Question about Coby DVD-207 Portable DVD Player
Coby dvd player
IM HAVING A PROBLEM WITH A COBY DVD PLAYER. WHEN YOU PUT THE DVD IN AND PRESS THE POWER/STANDBY BUTTON IT CHANGES FROM RED TO GREEN. THE DVD STARTS TURNING AND THE TV SCREEN READS LOADING. THEN YOU WILL GET A BLACK SCREEN LIKE THE DVD WAS STARTING TO PLAY AND THEN STOPS AND THE RED STANDBY LIGHT COMES ON AND THE DVD STOPS TURNING. tHIS JUST STARTED RECENTLY. EVEN STORE BOUGHT DVD'S THAT USED TO PLAY WON'T. THERE IS NO EXPLANATION IN THE MANUAL ON THIS. I NEED TO FIND OUT WHAT I CAN DO TO GET IT WORKING. THANKS.
Posted by JIM WEBB on
  • JIM WEBB Dec 11, 2007
    Thanks , I took it back for exchange . Thanks Jim
james kilgore
    Sergeant:
    Champion:
  • 362 Answers
Do you see the laser light come on when the disk spins if not it has probably lost power or failed, if so sometimes the laser head gets moved to close to the drive mechanism and the motor cant pull it out. i have found several of these that had this problem.
Posted on Dec 10, 2007
  • james kilgore
    james kilgore Dec 10, 2007
    just pull, it away from the center a little bit and see if that works.
I have onida dvd modal no. is dfx-2000. it having
Plz change ur dvd player bcz it was 2 old
Jul 18, 2009 | Televison & Video
I have a denon 1720 dvd player. When you press the power button it comes on for 3 seconds then the power button turns back red and powers off. If you press the eject button within the 3 seconds the tray...
same equql problem....?????
Can you help?
i have a denon 1720 dvd player. When you press the power button it comes on for 3 seconds then the power button turns back red and powers off. If you press the eject button within the 3 seconds the tray opens and the power button stays green. As soon as you close the tray the power agin goes to red. i have a denon 1720 dvd player. When you press the power button it comes on for 3 seconds then the power button turns back red and powers off. If you press the eject button within the 3 seconds the tray opens and the power button stays green. As soon as you close the tray the power agin goes to red. Can you help? thanks thanks
Dec 21, 2008 | Televison & Video
Power light is yellow when it should be green
sound like your main board is bad or it has a short to ground
remove it and put it back if same then change it
Nov 16, 2008 | Coby DVD-514 DVD Player
Stand by light on but thats all
if it does nothing when you push the standby button to make it play the most common problem is the power standby sw is bad. do you know how to use a miltimeter if so test the voltage through the swithc when you press the button.
Oct 14, 2007 | Coby DVD-207 Portable DVD Player
The unit won't turn on
We have exact same issue. My husband called Coby. They said if the red light is on & won't go green, the system is junk. Can return to the store or them. We are off to buy a new player and it won't be a Coby!
Jun 27, 2007 | Coby DVD-209
Region
coby 514.
power up. put disc in tray
press set up
then vol+ vol- vol+ vol-
code appears in top right 1
change altering left and right buttons
leave on 255 multi region (all discs)
press set up.
Coby DVD-514M
Turn unit on with remote
NO DVD in the tray (mine was closed, but opened might work)
Press TITLE then 1 then 9
Gray box will appear in the center of the screen with number 1 in the middle
Using up/down arrows change to desired region (0 for REGION FREE)
Jun 12, 2007 | Coby DVD-514 DVD Player
Philips dvd player not working
Im sorry to tell ya that you did all the things I would have suggested, so it sounds like a system control problem or a power supply problem, and if its a good machine then maybe its worth you having a service person look at it?? Most dvd units are not worth it these days, unless there combos or recorders.. Sorry couldnt be of more help.
Jun 05, 2006 | Philips DVP630 DVD Player
Coby DVD-207 Portable DVD Player Logo
395 people viewed this question
Top Coby Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Ekse
Are you a Coby Televison and Video Expert? Answer questions, earn points and help others
