Question about Tag Heuer 2000 Aquaracer WAB2011.BA0803 Wrist Watch
Set gap watch alarm - Tag Heuer 2000 Aquaracer WAB2011.BA0803 Wrist Watch
1 Related Answer
Anonymous
SOURCE: How do I adjust date of my watch bought from GAP
Here is the manual from GAP customer service.
Dear gap.com Customer,
Thank you for your email regarding the Sporty Printed Watch user
instructions. Please accept our apologies that no directions were
received with your order.
The instructions are as follows:
Button Functions:
A. Light
B. Mode
C. Start
D. Reset
Standard Time Adjustment:
1. To set the time, press the Mode button three times (The seconds and
the word Tuesday should start flashing).
2. If the seconds position shows less than 30 seconds, pressing the
Start button will reset the seconds to 00. If the seconds position shows
more than 30 seconds, pressing the Start button will reset the seconds
to 00 and the minutes will increase by 1.
3. Press the Reset button until the area you want to change starts
flashing (i.e., second, minute, hour, day, month, and weekend. Press
Start button once for per unit increment, press and hold for 3 seconds
for speedy advance.
4. At completion, press Mode button to resume standard time display.
To reset the Alarm:
Press the B: Mode button until you reach the alarm.
Press the D: Restart button.
Press the C: Restart button to get back to the time
Posted on Dec 13, 2008
How do I set the alarm on model wau111a tag watch
  • Pull out the crown to the alarm setting position. The crown is located on the right side of the face of the watch. Pull the crown out until "AL", the alarm indicator, is shown on the watch. Depending upon the model of your Tag Heuer Aquaracer watch, you will either pull the crown out in the first or second position.
  • Select the hours and minuets for the alarm. Once your watch is in the alarm setting position, press the bottom right button on your watch. This will enable you to select the hours and minuets that you want to set the alarm for.
  • Set your alarm. To begin setting your alarm turn the crown clockwise until the desired hour or minutes are displayed on your Tag Heuer Aquaracer watch. If you happen to accidentally pass the alarm time, turn the crown counter-clockwise the get back to the desired alarm time.
  • Save your alarm. When you are ready to save your alarm, simply push in the crown. Once your alarm sounds, to silence it press any button on your Tag Heuer Aquaracer watch.
  • Nov 06, 2014 | Tag Heuer Link Watches
    How do i turn off the hourly alarm on a gap sport watch?
    Press the start and the reset buttons at the same time and the Alarm mode will go off.
    Sep 13, 2009 | Watches
    How to turn off hourly alarm on Gap Sport watch?
    Click reset button (lower right) - this shows you the alarm time as indicated by a large letter 'A' that appears in the display.
    Keep holding the reset button and simultaneously press the mode (lower left) button.
    This toggles the days of the week at the top of the display.
    All days shaded in black means the hourly alarm is on.
    All days clear means the hourly alarms is off.
    Now, if I could just figure out how to choose the exact days the alarm can be set to ring ... it seems like it is possible.
    Aug 16, 2009 | Watches
    How do i set alarm on a gap sport watch?
    For setting Time & Date...
    1. Push "MODE" button three times (change Mode to TimeSet)
    Time -> StopWatch -> AlarmTimeSet -> TimeSet -> Time ->...
    2. Flashing Second Number Digits
    3. Push "RESET" to select...
    Second -> Minute -> Hour(12hr<->24hr) ->...
    Date -> Month -> Day of Week -> Second -> ....(repeat)
    4. Use "START" to set each item...
    For setting Alarm ON/OFF
    1. Push "RESET" button then Push "START" same time...
    Alarm ON -> Alarm OFF -> ... (repeat)
    Jan 09, 2009 | Columbia All Sport Digi Watch l
    Sector 250 Chronograph Alarm
    the middle dial on the right side of the watch is used to switch from watch settings to alarm settings..
    pull the middle dial out to put it in alarm mode.
    To set alarm:
    -pull the center knob out.
    -with it out you can now use the bottom (right) knob to set the alarm.
    -pull the bottom right knob out one notch
    -turn the knob clockwise or counter clockwise to set the alarm time
    -push the knob back in (all the way)
    the alarm is now set
    if the center (right) knob is pulled out the alarm is ON
    if the center (right) knob is pushed in the alarm is OFF
    I have owned this watch for about 10 years now and love it.
    the past few years the chronograph buttons (on the left side of the watch) were not working well rendering the chronograph and count down timer functions unusable.
    repairing a chronographs is expensive and watch makers usually charge several hundred dollars which is not a feasible fee for a watch of this value so i decided to open it up my self and clean it up and that did the trick.. its working like new!
    enjoy the watch!
    Dec 11, 2008 | Sector 2653940025 Wrist Watch
    I think I figured it out: (Start + Reset) = toggle alarm on/off ("ALM" will display in upper left corner when alarm is on. (press Mode once) will bring you in chrono mode, where "start" button starts and stops the chrono, and "reset" button resets it back to zero (press Mode once more) will bring you to setting of time for alarm. Set the "hour" value by pressing "start" repeatedly, then press "reset" and set the "minute" value by pressing "start" repeatedly (press Mode once more) will bring you to setting of time for actual time. Reset the "Seconds" value to zero by pressing "start" button once, then press "reset" and set the "minute" value by pressing "start" repeatedly, then press "reset" and set the "hour" value by pressing "start" repeatedly (if it shows "H" in upper right corner, time will be displayed euro-style 0:00-23:59, if it shows "A" time will be displayed 12am/12pm), then press "reset" and set the "day of month" value by pressing "start" repeatedly, then press "reset" and set the "month" value (1-12) by pressing "start" repeatedly, then press "reset" and set the "day of week" value (Su-Sa) by pressing "start" repeatedly (press Mode once more) voila!
    Nov 12, 2008 | Watches
    Button Functions:
    A. Light
    B. Mode
    C. Start
    D. Reset
    for speedy advance.
    To reset the Alarm:
    Sep 29, 2008 | Tag Heuer 2000 Aquaracer WAB2011.BA0803...
    Watch isn't recognised by computer
    Hi Hoffman518,
    To set the alarm on your Timex Ironman, please follow the steps below.
    1. Begin by pressing the "mode" button until the alarm screen appears.
    2. Press the "set" button and use the "advance" button to set the hour for your alarm.
    3. Repeat the same procedure to set minutes and seconds for your alarm.
    4. When you have finished setting the alarm, press the "set" button, followed by "advance" save and activate your alarm.
    5. When you alarm sounds, you can deactivate it by pressing any button on the watch.
    Hope it helps.
    Thank you for using FixYa.
    Aug 08, 2007 | Timex Ironman 53151 Wrist Watch
    Tag Heuer 2000 Aquaracer WAB2011.BA0803 Wrist Watch Logo
    46 people viewed this question
    Top Tag Heuer Watches Experts
    Janelle Schoonover
    Janelle Schoonover
    Bruce Robin
    Are you a Tag Heuer Watch Expert? Answer questions, earn points and help others
