FEF368CCS Electric Range. Set oven temp to desired temp--- bake indicator goes to 100 degrees for a few seconds then goes out (like when you cancel). Oven element does not get warm. Broil function does same thing.. when the on indicator lights, it is only for a few seconds then everything goes out. No error codes or other fault indicators. Suggestions?
SOURCE: Oven does not heat up
It could be a bake element or an oven control problem. If you have a volt meter, remove the back of the oven and test the voltage across the bake element terminals while it is on. You should have 240 volts. If it is less than that, you have a control problem. If you have no way to check the voltage, replace the element and try it. It is the cheaper part to replace if you want to try something. Post back if you need to know how to change it or need further guidence.
SOURCE: Electric Oven not getting hot enough
there are relays on the oven control that turn the elements on and off, sounds like you need a new control
Sir, I think the top oelement is for broiling ONLY. It should not turn on when baking. The clicking may be the oven heating up.
How far apart were the oven temp instrument and the digital?
Don't expect them to match...they are inaccurate.
1. Heat water until it boils. Place digital therm in boiling water until it comes up to 212deg. If it is not at 212 in boiling water, record the error.(this gives a rough calibration to the digital)
2 Turn on oven, set to 350 deg, place digital therm on rack. Wait until oven reaches 350 (on stove) and read the digital. Note the difference between the two
SOURCE: Oven not working
Sounds very much like the thermostat has failed and needs replacing.
A job for a qualified engineer I'm afraid.
SOURCE: JBP26 Oven broil and bake do not work and the oven light is flash
If you have 240Volts to the range and BOTH elements don't work, it sounds like the L2 OUT relay on the oven control is bad. Bake and Broil share this line and this problem is not un-common. Make sure you have proper incoming voltage first. Turn breaker off and back on to make sure both poles are set.
If you are referring to the bake element, but the broil element works then you would need to just replace the bake element. If both your bake and broil element does not work, then there might be a problem with the wiring communication. However, if the oven does not bake and/or broil but the cook top works, contact a professional to have the EOC (electronic oven control) diagnosed.
If your electric oven is taking too long to heat or just not heating up right, then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
