USB port in rear of TV
SOURCE: Lost power cord
You should try matching up the amperage (A) and voltage (12V) with a universal adapter. You can find at radio shack or walmart. Make sure you get as close to possible to correct amps, anything more than the correct amps can fry your tv. Volts doesn't have to be exact
SOURCE: no Picture only sound polaroid tv tdx 03211c
There are two places to look for the problems, the backlight inverter board and the power supply. Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
SOURCE: I cannot hear any sound
Hello The remote comes preset to allow independent volume control of each selected device (Global Volume Unlock). However, you may change the Volume Lock setting to Global Volume Lock so that one device's volume will control volume in all other modes. After that, you can perform Individual Volume Unlock on a selected device to set its volume control for independent operation or Global [2] Enter 9-9-3 and then press the mode key for the device you want to control volume (for example,TV). The LED blinks twice. Now when you press VOL+, VOL-, or Mute, the selected [2] Enter 9-9-3 and then press VOL+. The LED blinks four times. [3] Enter 9-9-3 and then press VOL-. The LED blinks four times. Volume is now
First make sure that the "Mute" function is OFF. If it is set to "ON", no volume will be there.
Your TV has a volume lock function included [Global Volume Lock].
Volume Unlock to remove all volume locking.
Locking Volume Control to One Mode (Global Volume Lock)
[1] Press and hold SET UP until the red LED blinks twice; then release.
device (for example, TV) will control the volume regardless of the current mode.
Unlocking All Volume Control (Restoring Global Unlock)
Volume is now independently controlled for all programmed devices.
Unlocking a Single Device's Volume Control
[1] Press a device key (TV, VCR/DVD, CBL/ SAT, or AUX).
[2] Press and hold SET UP until the red LED blinks twice; then release.
independently controlled for the selected devices.
OK
