Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
1996 road king.
Every once in a while the rear cyl. stops firing for maybe 20 -30 seconds ,i could be in the middle of a ride or on start up it starts on one cyl. then begins firing again.i pulled the wire off the plug to check for spark and had no spark .
Posted by deuce8888 on
Tom Diffin
    Habit-Forming:
  • 95 Answers
Hey check the plug and the wire, if it is fireing intermintly on one cylnd it should be suspect, i think sparkplug, your coil supplies both plugs spark at the same time(dual fire) unless the ign unit (ign and coil) has been switched out to a single fire in this case it could be the coil
Posted on Jan 11, 2009
Anonymous
    Scholar:
  • 150 Answers
Coil?
Posted on Apr 24, 2008
Harley troubleshooting
bike is overheating check temperatur of oil make sure right oil level is in it maybe rear piston need replaceing maybe vapor lock remove fuel cap and start bike did this`remove campa if steel runs replace gas cap or bad valves might do it happen over
May 25, 2014 | 2004 Harley Davidson Road King Custom
What could promlem be
o
un do panel check electrical conection on back it just plugs in
May 22, 2014 | 2005 Harley Davidson FLHRS - FLHRSI Road...
Harley problems
the brake is damaged or the engine is old
May 22, 2014 | 2003 Harley Davidson FLHR Road king
My 2006 road king Harley won't start after riding over a curb
You didn't describe the "click"
A series of rapid clicks means a low battery, or a bad (usually ground) connection, like if you crunched/abraded a wire along the lower frame when you drive over a curb.
A single, loud click indicates its a bad starter relay, about a $12 part:
http://www.ebay.com/itm/Starter-Brake-Relay-Switch-Harley-ROAD-KING-1991-2011-repl-OEM-31504-91A-/390652043658?pt=Motorcycles_Parts_Accessories&fits=Year%3A2006%7CModel%3ARoad+King%7CMake%3AHarley-Davidson&hash=item5af4ad218a&vxp=mtr
Nov 25, 2012 | 2006 Harley Davidson FLHR Road king
Bike died going 75 mph and will not start. Has not fire
The owners manual for my 2008 Road King Classic says to down shift from 6th to 5th at about 60 MPH, not 75 MPH.
Jul 05, 2012 | 2008 Harley Davidson FLHRC Road King...
2003 HD Road King - starts fine, idle normal. Once it is warm, idles at 2000 rpm. Does not come back down, even after riding for an hour or two. Only idles normal when cold. Help??
If you bike is equipped with a carburetor, the idle stop screw is located at the top of the carb on the right side. Counterclockwise turn slows the idle speed.
If you bike is fuel injected, a dealer or shop will have to set the idle speed electronically.
Good Luck
Steve
Sep 16, 2010 | 2003 Harley Davidson FLHRCI Road King...
I have a 1993 dyna harley davidson with a1340 ss motor. i will ride for a little and the motor will miss fire .pull over two the side and i can remove the coil wire to rear cyls no spark replaced coil...
ok buddy are you running the correct heat range plug as when wrong pluges get hot they foul and when the cool the come back to life so try that 1st also what colour are the plugs when you pull them out get back to me
Sep 15, 2009 | 2000 Harley Davidson FXDWG Dyna Wide Glide
The rear cyclender stop's firing when bike is hot
You have a bad rear coil, or if the bike has a signle coil the rear cyl section of it is bad.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
Sep 15, 2009 | 1986 Honda VT 1100 C
2006 Harley Davidson FLHR Road King
yes you should start it at least once weekly to maintain battery and keep engine lubricated, also it keeps fuel flowing through the bike. but dont just start up then switch off, make sure you get it up to normal operating temprature, this keeps moisture out of the engine oil.
Jan 28, 2009 | 2006 Harley Davidson FLHR Road king
Lands Phones Logo
159 people viewed this question
Top Harley Davidson Lands Phones Experts
Sheldon Dedek
Mai Lor
FastHarley
FastHarley
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
