When power is disconnected and then reconnected the two front burners come on high and won't turn off
SOURCE: LG Electric Range Oven Keeps Shutting Off
When you say "Just shut off" do you mean the circuit breakers would trip, or fuses would blow? If so, I would have an electrician check that the circuit is properly fused/breakered and wire sized for the amount of power required by the oven. If the installation directions say it needs a 50 amp service, it better be a 50 amp service.
If shutting off is just something within the oven, then get LG back out again, and let us know of what they say is wrong.
SOURCE: lg range
Contact your states attorney general office and file a complaint online. Hopefully if enough of these get through they will do something. I live in Ohio and this is their website http://www.ohioattorneygeneral.gov/ConsumerComplaint
SOURCE: burner on range will not turn off
Look at the back of your range there should be schemetic for your power control board. look for defective burner wire going into relay. There should be 5 relays in rows. Realy is the problem. I had the same problem with my front left burner stuck on high.
After replacing everything works okay.
SOURCE: range top front burner will not shut off, stays on
I have the same problem with the LG LSB5682SW Electric Range - Font Left Burner will not go off / stays on high. This is very dangerous. LG customer service is horrendous. I think it is time for a recall before someone's house burns down!
SOURCE: The burners on my LG LRE30755ST range will not
Sorry to read about your problem, I hope this helps you out.
The PF message will appear whenever there has been a power interruption to the appliance. To clear the PF message touch CLEAR/OFF control pad and be sure to reset the clock with the correct time of day.
• To clear the HS message touch ON/OFF pad.
if this does not correct the problem. you then have a defective control card, inside the range.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
