Dryer won't heat. I tested the Heating coils and over temp thermostat but I can't get at the cycling thermostats. I tested them with my ohm meter by looking for conductivity between the red wire and the other two yellowish ones. They test ok that way but I wanted to test them in isolation. I don't know how to get at them.
Https://www.repairclinic.com/RepairHelp/Dryer-Repair-Help
I’m happy to assist further over the phone at https://www.6ya.com/expert/david_dc2f9e0a44104720
SOURCE: help with door switch wiring.
Just found that my neighbour works for comet
Got full PDF. Whiring is as follows:-
3=Gray
4=Brown White
5=Pink White
SOURCE: Hotpoint CTD85A F15 error not drying clothes
Hi
f15 means heater relay on pcb is welded closed
which basically means the pcb has failed and needs replacing.
regards
SOURCE: i HAVE A HOTPOINT ELECTRIC DRYER-EVERYTHING
Check the thermal fuse... it should also read zero ohms...
A dryer may not start for many reasons...
This tip that I wrote will help you to figure out what is happening...
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
SOURCE: HOTPOINT TDC32P Dryer - No Heat Usual story. Have
Could well be a intermittentt sticking relay, I have experienced this myself, fitting new relay solved the prob, I doubt you will be able to obtain a wiring diagram , in any case , you should not need one.
I would fit a new relay myself if I were you.
Testimonial: "Extremely quick reply and sounds sensible solution."
SOURCE: My Hotpoint Aquarius VTD60 tumble dryer works ok
you can use a multimeter to check both. case usually must be removed. for the heating coils, make sure the unit is unplugged !!!, change the meter to ohms, then touch the meter's leads to each end of each coil. should be around 3-10 ohms depending on the power rating. to test the thermostats, unhook all dryer leads to the thermostat and connect and secure the meter's leads to the thermostats leads while still in ohms; should be just two leads on each thermostat. if it has more, it could be a preheated type; you'll need the part number off the thermostat to get the pin functions. should be close to zero while cool, and open (or infinite ohms) when you heat it up (use a lighter). this is a crude test to check the thermostat's basic operation, not how accurate they are. Most dryers have two thermostats; one for low, and one for high, and are mounted in or on the air duct behind the lint trap. good luck.
https://www.repairclinic.com/RepairHelp/...
