Question about Citizen CLP-7201E Thermal Label Printer
Cut err printer stops printing after 1 label and gives a cut err on the displat panel
Posted by Wonker on
CheckitRight
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Citizen Master
  • 1,363 Answers
This is the manual for that printer go to the troubleshooting section page 24 of 26 there is not much info on it, just make sure that there is no paper or labels stuck somwhere  and tripping a sensor.
http://www.citizen.co.uk/pdf/1267uman.pdf
Posted on Oct 19, 2007
Soulvisitor
  • Citizen Master
  • 1,113 Answers
Paper Cutter Error - Guiliteen isnt sliding across the  rail it runs on properly  try lubing rail that cutter runs on with a LITTLE light oil , near front paper exit area
Printer will not advance to tear after print
I can't give the exact solution for this printer, however, I use the Epson POS thermal printer and here was our solution. In Windows 7 go to Devices and Printers. Click on Printer Properties. Then see if you see a tab that says Document Settings. Under that setting click on Paper Source. You should now see several options; I have mine set on Document(Feed, No Cut). There are other options but we prefer to tear ours off. You can chose Document(Feed, Cut) and it should advance then cut the paper for you.
Jul 10, 2014 | Datamax E-Class E-4205A Direct Thermal...
Printing on two labels
lets start with the basics.
Do a calibration of the label to the printer : -
1/ Turn off the power
2/Press and hold the feed key
3/ Turn on power and wait for the green feed light to flash twice.
4/ Release the feed key
5/ The printer should feed and print the configuration.
Now press the feed key and the label should feed and stop at the gap.
If this does not work , then let me know via this page.or contact me at the link below
trev
thermal labels printers co uk
Mar 06, 2014 | Zebra TLP 2824 Printer
Hi, I have DataMax ST3210, while printing it is instering a blank page randomly. Please advise
Check that your format is centered top and bottom on the stock, and that you have at least 1/8" quiet area top and bottom.
If you are printing on stock with an eye-mark, ensure that your print does not interfere with the area at the eye-mark. The printer will try to print the format, but if the eye-mark is in the way, even if the format is printed completely, will feed a blank label.
The also applys to standard die cut labels. with standard 1/8 die cut between labels
Nov 10, 2010 | Datamax DMX-ST-3210 Printer
Why does the label wrap around the bar every other label I print?
possible becouse the tear off position stop the gap on the wrong spot and wen you cut the label, left some label with glue expose, and wen you send other print, the printer make the backfeed and the label go stuck on the white rollar.
go througt the setings to TEAR OFF, and ajust to the front or back, untill hav the best gap/label rest possition and cut proply. don't forget to save (press setup button twice)
May 10, 2010 | Zebra Z4Mplus Label Printer
Everytime I print a label it stops short of the
This is an easy printer to fix since there is only one control button. Turn the printer off. Hold the green feed key down while turning the printer on; once the red light begins flashing, let go of the feed button. This will do three things: the printer will calibrate with the installed media, it will print a configuration label and the printer will go into dump mode. Press the feed key again. One more label will come out with with the words "Out of Dump" printed at the top. If the printer still fails to print, remove the ribbon and try the same procedure with direct thermal labels (UPS or FedEx). From there, consult the manual for more troubleshooting tips.
Jan 29, 2010 | Zebra Eltron TLP 2844 Thermal Label...
Zebra 140xiIIIPlus w/ attached cutter, cutter will not cut labels
For the cutter to work it is necessary to instruct the printer to "Use the cutter" This setting is usually accessible in the printer driver. Your label program interacts with the printer driver. Ensure that the cutter option is selected in the printer driver.
Apr 02, 2009 | Zebra 140XiIIIPlus Direct Thermal-Thermal...
After cutting the label the printer pulls media back about 1/2''
you can adjust the tear off position.
check if need the backfeed and what setting, if you need, you be able to stop doing that (no back feed) but can change the print on the lable.
Nov 20, 2008 | Zebra 105SL Thermal Label Printer
I-class cutting issues
You need to calibrate the printer using the instructions located in the manual. This should be in area 5.2 of the manual. If you don't have the manual you can download them at this address along with software updates and firmware updates.
http://www.datamaxcorp.com/software/i-class/
Label printers are always finicky. I have strtix printers where I work and they give off wacky errors too.
Sep 19, 2008 | Datamax DMX-I-4212 Label Printer
Printing die cut labels on Zebra Z4Mplus?
Set the printer to transmissivefrom reflective gap sensing.
This will cause the printer to loog for the inter-label gap to tell it where the top of the label is at.
Steve Weinrich
LazerTek, LLC
Dec 15, 2007 | Zebra Z4Mplus Label Printer
Feeding
Hello Sarunas,The problem ultimately, might lie with label feeding,Try Printer feeding,when u give the feed button, the labels should automatically, stop at the gap position, try printer calibration settings.
Hope fully, this should solve your problem
If you Any other queries, Related to barcode printer - Sales and Services.
Contact , Trridev Labelss Mfg Co Leading Labels Convertors In Tamil nadu
For more information visit our web page.
Jun 26, 2007 | Argox R-400 Thermal Printer
Citizen CLP-7201E Thermal Label Printer Logo
353 people viewed this question
Top Citizen Office Equipment & Supplies Experts
ksriramkrish
CheckitRight
CheckitRight
jay kaye
jay kaye
Are you a Citizen Office Equipment and Supply Expert? Answer questions, earn points and help others
