Question about Lexmark X85 All-In-One InkJet Printer
System error 000 carrier stall Presss power Key
I have a Lexmark X85 printer and every time i put it on it displays "system error" followed by "carrier stall" on the menu window - when i switch it off and put on it re-appears - and not allowing me to undertake any printing, scanning or copying. I have tried uninstalling and restalling - but no difference - no mention of this error in the lexmark manual. Don't know what else to do. I have a HP pavilion PC.
Would apprechiate your help greatly.
Alison
  • Lexmark Master
  • 1,113 Answers
Does carriage bash against side when power up? if so encoder strip is dirty or incorrectly seated... plastic strip inside printer lines on it 1cm wide, must sit vertical in slot on carriage
Might be somethin stopping print head from moving along rail, check ink carts are installed correctly and fully, check for paper squashed up left and right inside ends of printer. make sure carriage moves left and right
Try power up without cartridges and just black and just colour cart to eleminate cart faults does error change?
Posted on Oct 19, 2007
I just pressed the power button while holding the carriers to the right, then cycled power again.
Seems to have solved at least the "banging" issue.
Posted on Jan 07, 2008
6ya staff
SOURCE:
Used x4270 .no cd to download. list of printers does not inclued 4270. having problems with error 1200. took out old cartlidge and don't know how to put them back. have printer connected to computer...
Try to fix the 1200 error first. The error indicates that the cartridge carrier has stalled. Please refer to this article to fix the problem: 1200 Error Message on a Lexmark X4250/X4270/F4270 All-In-One. Once your cartridge carrier is functioning properl, re-insert your cartridges - How to Install Ink Cartridges In Lexmark X4200 Series AIO.
You can download the Lexmark X4270 driver by visiting the Lexmark website at http://bit.ly/gKXn7F. Select your operating system, download and execute the file. Follow the instructions on your computer screen.
For your scanning concern, especially when scanning documents, you will need the Lexmark OCR scan software to do the job. The scan software is available only on the installation disc that came with your printer. If you lost the disc, please contact Lexmark Technical Support Center for additional assistance.
Jun 14, 2011 | Lexmark X4270 All-In-One InkJet Printer
Error 1201
Problem Error 1201; Carrier stall; Printer stopped Solution The definition corresponding to this error message is this: "The print carrier stopped before all of the data was used." To resolve this issue, please do the following:
  1. Power the printer off.
  2. Remove all cables from the back of the printer.
  3. Reinsert the power cord.
  4. Switch the printer back on.
  5. Check the operator panel to see if the 1201 error message is displayed.
  6. If the error message returns, the printer could be defective. Contact Lexmark Customer Support for further troubleshooting and warranty options.
I’m happy to help further over the phone at https://www.6ya.com/expert/jonathan_828b54f422cbefdd
Nov 11, 2009 | Lexmark X4270 All-In-One InkJet Printer
Carrier Stall is the error
Please do the following..
To check the cartridge carrier:
  1. Unplug the printer.
  2. Move the cartridges to the left by hand and then take them out.
  3. Try to print without the cartridges in the carrier. Do you still receive a Carrier Stall error message?
  4. If not, put the cartridges back into the carrier and snap them in at the back. The message should no longer appear.
If the power light on the printer is not blinking, the error message may be caused by a communication error. Do the following:
  1. Remove any other devices attached to the USB/LPT port.
  2. Uninstall the Lexmark printer.
  3. Connect the printer directly to the PC and ensure that power is being supplied to the printer.
  4. Reinstall the printer.
Thank you....
Jan 26, 2009 | Lexmark X83 All-In-One InkJet Printer
I need to install a lexmark x85 printer scanner
If you need to download the software/driver, go here: http://downloads.lexmark.com/perl/downloads/downloads.cgi?ccs=229:1:0:0:0:0
Search for your printer (X85), then select your operating system and language. After you download the file, double-click it to launch it and follow the instructions on your computer screen.
I think you just need to install the software, but if you also need to set up the hardware, refer to the instructions in the Setup Sheet, which you can find here: http://www.lexmark.com/publications/pdfs/x85/en/setup.pdf
Follow the instructions on the Setup Sheet through step 13. At step 14, rather than inserting the CD, download and install the software as I've instructed above.
Oct 01, 2008 | Lexmark X85 All-In-One InkJet Printer
Lexmark x83 carrier stall
Hello there.
I have checked lexmark's website on troubleshooting this problem for you.
As per the link here we need to try the following steps to resolve the problem.
Carrier stall" Error and the Carrier Slams in the Printer ID:ENUS12078 null.gif null.gif null.gif
If the printer carrier is slamming into the side of the printer, please try the following:
  1. Disconnect the power supply from the back of the printer.
  2. Open the front cover of the printer where the cartridges are located.
  3. Look for two black bands that span from left to right (they should have one serrated side and one smooth side). Just above the black bands there is a transparent strip; this strip is called the Encoder strip.
  4. Flick this strip lightly with your finger to make sure that it is running smoothly from left to right. You may need to do this two or three times. CAUTION: Do not pull the strip!
  5. Close the front cover of the printer and reconnect the power supply.
  6. If the problem persists, you may need to contact Lexmark Technical Support.
Let us know how this goes and we can assist you futher, if the printer is damaged and is under a year old, lexmark may be able to repair or replace it for you.
Hope this helps.
Jun 16, 2008 | Lexmark X83 All-In-One InkJet Printer
http://support.lexmark.com/cgi-perl/knowledgebase.cgi?ccs=229:1:0:95:0:0&framed=&docid=ENUS22722&relevance=0
Use the above link to trouble shoot the problem.
Error: "Carrier Stall" ID:470
Feb 24, 2008 | Lexmark X83 All-In-One InkJet Printer
Printer stopped printing abruptly.
Did you try turning it off and disconnecting it from the power for a few hours so it will reset?
Feb 05, 2008 | Lexmark X85 All-In-One InkJet Printer
Will not print
Go to print. Prinrt comand comes up just fine. Press ok and nothing. Document pending is all I get. Printer seems to be ready but goes into power save waiting for next comand,
Jan 12, 2008 | Lexmark X83 All-In-One InkJet Printer
Printer does not connest to pc
I think "Cartridge short" is refering to a short circuit to the ink cartridges, remove them and clean the contacts, and try again, if this persists try replacing the cartridges
Aug 22, 2007 | Lexmark X85 All-In-One InkJet Printer
Lexmark X85 All-In-One InkJet Printer Logo
690 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Clive
Clive
Ekse
Thomas F. Schneider
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
