Zanussi ZBF360X Electric Single Oven Logo
A
Anonymous Posted on Jan 03, 2014
Oven light not coming on - Zanussi ZBF360X Electric Single Oven
Replace light in KEMC378KSS microwave
The oven lights are 12-volt, 5-watt maximum halogen bulbs. They
will come on when the oven door is opened. On double oven
models, both upper and lower lights will come on when either
door is opened. The oven lights will not work during the Self-
Cleaning cycle. When the oven door is closed, press OVEN
LIGHT to turn them on or off.
To Replace:
Before replacing, make sure the oven is off and cool.
1. Disconnect power.
2. Remove glass light cover by grasping the front edge and
pulling away from oven
3. Remove bulb from socket.
4. Replace bulb, replace bulb cover by snapping back into wall.
5. Reconnect power.
1helpful
When I turn on the wall oven it will not heat up, the light doesn't come on
If the oven element or the indicator light don't come on it sounds like a timer problem. I assume the oven has an electronic timer/clock. The timer must be in manual mode for the oven to work. If so, turn the oven ON. Then operate the clock/timer buttons to get it in the manual mode. Be patient. When the oven indicator light comes on it is in manual mode.
Please vote for me if this helps you.
Mar 05, 2011 • Ovens
I have a Tecnik TKC 8522 double oven - I can't get the bottom oven to heat up. When you turn it on the fan comes on, but the red light doesn't come on and the oven doesn't heat up.
If the red light does not come on, then this suggests that the oven thermostat or control switch is fault.
Even if the element was faulty, the red light shuld still come on.
4helpful
Gas in oven wont come on,burners and broiler ok, oven light comes on but oven won't come on,electrical connections ok, checked
this is a 2 burner oven with 2 ignitors . the bake ignitor is too weak to light the burner . replace it and the bake should work properly .. mm
1helpful
The oven wont light. Panel light comes on and
Attach a amp meter to the ignitor wire. If you read 3 amps or less,replace the ignitor. 3 amps or more replace the gas valve.
Sep 06, 2009 • Ovens
TOp Oven Light ..
if its a brand new unit (still in waranty) make the service call
Top Zanussi Ovens Experts
Paul Carew
ADMIN Andrew
ADMIN Andrew
Are you a Zanussi Oven Expert? Answer questions, earn points and help others
