on any appliance the buzzing is the pump trying to work but unable to go round, start there and see how you go if i have helped rate me please
Top LG Washing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
