MONITOR NOT ON THROUGH ON/OFF SWITCH
You may have problem in the logic board, it uses surface monted components no much chance for DIY repair.
Service manual; http://elektrotanya.com/?q=showresult&megnev=Acer&megnev2=AL2216W&kategoria=monitor&kat2=all
The cases these days are hard to open, they use plastic finger hooks types, they go in easy but real hard to remove without damageing them.
Use thin flat blade to crack open at the bottom edge so the scratches will not be so noticeable, and work your way around, look out for cables attached to the front bezel also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors:http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps:http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit:http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Hi NAEEM SULEMAN, I want to help you with your problem, but I need more information from you. Is the power cable all-the-way plugged into the back of the monitor? IBM/Lenovo monitor plugs work loose, I've noticed. Is it likewise plugged into a good power source properly?
