Question about LG Tromm Front Load Washer And Dryer Set
Lg washer wm2650
Problems with noise on spin
Anonymous
  • 95 Answers
SOURCE: LG WM0642H front load washer making a loud vibration-type noise
mc not level
Posted on Nov 18, 2009
Rattling noise in spin, spin problems becoming more pronounced. control panel lights flash but 0 error codes. unplug 2 reset, probl repeats
If this noise is happening while it's trying to drain water then you have something floating around in the lump. Coins are very common. If the noise is happening during a spin cycle and more pronounced during the final high spin cycle, you have bearing or spin tub issues. Time to go shopping.
Nov 07, 2013 | Frigidaire ATF6000ES Front Load Washer
The machine won't pump water or spin and makes nasty noise. When I turn the drum by hand there is no noise and feels normal.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Jul 08, 2011 | Bosch Washing Machines
I got a whirl pool cabrio and it makes a noise noise and will not drain
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
If you are having problems with your front load washing machine then checkout this tip...
heatman101
May 08, 2011 | Whirlpool Ultimate Care II LSQ9564J Top...
Spin cycle doesn't spin clothes dry. machine makes noise when it first starts to agitate but then the noise quits.
heatman101
Apr 28, 2011 | Washing Machines
Washer is making noise while in spin cycle
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front load washers can make..
Washer Problems Washer noise when spinning
heatman101
Sep 25, 2010 | Washing Machines
It will spin but the water does not come out, then it makes a funny sound-like a high rattle noise. We have never had any problems - we checked the hoses, they are clear. I has worked like a tip for years,...
heatman101
Aug 29, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Makes a lot of noise when spinning, could be
Check out this tip I wrote about that...
http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when
heatman101
May 31, 2010 | Candy CBL166 Front Load Washer
When in the spin cycle it now makes a horrendous noise
heatman101
May 14, 2010 | GE WPXH214A Front Load Washer
It makes alot of noise when its in the spin mode
heatman101
May 13, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Loud spin noise from Maytag washer
Check the drum bearing, a load noise, and often spinning problems are symptoms of a bad drum bearing.
Jan 05, 2009 | Washing Machines
LG Tromm Front Load Washer And Dryer Set Logo
35 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
