Question about Sony Vaio PCG 7Q1M Laptop Universal AC Adapter 18-20v (AC22VPNNTMPX8)
Cooling fan stopped working
What replacement model numbers will fit?
Posted by Anita Trestrail on
Ian
    New Friend:
  • 48 Answers
Any 18-20 volt laptop charger should work only need correct power plug and that can be easily changed if necessary with soldering iron and volt meter. using old charger plug as replacement. volt meter is used to check out correct polarity of plug before and after you re solder plug on.generally outside is -ve and center is +ve ,alternatively go to ebay or google and type in Sony Vaio PCG 7Q1M charger,or type in part number ,or try 18-20v laptop charger, that is what I do when I need a replacement charger,cost around $10 delivered usually.
Posted on Jun 10, 2014
Hi, i replace the thermostat and water pump flashed the radiator has coolant but still overheating, what else could it be its golf 4 tdi diesel 2002. Thank you
Radiator may have rust/salt deposits inside, if that is case its cheaper and better to change the radiator. Also for future don't use normal tap water in radiator, use a coolant + ph balanced water meant for radiators to reduce salt buildup inside radiator.
Also check the radiator fan is working ok and rotating in the right direction, sucking cool air inside not blowing out hot engine air to the radiator. Some electric fans can have wires mixed up so they start in the wrong direction. (make sure fan is sucking cool air outside towards the engine).
In some cars, radiator fan has a top cover that stops hot engine air getting sucked by the fan, if your car has it, make sure it is fitted properly and is in good order.
Some cars have a fan fitted on the AC condenser, make sure this fan is working as well.
Oct 01, 2016 | Cars & Trucks
My Daewoo freezer is not working since yesterday, we tried to change the fuse but it just works for 15 seconds then,it stops we don't know why can you help please?
I would think that the compressor is either overheating, or faulty and cutting out on a Thermal overload cut out device fitted to the compressor.
If it is overheating, then it could be due to several problems:
1] Ventilation to the compressor is poor, or blocked.
2] compressor Cooling fan failed ( not fitted on all models)
3] Condensor blocked ( Not fitted on all models) This looks like a small car radiator in the compessor compartment (if fitted?).
Turn the fridge off, and leave it for up to 2 hours to cool, once cool, ensure that the ventilation is good around the compressor compartment, and try it again. If it starts and runs as normal it may have just overheated. If there is a fan fitted in the compressor compartment, then observe if it is working or not when you turn it back on.
If the compressor cuts out again, as you have described, trhen it is more than likely that the compressor has failed and needs replacing.
This is not a job that a novice can do, and will be expensive to have replaced by a Refrigeration engineer.
I hope this helps?
Feb 22, 2016 | Daewoo Refrigerators
How to check for Asus UDQF2PH62BAS CPU FAN compatibility?
The only way to see if this replacement part will work for you or not, your product's Part Numberhave to be the same with our replacement Part number. If it's on the list, then it will be compatible. (Your Deivice Model number is not good enough to verify correct product).Part numbers can be located on your Asus UDQF2PH62BAS Cooling FAN or you can check your user's manual. Another way to check for compatibility would be to check the listing within the "Fits the following model." The list will provide you with the product model that would be compatible with the List item. for more information : www.2egoo.com
Mar 28, 2012 | Computers & Internet
I have a HP PL4245N plasma HD TV. sometimes while watching it just shuts itself off screen goes black and will not turn back on unless I unplug it wait 20 seconds and plug back. Then it works fine. it...
Hello
I thinks you may be right. All plasma and LCD panel tVs will have cooling fans at the top side. Plasma screens will heat up much more, and if cooling fans stops work, of has damaged, the set will overheat, and awill automatically shut down; because there is a overheat sensor fitted inside it, will sense the heat, and if the set overheats, it will send a signal to the main system control fo the TV; which in turn shut down the whole system. look fans for proper working. If not replace them. OK.
Jul 04, 2011 | HP PL4245N 42 in. HD-Ready Plasma...
Stopped cooling no humming or nothing digtal reading are working but nothing else
you need to replace the fan at the back of the unit. no noise means the fan is not working. The fan removes the heat from inside the unit to cool it. no fan, no cool. Your local appliance repair can fix it. the fan does not cost much and there isn't much labor involved. If you want to tackle it yourself then take your model number to the appliance store and order a fan, remove the back and replace the fan. Some fans are plug and play, some are not. if yours is not plug and play then you will have to splice wires. either way, the fan is your problem.
Nov 23, 2010 | Oster 12-Bottle Wine Cellar - Black
Model number for the interior cooling fan, for a toshiba laptop
I have found a link to a web site that sells them but they are dear they have the product code also for your fan so you might get one cheaper on ebay or something.
http://www.notebooksolutions.ca/zc/index.php?main_page=product_info&cPath=66_140&products_id=1250
Feb 25, 2010 | Toshiba Satellite A105-S4074 Notebook
Model: GSH22JFT (GE side by side) freezer working by refrigerator not cooling.
The most common problem for your model refrig , to stop cooling the ref section , is a shorted defrost heater in the freezer section . Do you see a light layer of frost on the rear inside lower freezer wall ? Do you hear the fan in the freezer working ? If you have the frost , you will need to remove the rear inside freezer panel ( 2 screws ) , and at the bottom of the coils , is the defrost heater . Part number WR51X10101 . This replacement heater , comes with 2 heaters , due to the old 1 heater burning out so often . The part , sometimes comes with a wire extension , since the blue wire will have to be moved over to the right , with the orange wire , to make it long enough to fit , and sometimes doesn't come with the extension , in which case , you will have to make one . It's also best , to replace the defrost thermostat ( bimetel ) while the panel is off also . Part number WR50X10068 .
Oct 25, 2009 | GE GSH22JFTSS Stainless Steel Side by Side...
Refrigerator and freezer not cool at all
Most likely the fan that draws air over the condenser coils has burned out. It's a small fan usually toward the back of the unit on the bottom. While you're under there, be sure to clean the dirt and dust off the coils.
The fan is pretty easy to replace and doesn't cost a whole lot, so this might be a fix you can do yourself if you're mechanically inclined. There are any number of third-party manufacturers who make these fans. They're sort of 'universal' and can usually be adapted to fit just about any make and model.
Jun 11, 2009 | Admiral 26 cu. ft. Side-By-Side...
Laptop fan stopped
emachine has laptop ?? what's the model ?
May 02, 2008 | Computers & Internet
Sony Vaio PCG 7Q1M Laptop Universal AC Adapter 18-20v (AC22VPNNTMPX8) Logo
78 people viewed this question
Top Sony Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Michael Thomas
Michael Thomas
Muntejaya Ginting
Muntejaya Ginting
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
