Sewing Machines Logo
A
Anonymous Posted on Jan 03, 2014
Won't pull bobin thread correctly
When I attempt to sew it pulls multiple loops from the bobin. I can only get one or two stitches and it knots up.
4 Related Answers
Anonymous
  • Posted on Oct 29, 2007
SOURCE: sudden knotting under fabric
I have an Elna 2005 machine and had a similar but opposite problem whereby the tension up top was too tight - thread wouldn't pull smoothly. I found adjusting the feed dog lever slightly helped the stitches a lot, even though the needle tension up top is no better. Hope that helps! :-s
Anonymous
  • 8 Answers
  • Posted on Apr 21, 2011
SOURCE: My machine drops stitches, bobin hangs up, thread
This may sound very simple, but try putting in a new needle. If the needle is blunt or has a burr on it, that could be the cause of your issues.
If it is a drop in bobbin style machine you may also have a "needle nick" on the plastic bobbin case. The thread can get caught up on those little knicks causeing it to get caught up or fray.
You can pollish down the little knicks with a very fine sandpaper to smooth them out.
Tally Girl
Tally Girl
  • 1134 Answers
  • Posted on Nov 03, 2012
SOURCE: elna sewing machine 7000 geting bobin won't go through the feed dog
sorry, not sure I understand your problem. can you elaborate?
Have you got the correct Elna bobbin for your machine? check your manual, it should have an image of the bobbin, the 7000 was one of the last Swiss made Elnas and although a computerised machine, it still tool the Elna metal bobbin with 7 holes on one side only. If you are using another bobbin in the shuttle, it may not function correctly.
if you can add some more info I will try to help you further.
Debbi's Sewing Machine Repair
  • 7365 Answers
  • Posted on Nov 20, 2012
SOURCE: my elna 7000 bobbin thread will not pull up with the needle in order to sew.
try changing the needle
rethread the machine top and bobbin
here is a link for a manual if you don't have one
http://sewusa.com/Sewing_Machine_Manuals/Elna_Manuals/7000_Instruction_Manual.htm
try a different bobbin incase that one is warped
it's also possible that the machine could need the timing checked
Singer 603E Sewing Machine. Why is it making a rat's nest when I try to sew.
Your sewing machine tension is incorrect. Tension is a delicate tug of war between the upper thread and the bobbin tension to place the knot loop in the centre of the two pieces of cloth.
Sewing machine tension is how tight the threads are pulled as you sew. The tighter your thread (or the higher your tension), the tighter your stitches. With proper tension, your sewing machine needle moves up and down, the bobbin thread is pulled up, and you get nice, neat, even stitches.
Understanding Sewing Machine Tension - DIY Danielle®
https://diydanielle.com > sewing-machine-tension
I have a 9020 singer sewing machine I bought without a manual. I can't seem to sew without looping the thread under it. Almost in knots.
Are you saying the upper thread is knotting under the fabric as it stitches? This is bird nesting or thread nesting and is generally caused by mis-threading, the thread not being seated in the tension disk, or the upper tension too loose.
When threading the upper thread, ALWAYS RAISE the presser foot. Verify that the machine is threaded correctly. If one guide is missed, the stitching will go haywire. Start out with the upper tension set around the midway point and then tweak it through test stitching.
What causes Bird Nests Superior Threads
Sewing Machine Thread Bunching Up Here Why
Birds nest under the fabric big loops of thread top side looks good...
Model 4075 white sewing machine thread from bobbin builds up and stops sewing.
Check the stitching and confirm that it is in fact bobbin thread and not the top thread that is creating knots & loops under the fabric. This is usually the case and is called thread nests or bird nests. (You can search the internet for more information about this symptom.)
Install a brand new needle.
Remove the thread from the machine.
ALWAYS RAISE the presser foot while rethreading the upper thread.
Confirm the thread path is correct.
Verify the bobbin is installed facing the correct direction in the bobbin case and the bobbin case is threaded properly.
Set the upper tension to the midway point (factory standard) although it may need to be tweaked as machines change with use and time.
Pull up the bobbin thread. This method works with general sewing projects, not just quilting.
How and Why to Bring up the Bobbin Thread
Begin to test sew slowly.
If the thread is still making a mess, then the machine most likely has a timing issue. There are multiple web sites and videos that discuss sewing machine timing. Or take it for service.
2answers
Thread Knotting underneath
plug it into your charger cable and 110volts, there is only one connector that the charger cable will go into.
How to bring up bottom thread
Be sure you leave a 3-4" tail on the bobbin when you insert it. Hold the end of the top thread, turn the fly wheel toward you until the needle goes down into the bobbin, grabs the bobbin thread and pulls it up. Take both threads toward the back of the machine and pull out about 6". Hold both threads as you take the first stitch in your fabric.
Why won't my Bernina Activa 140 sew the blind hem stitch?
Are you absolutley sure you're not getting a problem with stitch formation on, for example, wide zig-zag. Check again, using a different colour top and bottom and make sure that the stitch is being formed properly with only the top colour on top and bottom colour on the bottom. It sounds as though the bottom loop is not being picked-up by the hook properly. Make sure you've thoroughly cleaned-out any fluff under the stitch-plate and remove the hook/shuttle and give the hook race a good clean and give it a single drop of oil, even if you've got the lightweight part-plastic hook/shuttle fitted.
Can't set the tension on needle or bobbin to match
1. make sure your machine is threaded right.2. set the tension between 3 and 4 and play with the tension as you need it to adjust it.3. make sure the bobbin is threaded right.make sure to visit the site below; it has solutions to multiple problems and instructions how to thread the needle or bobbin. Good luck.htt://Fix Looping/Knotting Thread Fix Knotting/Bunching Thread Looping Bunching & Knotting Thread
1helpful
2answers
Thread tangled in the bobine
I had this same problem yesterday. I took apart the needle tension casing and now it doesn't get tangled or stop. The only thing is the bobbin is not sewing...it looks fine on the top, but the bottom is just loose loops.
10helpful
3answers
How to tie knot using handy stitch machine how to tie off the thread so it won't come undone.
When you get to the end cut the threads long enough to be able to tie.
From the wrong side of the fabric, if you pull the thread slightly you will see the a loop from the top thread, pull this, so now both threads are on the wrong side, tie a square knot and cut close to knot, you can also put a drop of fabric glue on the knot to help secure it.
Hope this helps, and please rate if helpful or not
Moni
2helpful
4answers
BOTTOM STITCH IS ALWAYS LOOSE
If the top stitch is loose, then you need to tighten the bobbin tension: if the bottom stitch is loose, tighten the top tension. Hope this helps. It could also be the size needle and thread you are using for a particular fabric. Different fabrics require different notions.
Top Elna Sewing Machines Experts
Mike Cairns
Mike Cairns
SmartAviator
SmartAviator
Ngoro
Are you an Elna Sewing Machine Expert? Answer questions, earn points and help others
