Question about Kitchen Appliances - Others
Foodsaver troubleshooting Vacuums well but will not seal
arogers270
The same thing happened to mine and I found a really,really inexpensive way to resolve it. I don't use original foodsaver bags and I found out that their thickness might not be detected correctly so it won't vacuum. To compensate for this, I used an ordinary piece of notebook paper. I cut it to a size of 4 1/2" by 1 1/2". I set the long side in the middle of the liquid catching tray and let it lean back towards the heat strip. Make sure it doesn't cover the heat strip or it won't seal. Now I inserted the bag as the directions say, close and lock the top, and it vacuums and seals perfectly. foodsaver troubleshooting - b40a3e78-1fd3-4c38-9291-c5c4e3885648.jpg
Posted on Oct 10, 2014
Dena Pierce
Vacuum/sealer is not vacuuming
Posted on May 04, 2014
3 Related Answers
Lee Eismann
  • 88 Answers
SOURCE: Foodsaver Food Sealer Vacuum V2240 T: Foodsaver Professional II Turbo. Vacuum pump work...
This is likely happening because the unit cannot detect that a vacuum has formed, and as a result, the unit never "turns on" the heating element to seal the bag, with the gaskets around the vacuum channel being the probable culprit. The Foodsaver gaskets will deform and/or dry out with time, just like in any device, but you don't necessarily have to replace them. I've tried this inexpensive solution on my own Foodsaver V2490, and it works perfectly.
Buy some food-grade silicone grease and apply it to both the upper and lower gaskets. I remove the gaskets and coat both sides with a thin layer of grease before replacing them in their respective channels. And since this grease will be absorbed and/or dry out with time, you will have to do this occasionally, so I also flip the gaskets (i.e. turn them over) whenever I apply the grease.
You can buy a 2 oz container of silicone grease at any dive store, or you can buy it over the Internet by searching for "Trident silicone grease".
This is a link where you can buy it for around $7.00:
Dolphin Dive Center
I do not work at this dive center, but I am a scuba diver and already had some grease that I use for the numerous rubber gaskets in my gear. The 2 oz. jar will last you several years, and you will find many other uses for it around the house since the grease will last longer than a spray.
Posted on Aug 02, 2010
Lee Eismann
  • 88 Answers
SOURCE: I have an older model Foodsaver. The machine will
This is likely happening because the unit cannot detect that a vacuum has formed, and the gaskets around the vacuum channel are the probable culprit. The Foodsaver gaskets will deform and/or dry out with time, just like in any device, but you don't necessarily have to replace them. I've tried this inexpensive solution on my own Foodsaver V2490, and it works perfectly.
Dolphin Dive Center
Ed Mac
  • 731 Answers
SOURCE: foodsaver V845 is not sealing?
Does the vacuum seem to run forever and it doesn't seal?
Clean the black foam seals
Replace them if needed. they can be purchased from Tilia
WWW.FOODSAVER.COM
Posted on Jan 24, 2011
Foodsaver vac 1050
Perhaps the bags you are using are not suitable. If they are too thin it will not vacuum air out.
Apr 30, 2018 | FoodSaver Vac 800 Vacuum-Sealing Kit,...
Foodsaver V3840 Won't vacuum air out and wont go to seal. A label states the seals are not removable. Do you know how to fix?
you are not using a "good" bag. Make sure there are no holes and that the bottom and sides of the bag are properly sealed. It will run all day and not pull the air out if the seal is broken anywhere.
Sep 11, 2014 | FoodSaver V3840 Vacuum Packaging System
FOODSAVER V3880 DOESNT GET GOOD VACUUM IN BAG
Sounds like the foam seals are leaking. Go to their website to get replacement parts.
Mar 11, 2014 | FoodSaver V3880 Vacuum Sealer - The Master...
It won't seal it doesn't get hot it vacuums ok
There is a heating element in your unit that seals the bags. Most of the units you cannot replace the heating element. The company is pretty good about warrantying the units. They go by the number on the plug to tell if the unit is still in warranty. Give them a call. 877-777-8042
Jan 19, 2014 | FoodSaver V2222 Vacuum Food Sealer
2240 unit vacuums but won't go into seal mode. if the seal button is manually pushed, it will then seal but the vacuum is lost
I am having the same problem, it is like the heating element for the sealer is broken.My unit actually will NOT seal if I push the manual seal, but the vacuum works.
Feb 24, 2013 | Tilia FoodSaver V2240
Why there say tray full red light
The tape trick didn't work for me. Had to cut the wires. Works for now.
Sep 27, 2012 | FoodSaver Smart Seal Vacuum Sealer V3825
Foodsaver V845 is not sealing? vacuums okay, but won't seal bag.
WWW.FOODSAVER.COM
Jan 24, 2011 | Tilia Foodsaver V835 Vacuum Sealer
The foodsaver blade is stuck
I have the same problem with the blade. It works sliding left to right, but won't cut right to left. I took it apart and removed the blade and it looks o.k. And cannot find replacement part for it either.
Nov 08, 2009 | Tilia FoodSaver V2240
Kitchen Appliances - Others Logo
3,796 people viewed this question
Top Kitchen Appliances - Others Experts
Marvin
Marvin
Irene Tulloch
john h
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
