Question about SanDisk Sansa m240 MP3 Player
I can't delete the songs and the computer says my mp3 is "full"
Ok so i tried to delete all the songs from my mp3 player the other day. but 97 songs out of the 120 songs or so are still in the mp3, and whenever i try to delete them from the computer, it doesn't work. then, when i try to add new songs into it, it tells me that i have to delete some un-needed files to get enough memory space to put in the new songs. i don't know what to do. I've never had this problem before.. >_<"
Posted by ishotpamela on
Anonymous
  • 27 Answers
You need to be in MSC mode to do deletion in My Computer; put in MSC mode in the settings menu under USB, then plug in, go to My Computer and open it as a drive, go to Music folder and delete by rightclicking on songs and choosing delete. You can also format the player by rightclicking on the drive letter of the sansa and choosing format. If you are deleting from a program like Rhapsody (ugh) or windows media player, you will get a lot of issues and not all will delete. Stick with My Computer in MSC. Also as a side note, make sure you have all file folders showing including hidden files in the tools menu in My Computer
Posted on Oct 21, 2007
500 songs, all gone but wont allow other downloads, "too full"
Re: 500 songs, all gone but wont allow other downloads, "to full"
Use settings "format" on mp3 player. This will delete any hidden files. If you download in one format (say like Ubuntu) and delete them under another (say Windows), files can remain in *.trash which is hidden. To avoid this in the future, try deleting with shift+del as it will bypass the trash folder.
Apr 17, 2015 | SanDisk Sansa Clip MP3 Player
I deleted recordings then tried to record new voice sentances but the player says memory is full?
Hi yomgyo...
Try deleting the recordings this way...
BIG WARNING: DO NOT DELETE THE FILES NEEDED TO OPERATE YOUR MP3 PLAYER.
Hook up your mp3 player to your computer
Go to your desktop and double left click on "My Computer"
When it opens you will see listing that says "Devices with Removal Storage" your mp3 player should be listed there.
Right click on your mp3 player, and a window will open, right click on "Open" and now your files/songs should be visible.
Hold the left click down and drag it across all the files/songs that you do not want this will highlight the files/songs you do not want, release,right click and then click on "Delete"
Now you mp3 player should be clear of the files/songs you do not want.
ONE MORE BIG WARNING: BE CAREFUL AND DO NOT DELETE THE FILES NEEDED TO OPERATE YOUR MP3 PLAYER.
Please take time to rate me thumbs up
Sep 26, 2011 | Philips GoGear ViBE Digital Media Player
Full can not delete
Hi parrishkaren...
Try deleting your unwanted files this way
Deleting Files,Pictures,Videos,Audio Books, Apps,etc. from MP3 Player/Ipod
Aug 28, 2011 | RCA Audio Players & Recorders
Ok so im trying to delete all the music from my mp3 player ( sandisk m240) when i connect the usb to the computer and open the file it shows nothing, however when using just the device there is still 52...
Deleting Files,Pictures,Videos,Audio Books, etc. from MP3 Player
release, right click and then click on "Delete"
Now your mp3 player should be clear of the files/songs you do not want.
Be careful and do not delete files needed to operate your MP3 player.
Please rate me
Dec 06, 2010 | SanDisk Sansa m240 MP3 Player
My mp3 player won't turn on. the only message its giving me is, that its to full and i need to delete songs. how do I do that because it won"t turn on enought for me to delete songs?
Try this solution...
Connect/Hook up your mp3 player to your computer
BE CAREFUL and do not delete files needed to operate your MP3 player.
Please rate me
Aug 22, 2010 | SanDisk Sansa m230 MP3 Player
Windows mEDIA PLAYER SAYs my sansae260 is full, but device won't sync. It says no song. I tried to reset, but still says no song
change the usb modes also....MSC will allow you to see the expansion card ( 2Gig E200 series 4gig Fuze) mtp won't.....MTP shows you your music folder in the media folder thats where you put your music plus expansion.....
Delete songs and Format (Helps with trying to delete BAD TRACKS and folders that will not delete full memory(Some ripped CD folders).. Go to my computer scroll to sansa or your MP3 player and open the music folder and open each sub folder and delete Songs manually then delete the folders themselves then format a couple of times hope this works
Jun 21, 2010 | SanDisk Sansa e260 MP3 Player
Ok so I have a coby mp3 player and the songs are
Ok there are 2 Solutions that can fix this:
First:
1. Plug the MP3 player into the USB port. Open Windows Media Player, which will recognize that the device is plugged in and register under the "Sync" tab at the top.
2. Click on the "Sync" tab and and the library that is on your MP3 player will be displayed.
3. You can select individual songs or albums for deletion. Simply right click on the song or album to be deleted and scroll down to the "Delete" option.
4. After selecting "Delete," another window will come up which says "Are you sure you want to delete [title of song]?" There are two options at this point--you can delete from the library only or from the library and your computer. Select the one or the other and click
"OK." The song will be deleted. The change will be displayed within the library onscreen.
5. When you unplug the player from the port, the library will adjust the files to reflect the change. The player will say "configuring library" or some other message to that effect. Once this has finished, the main screen will be displayed. Depending on the model of the MP3 player, there may be a message stating "library updated."
Or if that does not work try this:
Try reflashing the firmware for your device you can find the latest firmware and flashing utilities from the Coby's website. Make sure that you back your music up first because when you do this you are setting it back to factory settings.
Oct 03, 2009 | Coby MPC-848 MP3 Player
My mp3 is messed up
once the mp3 player is connected try performing a format on the mp3 player via the My computer .then try and reload.
Apr 11, 2008 | Coby MP-C858 MP3 Player
Deleting songs
Hi the best way to remove songs off mp3 player is connect it to your comp then goto my computer and open up the mp3 file might say removable disk ok select this then it will list all the songs on the mp3 player now if you right click on the songs you want to delete it will delete them.
If you cant use bigpond on your mp3 try limewire this site will give you any song you can think of for free just download them as you would normally then transfer to mp3 if the songs dont play on your mp3 then you need to convert the song format to mp3 just use search engine and type convert music file
This will list all the sites that do this and most of them a free.
Let me know how you get on or if you need further help ok
Feb 15, 2008 | Samsung YP-U3 MP3 Player
SanDisk Sansa m240 MP3 Player Logo
110 people viewed this question
Top SanDisk Audio Players & Recorders Experts
ThaMp3Doctor
ThaMp3Doctor
Muntejaya Ginting
Muntejaya Ginting
aliasger yq
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
