Question about HP DeskJet F380 All-In-One Printer
PRINTING PROBLEMJS I too am experiencing the same error code, orange flashing light with an "E". What does that all mean?
Posted by coppertopper on
  • Anonymous Nov 16, 2007
    not work
Thomas Christopher
    Genius:
  • 1,601 Answers
Colour and black ink cartridge flashing orange
They call that flash codes or error codes. please count
count how many times the lights flash, here is what they mean
Alarm / Power light flashes orange 7 times consecutively (ink cartridge installed incorrectly)
Alarm / Power light flashes orange 5 times consecutively (Print Head Error)
Alarm / Power light flashes orange 4 times consecutively (Out of Ink Error)
Alarm / Power light flashes orange 3 times consecutively (Paper Jam Error / Cover Error)
Alarm / Power light flashes orange 2 times consecutively (Load Paper / Paper Feed Error)
Alarm / Power light flashes orange 16 times consecutively (This FINE Cartridge has previously been used)
Alarm / Power light flashes orange 15 times consecutively (FINE cartridge not recognized)
Oct 05, 2014 | Canon PIXMA MP495 InkJet Printer
Orange ink light keeps flashing
HP Desk Jet 940c orange light flashing
Oct 01, 2014 | HP DeskJet 940c InkJet Printer
My orange light next to the yellow dot blinking and the printer will not print
When the orange light is solid it means the cartridge is low and you can still print. But when the orange light is flashing it means the cartridge is empty and the printer stops printing. To continue printing you will need to replace the yellow toner cartridge. The part numbers are Q3972 regular yield or Q3962A high yield.
Jun 23, 2010 | HP LaserJet 2550n Printer
Green light flashes, will not print. Checked all
Hi can gave you the truble codes
  • Light Orange - 2 beeps: Remove any paper jammed
  • Light Orange - 3 beeps: Remove any paper jammed
  • Light Orange - 4 beeps: Add Ink
  • Light Orange - 5 beeps: Re-install cartridge or replace it
  • Light Orange - 6 beeps: Re-install cartridge or replace it
  • Light Orange - 7 beeps: Re-install cartridge or replace it
  • Light Orange - 8 beeps: Waste is almost full
  • Flash 1 x Orange - 10 beeps (error code 6100): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 2 x Orange - 10 beeps (error code 6300): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 3 x Orange - 10 beeps (error code 6800): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 4 x Orange - 10 beeps (error code 5100): Make sure nothing is blocking the cartridge movement, if not requires service.
  • Flash 5 x Orange - 10 beeps (error code 5400): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 6 x Orange - 10 beeps (error code 5B00): Waste full (make a reset)
  • Flash 7 x Orange - 10 beeps (error code 5200): Replace the BJ Cartridge(Printhead)
  • Flash 8 x Orange - 10 beeps (error code 5200): Replace the BJ Cartridge(Printhead)
  • Flash 9 x Orange - 10 beeps (error code 5600): Replace the BJ Cartridge(Printhead) or reinstall it
  • Feb 01, 2010 | Canon BJC 4400 InkJet Printer
    Both lights are blinking and will not print
    they call that flash codes or error codes. please count
    Sep 20, 2009 | Canon Pixma iP2600 Photo InkJet Printer
    Problem on a canon 3100
    The Power Light Flashes Orange - Error Codes When an error occurs, the power light flashes orange. The number of orange flashes followed by a long green flash indicates the cause of the problem.
    Two orange flashes: Out of paper, paper jam, or paper feed error
    If no paper is loaded in the auto sheet feeder, or if the paper is not loaded correctly, set the paper correctly and press the Resume button on the printer to continue printing.
    Three orange flashes: Paper jam
    If paper has jammed in the printer, carefully remove the jam and press the Resume button to continue printing.
    Four orange flashes: A tank inside the BJ cartridge (print head) is out of ink
    Replace the empty BJ tank and press the Resume button to continue printing.
    Five orange flashes: BJ cartridge is not installed properly
    Remove and reseat the cartridge correctly. Make sure the orange protective cap and tape have been removed. Make sure the blue locking lever is locked down securely.
