Question about Nordic Track NordicTrack C2150 Treadmill
Can't get speed to go above 1mph
None of the console buttons work. It will turn on and can start a workout, but can't increase the speed at all.
Posted by Katie Turtenwald on
4 Related Answers
Anonymous
  • 3 Answers
SOURCE: Buttons Froze during workout, now none of them work
It sounds like you just need some calibration. To calibrate incline, turn power on press press any incline buttons, as the incline try to change unplug the key. Now re-nsert key and incline will self calibrate,
Posted on Sep 02, 2009
maxtreadmill
John Mazmanian
  • 832 Answers
SOURCE: My Nordic Track treadmill has has 10 speeds (1mph
You should have a speed arrow up & down, this increases and decreases the speed in .1 mph. Try this control and see how the unit re-acts if the speed does not adjust in .1 mph increments or it stay the same either way it sounds like an upper board issue. Go to iconfitness.com go to customer service the replacement parts put you M# and will give part# and pricing.
RULE OF THUMB: IF REPAIR IS MORE THAN THE THE PURCHASE PRICE OF UNIT DOE NOT REPAIR
Posted on Feb 28, 2010
Anonymous
SOURCE: When I turn on the
First of all you need a Surge protector, you can get one from Nordictrack.com, it is on sale. Secondly, unplug the treadmill and leave it unplugged for at least 24 hours. Before you plug it back again, make sure you already have a surge protector on your outlet. Also make sure Trreadmill is the only load on this circuit. Plug it and try again. I had the same problem, and mine works this way. Some times, with dilrty power, the bit get set and the bottons stop working. Good Luck!
Posted on Jan 03, 2011
ercupa190
ernesto cuadra
  • 12223 Answers
SOURCE: Nordictrack COmmercial 1500 console buttons don't work
http://www.fixya.com/support/r10724803-measure_voltage_in_transforme_fitnes
11_17_2011_8_43_24_pm.gifsincerely. Please keep me in touch.
Posted on Nov 17, 2011
I have a Stepmill 7000 pt. I have a terrible time trying to start a workout program like quick start, manual, fat burner, etc. I have to push the program button multiple times to start the program.
It sounds like you may have a faulty keypad. The following link will take you to this item. Stairmaster Stepper 7000PT Stepmill Parts Transmission SPORTSMITH net You might also be looking at a faulty ground or insufficient power coming from your power supply. Check this out put with a multimeter. You should be getting between 12-19 volts DC.
Dec 05, 2017 | Stairmaster Stepmill 7000 Pt
Treadmill buttons not working
Here is a link to the manual pay close attention to page 16 this will tell you how to see if it is in fact in the demo mode and how to cancel it. Some thing to remember about the display is that it is a matrix with contacts going both horizontal and vertical if one is broken some buttons will work and other won't. You may want to remove the console and clean the ribbon cables.
Mar 18, 2014 | Exercise & Fitness
Powered, but buttons do not function
please adjust the REED switch, TEST for open or faulty, clean it, and tight the plug or connector very well, see the diagram attached.
2) Tight the ribbon cable inside very well for keypads
3) replace batteries with the same types, same value, same polarity, and clean the contacts batteries.FULL charges.
God bless you
Dec 06, 2012 | Proform CrossTrainer Treadmill
My control panel on the Sole F80 Treadmill lights up but nothing I press works
adjust the REED SWITCH, see the diagram attached, clean it and tight the wires connector very well.
tight the ribbon cables insides from keypads +tight the wires connector from display board vs lower board and clean it.
God bless you
Jul 22, 2012 | RTO Sole F80 Treadmill
How does the e3200treadmill fat calories work with the regular calories burnt.
Add incline. Instead of keeping the treadmill on a flat surface, maintain an incline as you walk, jog or run. This will serve to replicate the wind resistance and terrain variation that you encounter when you run outdoors. Keep an incline of at least 1.5 percent on your treadmill throughout your workout.
  • 2 Increase your speed. If you run at the same speed every time you workout, your body will not be challenged and you may reach a fitness plateau. Up your speed by a quarter-mile per hour every few weeks.
  • 3 Vary your workout time. In order to challenge your body in different ways, variety is key. If you run for half an hour three times a week, opt for a one-hour run for your fourth workout. This will help to condition your body for endurance training, resulting in more calories burned.
  • 4 Use intervals. Interval training can dramatically increase your calorie burn in an average workout. Instead of running at a steady pace for your entire workout, mix in sprints. Jog at a steady pace for two minutes, and then increase your speed to a full sprint for 30 seconds. Return to the steady pace to recover. Your heart rate will rise on your intense sprint intervals and stabilize on your longer recovery periods.
  • 5 Incorporate incline into your interval training. You can use incline in the same manner that you would speed to interval train. Walk or jog at a 5 percent incline for two minutes. Increase the incline to 10 percent for two minutes and then to the 15 percent maximum for one minute. Decrease the incline back to 10 percent for two minutes and finally back to 5 percent for two minutes. Repeat this same pyramid interval a few times.
  • 6 Wear a heart rate monitor. This will monitor how hard you are actually working as well as how many calories you burn in each workout. You can then adjust your speed and incline accordingly to maximize your calorie burn.
  • 7 Drink plenty of water before, during and after your treadmill workout. If you are dehydrated, you won't perform as well as you can. You'll work harder and burn more calories if you're hydrated
  • Nov 03, 2011 | Exercise & Fitness
    I plugged in my Pro-Form 730cs treadmill and it won't start.
    My i FIT treadmill won't turn on. Is there a reset button somewhere?
    Aug 28, 2009 | Proform Quick Burn Pro Treadmill with 12...
    Aug 23, 2009 | Nordic Track NordicTrack Treadmill, A2550
    Nordic Track NordicTrack C2150 Treadmill Logo
    83 people viewed this question
    Top Nordic Track Exercise & Fitness Experts
    Marvin
    Marvin
    Jesse Garza
    Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
