Question about HP LaserJet 3055 All-In-One Printer
HP LaserJet 3055
I will try to explain the problem in english ...
I bought it in November 2006 and got any problem until I installed the new version Windows Vista .
Now, the function Scanner and Fax does'nt work now.  The drivers for the material are OK.
But, there is any communication between PC and LasetJet 3055.
May be, you can help me !
Posted by merizzi on
Anonymous
I've upgraded my vista printer drivers and all and it still doesn't work ont he same model. i used to run this printer on a XP but working on seperate computer can be too crumblesome. since it's a plug and play on vista with this printer.. my solution is go to windows photo gallery. under the FILE - hit import scanner / camera. - it will auto read ur scan feature. but before that. just make sure u install a scanner onto ur windows . by going to control panels and set up scanner. - connect printer to computer first when u do that. it will rauto read ur printer. the drivers just owuldn't work but the windos software helps to elimiinate the problem.
Posted on Feb 03, 2009
satya
    Habit-Forming:
    New Friend:
  • 54 Answers
Hi my dear friend,
in this model separate patch software is available for this problem in hp web site.. please try and download it, if you unable to download this software please send me one mail to i will send link to your mail id.( [email protected])
....have nice day.
Posted on Jul 01, 2014
Soulvisitor
  • HP Master
  • 1,113 Answers
The print drivers might be ok but have you updated and installed new Vista Scanner software as well as Print Drivers
Posted on Oct 21, 2007
The HP 3055 network printer, connected to 3 dell inspiron laptops doesn't print...it says it's offline, even though the screen on the printer says "ready." I tried adding a printer profile and...
Check the IP of the printer, it should be manually assigned, if you are not confirmed,
  1. Press menu/enter .
  2. Use the or the > button to select Reports , and then press menu/enter .
  3. Use the or the > button to select Config report , and then pressmenu/enter .
  4. The printer exits the menu settings and prints the report.
Try re installing the printer software from the cd, or download the full version from the links below for your area
HP LaserJet 3050/3052/3055/3390/3392 Asia Pacific Full Software Solution
HP LaserJet 3050/3052/3055/3390/3392 Eastern Europe Full Software Solution
HP LaserJet 3050/3052/3055/3390/3392 North America/Western Europe Full Software Solution
(The full software solution provides print, fax and scan functionality. This software solution is the same solution as the Version 4.0 in-box CD that came with your HP LaserJet 3050/3052/3055/3390/3392.)
You can download Printer manual from the link below
Printer Manual
If you require more assistance in this regard feel free to reply to this post
Best regards-BA
Jan 20, 2011 | HP LaserJet 3055 All-In-One Printer
We just bought a new HP laptop. We have an HP
yep the best way anymore is throught a usb port
Mar 03, 2010 | HP LaserJet 3055 All-In-One Printer
When trying to copy papers do not feed but if you scan they will
HP LaserJet 3050z, 3050 All-in-one, 3052, 3055, 3390 and 3392 versatile printer - Error reported: Document Feeder Jam ISSUE: How to correct the HP LaserJet 3050z, 3050 All-In-One, 3052, 3055, 3390 and 3392 versatile printer if this error is reported: Document Feeder Jam SOLUTION:
  • Clear the jammed media from ADF (HP LaserJet 3050, 3050z).
  2. Remove any jammed media with care.Take out the page gently. NOTE: Take care not to tear the paper. c01075162.gif
  3. Close the ADF cover plate.
  • Clear the jammed media from ADF (HP LaserJet 3390, 3392, 3052 and 3055).
  1. Open the ADF cover plate. NOTE: Check whether all packaging straps inside the ADF are removed. c01075163.gif
  2. Unload the jam clearance component.Lift the two handles with both hands until the component clutch is released.Rotate and lift the jam clearance component, and then put it aside. c01075164.gif
  3. Lift the green handle, and rotate the paper picker until it is opened. c01075165.gif
  4. Gently remove the page without tearing it.If you feel resistance, go to the next step. c01075166.gif
  5. Open the ADF cover plate, and loosen the media gently with both hands. c01075167.gif
  6. When the media are stopped, pull the media out gently along the shown direction. c01075168.gif
  7. Close the cover plate of the flat scanner (HP LaserJet 3390, 3392, 3052, 3055). c01075169.gif
  9. Insert the jam clearance component to reinstall it.Press the two reeds until the component is properly engaged.Install the clearance component correctly. Otherwise, paper jams will continue to occur. c01075171.gif
Have a good day
Jun 22, 2009 | HP LaserJet 3055 All-In-One Printer
HP LASERJET 3055 . I LOST THE DRIVER CD
if u want Drivers for Hp 3055 all in one please use below link for Drivers
in this site please Select correct Operating System witch u have on u r system after Selection u get All drivers & softwares for This printer also available Frimware for it
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?lang=en&cc=us&prodNameId=1140780&taskId=135&prodTypeId=18972&prodSeriesId=1161389&lang=en&cc=us
if this Information is useful for u please Rate me........
Jun 21, 2008 | HP LaserJet 3055 All-In-One Printer
Please help me to to install my printer
hi if u want Drivers for the Hp 3055 all in one
please use link below select the operating system & download it
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?lang=en&cc=us&prodNameId=1140780&taskId=135&prodTypeId=18972&prodSeriesId=1161389&submit.y=10&submit.x=5&lang=en&cc=us
there is Drivers/software &firmware also available
if this information is useful for u please rete me ......
Jun 11, 2008 | HP LaserJet 3055 All-In-One Printer
How to install Hp laserjet 3055
If the connection is ethernet. Print configuration from Printer.
Manually install printer.
Select computer is on local port
Local port to select is TCP/IP
then type in the network address to the printer.
Driver will still be inside computer.
Mar 03, 2008 | HP LaserJet 3055 All-In-One Printer
HP LaserJet 3055 All-In-One Printer Logo
389 people viewed this question
Ekse
efs_perpends
efs_perpends
