I am trying to program a universal remote to my proscan tv, I have a greenbriar international remote that does not require any code input, you just press the set up button then press power until the tv turns off but it never does. I have also tried two other universal remotes that did have code entries but they did not work either. Please help!
I found this on ChaCha.
The most popular code to program a remote control to a ProScan TV is 10047 (Others: 10466, 11347, 11447). ! - See more at: http://www.chacha.com/question/what-is-the-code-to-program-a-remote-control-to-a-proscan-television#sthash.S9wE8CE0.dpuf
I hope this helps!
SOURCE: need a remote control code
hi,i had the same problem and found out that the samsung remote codes worked,try that.
SOURCE: Universal Remote Codes
I just programmed my comcast remote today and the codes in the manual work fine. I was lucky, the first one as the one I needed. Good luck.
11454, 10054, 10030, 10706, 10187, 10386,10802,11198,11254,11963,11990.
SOURCE: lcd 32" proscan need code for universal remote
Wow it took me a couple hours but hey i found the code ever1 needs and its a 5 digit code for comcast remotes with the red ok button the codes r 10090 or 10030 hope ive helped u out good luck
SOURCE: proscan universal remote
Found these codes on the website for PROSCAN. www.oncorpus.com, for you model television.I hope this help you with your problem. UNIVERSAL REMOTE CONTROL CODE LIST
For Universal Remote Control brands listed below, please use accompanying Proscan codes
and refer to your Universal Remote Control User Manual for basic instruction for changing TV code to
operate Proscan model.
Proscan codes for Sony TV=8003,8012
Proscan codes for Philips TV=1005,1006,1007,1035,1064,1216
Proscan codes for other universal remotes=272,132,134,116,040,016,024,056,019,262
SOURCE: Comcast remote won't accept codes for Proscan TV
I had the same problem. I have the 40 inch Proscan and they supplied a remote control guide for comcast. It was only 4 digits and it did not work. I called Comcast and they did not know. I found it needed 5 digits so I added a 1 and it worked The code is 10178. Hope it works for you.
