Question about Olympus Stylus 770 SW Digital Camera
Lcd screen not working
I used the camera in saltwater, worked for 2 days then LCD screen went black. I rinsed the camera in fresh water everyday after use and did not go more than 10 feet deep.
5 Suggested Answers
Anonymous
SOURCE: lcd screen is black
you have to disamled your camera and reconnect the LCD it happens when the cable of the LCD is half out
Posted on Mar 03, 2008
Anonymous
SOURCE: In shooting mode the lcd screen is black
Olympus says this is a bad image processing chip. They will replace it at no charge if you are still within the year warranty period. They require proof of purchase i.e. receipt, copy of charge card statement, copy of warranty card, etc. Contact them for further information on how to return it.
Posted on Apr 04, 2008
Anonymous
  • 919 Answers
SOURCE: Olympus 1050 - lcd screen blank, gasket was loose.
It is possible that since water did get into somehow that it did some internal damage to the camera. I recommend that you call Olympus Customer Service and discuss the repair process with them. Their telephone number is 800-622-6372 option 2 and then option 3
Posted on Dec 18, 2008
Anonymous
  • 378 Answers
SOURCE: My LCD display just randomly stopped working.
replace the battery and check out firat with brand new battery.many a times it battery problem.if still the same problem its due to lcd ic faulty on the mini circuit board.that has to replaced by a service center.
Posted on Apr 03, 2009
Anonymous
SOURCE: Olympus E10 went black
Sorry I can't solve this but if you decide that the camera is ready for the digital graveyard I need to replace the battery holder on mine because the screw od the holding lever is bust!
Posted on Apr 10, 2009
Canon Rebel EOS T3 - camera has power but there is no LCD display whatsoever.
Has the camera been dropped or had a liquid spilled on it? Sound like a circuit failure. However, if it has been dropped it may indicate that one of the flexes has come out or the little flipper on the flex connector has popped up and the connector is not working.
Apr 28, 2013 | Canon Eos Cameras
LCD screen on Canon camera is white
It is damaged and must be replaced. If the LCD screen is the only issue I'd be surprised. Saltwater is extremely corrosive to electronic parts. If enough water got on the LCD to cause damage chances are very good it got into the camera as well.
Apr 01, 2013 | Canon Powershot Sx150 Is 14.1 Mp Digital...
Olympus 850 sw digital camera 2 yrs old! Used all day perfectly fine turned back on screen blank, still takes photos, Still flashes, still beeps when press buttons just lcd screen is black likes its off?...
Hi
Either the LCD screen is cracked or defective in some other manner. It's possible the LCD works but just the backlight is out as well. Either way, the camera needs to be opened and the LCD checked out.
The Olympus "Tough" and "SW" cameras are FAR FROM being either "Tough" or "S"hock and "W"aterproof. I have seen dozens and dozens of them with cracked glass over the LCD and destroyed by water damage. Sounds like something got inside your camera or it was badly dropped.
Hope this helps.
Thomas Drayton
Owner, Darntoothysam.com
Affordable Digital Camera Repair
Sep 07, 2011 | Olympus ? 850 SW Digital Camera
LCD screen started getting fuzzy, then went dark.
You have inserted battery in your camera after splashing water onto it. Switching ON the device caused short in the circuit. It needs to be send for service (repair), there is no other way to fix the problem.
Rating the solution is highly appreciated....Good Luck
Mar 05, 2010 | Sony Cyber-Shot DSC-P72 Digital Camera
Hi. The LCD screen is black and won't take a photo...
This is a common problem... it is time to change the camera
Jan 19, 2010 | Sony Cyber-Shot DSC-P200 Digital Camera
No. It is likely that there is still water in it. It's very important that you take the battery out and do not try to use it. Take it to a repair shop and be SURE to tell them it had water in it so they can take the appropriate steps to clean and protect it.
Aug 04, 2008 | Sony DSC-T7 Digital Camera
LCD screen wont work
I had this problem w/ my canon. It is a cracked LCD screen. I took the camera apart and replaced the LCD screen. I ordered the new one for $50 including shipping. you may have to do some detective work to find the part you need. I used a screwdriver for eyeglasses.
Mar 27, 2008 | Fuji FinePix A600 Digital Camera
SD450 lcd went black
Please see the following post, and look for the SD400 LCD repair link. Click on the pictures of that site for larger pics. Follow the disassembly instructions, but skip the lengthy LCD removal portion. Instead just look for the LCD connector as shown on the front of the camera. Unseat the cable from the connector as shown by lifting the connector gate, BUT DO NOT unthread the cable through the camera. Merely examine its ends, and if it looks dirty gently clean it with a drop of alcohol on a Qtip. Give it some time to dry, and then reseat it back into its connector, close the connector gate, reassemble the camera and try it out.
http://camerarepair.blogspot.com/2007/11/fixing-or-replacing-broken-lcd-screen.html
Make sure you also read the following Flash Capacitor Shock Warning post on the above blog site before proceeding.
http://camerarepair.blogspot.com/2007/11/important-warning-camera-flash.html
Good Luck and hope it works. If it doesn't the next step would be to check out the electrical wire power connection to the back light.
Feb 18, 2008 | Canon Powershot SD450 / IXUS 55 Digital...
Blank LCD screen
you have accidentally turned the lcd pannel button off.just turn it on.
Feb 03, 2008 | Canon PowerShot A630 Digital Camera
Open Questions:
See all Olympus Stylus 770 SW Digital Camera Questions
Olympus Stylus 770 SW Digital Camera Logo
50 people viewed this question
Top Olympus Cameras Experts
Ekse
Jerry Greenberg
Jerry Greenberg
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you an Olympus Camera Expert? Answer questions, earn points and help others