    Six orange flashes: BJ cartridge (printhead) is not installed
    Seven orange flashes: BJ cartridge (printhead) is defective
    Remove the BJ cartridge and check that the contacts on the cartridge and cartridge holder are clean. Make sure the orange protective cap and tape have been removed and reinstall the cartridge. If the error occurs again after you resume operation, you may need to replace the BJ cartridge.
    Eight orange flashes: Waste ink absorber almost full
    The printer has a built-in waste ink absorber to hold the ink that is consumed during print head cleaning. This error indicates that the waste ink absorber is nearly full. Press the Resume button to skip the error so you can continue printing.
    The POWER light flashes orange and green alternately: Service error
    A service error means the printer requires the attention of a qualified technician. Count the number of flashes. (You may be asked this information.)
    Feb 02, 2009 | Canon PIXMA MP150 All-In-One InkJet...
    Not printing from one computer
    If the CHARGE/ERROR light is remain on orange with beep 1 times, it mean the paper is not properly set in the feed slot, just remove the paper and reload it properly.
    If the POWER light is flashing green, that mean your print job is not finish yet.
    YBC (/\)
    Dec 15, 2008 | Canon BJC 55 InkJet Printer
    BJC55 Printer not printing
    There are some possibilities due to the above phenomena. Let's discuss about it:
    1) If the POWER light is flashing green, then your printer is now warming up or performing maintenance procedure (replacing cartridge/tank) or cleaning print head, just wait a few seconds till the light stop flash. Also if the last page of a print job not done, this POWER light flashing green.
    2) If the CHARGE/ERROR light is flashing orange with beep 3 times, it mean your cartridge need to be install (especially the 1st time turn on printer) or cartridge being replaced, just install the cartridge and press RESUME to continue.
    3) If both POWER light is flashing green and CHARGE/ERROR light is flashing orange with beep 3 times, then your printer may facing a very serious error and maybe need a replacement.
    Hope these help.
    YBC (/\)
    Nov 01, 2008 | Canon BJC 55 InkJet Printer
    Printer ripair
    The BJC 3000 will flash two different colored lights in a pattern to signal several different errors. From the documentation I have the two colors are orange and green, could those be the colors you see? At any rate here is the code: Two orange flashes: Out of paper, paper jam, or paper feed error. If no paper is loaded in the auto sheet feeder, or if the paper is not loaded correctly, set the paper correctly and press the Resume button on the printer to continue printing. Three orange flashes: Paper jam. If paper has jammed in the printer, carefully remove the jam and press the Resume button to continue printing. Four orange flashes: A tank inside the BJ cartridge (print head) is out of ink. Replace the empty BJ tank and press the Resume button to continue printing. Five orange flashes: BJ cartridge is not installed properly. Remove and reseat the cartridge correctly. Make sure the orange protective cap and tape have been removed. Make sure the blue locking lever is locked down securely. Six orange flashes: BJ cartridge (printhead) is not installed. Remove and reseat the cartridge correctly. Make sure the orange protective cap and tape have been removed. Make sure the blue locking lever is locked down securely. Seven orange flashes: BJ cartridge (printhead) is defective. Remove the BJ cartridge and check that the contacts on the cartridge and cartridge holder are clean. Make sure the orange protective cap and tape have been removed and reinstall the cartridge. If the error occurs again after you resume operation, you may need to replace the BJ cartridge. Eight orange flashes: Waste ink absorber almost full. The printer has a built-in waste ink absorber to hold the ink that is consumed during print head cleaning. This error indicates that the waste ink absorber is nearly full. Press the Resume button to skip the error so you can continue printing. The POWER light flashes orange and green alternately: Service error. A service error means the printer requires the attention of a qualified technician. If you have any more questions let us know otherwise please don't forget to rate this post.
    Feb 20, 2007 | Canon BJC 3000 InkJet Printer
    HP DeskJet F380 All-In-One Printer Logo
    303 people viewed this question
    Ekse
    Thomas F. Schneider
