Question about Camco Copper And Zinc Standard Hwd Water Heater Screw-in Fold Back Element
Everything is working on my hot water heater I was just wondering could I replace my 3800w 240 volt standard type elements with fold back type and what are the pro's and con's of doing so, also will this help with hot water recover time?
No.
Fold-back elements are low-watt-density, so element does not burn out as easily since heating is spread across more surface area. But recovery remains 16 gallon per hour.
20 amp breaker and 12 gauge wire: max 3800 watts
30 amp breaker and 10 gauge wire: max 5800 watt.
4500 watt element heats 20 gallons per hour.
http://waterheatertimer.org/How-to-replace-water-heater-element.html
http://waterheatertimer.org/Increase-amount-of-hot-water.html
Instead of changing elements: Set thermostats higher so more cold is added to hot water, and then you have more hot water available inside tank.
Gene
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Posted on Jan 05, 2014
Jan 03, 2017 | Water Water Heaters
Mar 14, 2015 | Reliance 50 Gal. Electric Water Heater...
Dec 01, 2012 | Water Heaters
Jan 09, 2011 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Nov 21, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Nov 04, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Sep 06, 2010 | Reliance & 50gal Electric Water Heater
Dec 25, 2009 | Water Heaters
Apr 05, 2009 | Element Chromalox SG1353-430326 Electric...
Nov 15, 2008 | Water Heaters
122 people viewed this question
