OUTPUT DC VOLTAGE IS ZERO
SOURCE: COMPAQ V2000 WILL NOT POWER UP WITH DC/ADAPTER OR BATTERY
After you have verified that the solder is good around the DC Jack >>>>
Check MOSFET (Anachip 4407 or Fairchild 4435) near DC JACK
[replace the pair PNP/NPN]
Check MAXIM IC (MAX1999)
SOURCE: Compaq Presario V2000 no power new dc jack
I had similar problem, the power pin soldering has gone bad. I removed the cover and soldered it back, its woking now
Hve u tried a differnt adaptor , the adaptor might be blown too ,try replacing the adaptor , also check for the power cord if it has any kinks in it which may be interrupting the power supply , since the adaptor 18.5 v 3.5 a is the most common of all hp adaptors u should find one to try .
SOURCE: Gateway 405ROG AC Adapter Output Polarity
it doesn't matter if its + or - , make sure the pc runs on 19 volts and that the AC adapter does also, look underneath the laptop to find out if it does run on 19 volts but make sure the power jack fits the socket o the laptop before plugging it in to the mains
This is High Quality original LINKSYS AC Adapter Charger
Input Voltage: 100V-240VAC (50-60Hz)
Output Voltage: 12v1a
Model: AD12V/1A-SW
DC Plus Dimension: 5.0mmX2.1mm
Compatible Models:
WAG300N
WRT54G
WRT54GS
WRT300N
Linksys Routers
