If your lights are flickering like a security system is going off, but your car will still start, it is possible that there is an issue with your car's electrical system. Here are a few possible causes of this issue:
- Weak battery: A weak battery can cause flickering lights and may still have enough power to start your car.
- Loose or corroded battery cables: Loose or corroded battery cables can cause a poor connection between the battery and the car's electrical system, resulting in flickering lights.
- Faulty alternator: The alternator is responsible for charging the battery and powering the car's electrical system. If the alternator is faulty, it may not be providing enough power to keep the lights from flickering.
- Electrical grounding issue: An electrical grounding issue can cause the electrical system to behave erratically, including flickering lights.
If you are experiencing this issue, it is recommended that you take your car to a qualified mechanic for a diagnosis and repair. They can perform tests to determine the cause of the issue and provide the necessary repairs to resolve it.
