Question about Pentax Optio S4i Digital Camera
Switching camera software to wife's computer
I installed ACDC for Pentax to my wife's PC; when I turn on the camera, I don't get the dialog box with "copy images to hard drive & launch ACDC" message.
When I manually open ACDC I don't see any way to communicate with the camera!
My wife's PC runs under Windows 98;  when I put the CD in the d drive, the system seemed to go through the setup process OK.
Posted by camera67 on
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Pentax Master
  • 102,366 Answers
Consider NOT connecting your camera to your wife's computer.
The best way to download pictures from your camera to a computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use ACDSee or any other photo cataloging program.
Posted on Aug 31, 2012
5 Related Answers
Anonymous
SOURCE: Windows Vista!!!
nicklaus87 you are right. It works now. Thanks a lot!
Posted on Mar 25, 2008
Anonymous
SOURCE: Connecting OPtio S4i to PC
After formatting my PC to upgrade it I've been unable to install the USB driver software to save pictures from my Tentax OPtio S4i to my PC.
My computer isn't recognising my camera when I plug it into the USB port.
When I've tried to install the Driver using the disk I got with my camera, at the stage where it asks me to MODIFY REPAIR or REMOVE, the software I get the following showing up on display boxes:
Posted on Jul 12, 2008
Anonymous
SOURCE: Pentax S5i
I have lost my cd for my optio s5i pentax camera and have a new laptop how can I get another cd or download software so I can transfer photos onto my laptop
Posted on Dec 06, 2008
Anonymous
SOURCE: need a driver for vista/ pentax optio 60
I need webcam driver for vista.. pentax optio 60 my e-mail [email protected]
Posted on Feb 12, 2009
Anonymous
  • 79 Answers
SOURCE: Have windows vista on new computer, no longer have CD ROm for camera. I am unable to access the software when I connect it through USB port???
The camera should be detected as a drive when the camera is connected via USB. Does it? You should be able to connect and copy your photos straight out like a USB drive.
Posted on Apr 26, 2009
I do not have a Pentax Cd-Rom SW-SW58 to install on my PC.
You don't need any special software.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or, despite what I said first, you can use any photo cataloging program such as Picasa.
Jul 22, 2011 | Pentax Optio M20 Digital Camera
I have a pentax optio m20. I lost the installation cd. Can I install the software on line?
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or, despite what said first, you can use any photo cataloging program such as Picasa.
Aug 21, 2010 | Pentax Optio M20 Digital Camera
Is there a driver for Optio 230 camera to hook up to Windows 7?
Okay, in my comment I reported that I had this problem. Now I have discovered a solution. A little deception is in order!
The way to get this piece of legacy hardware working on modern PC's is to convince the PC that your camera is something with which it can communicate. After plugging in your Pentax 230, open your Control Panel and type "Device Manager" into the search box. (There are other ways to access the Device Manager, but this seems to be the easiest to describe here.) With the search complete, click "Device manager" (You'll probably see a few instances of Device Manager, any of them will work.)
In the device tree, the Pentax should stick out like a sore thumb with a little yellow exclamation point tag thingy on it. Double click the Pentax in the list and you should see a dialog box that says something to the effect of, "The drivers for this device are not installed." Click the button "Update Driver."
In the wizard that pops up click: Browse my computer... -> Let me pick from a list... -> Universal Serial Bus Controllers (in the list) -> Next (button) -> Manufacturer: SanDisk Corporation -> Model: SanDisk USB ImageMate Multimedia Card Reader -> Next (button).
The computer's nit-nanny utility will pop up to warn you that this can do bad things, and it may be right, but I experienced no problems when I tried this on two computers (Side note: DO NOT tell the computer this is a disk drive, bad things do happen then!). Click "Yes" that you do want to continue installing this driver.
The computer will begin to churn and will install the driver for the SanDisk Multimedia Card Reader, and your camera should appear as a removable storage device in the "Computer" window.
You're welcome.
Nov 12, 2009 | Pentax Optio 230 Digital Camera
Can't install software for Pentax OptioZ10
If software is a problem why not just buy a USB to SD card adapter, and plug your SD card directly into macbook - about $10
Mar 08, 2009 | Pentax Optio Z10 Digital Camera
I can't load software
You don't need a driver.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Sep 22, 2008 | Pentax Optio E40 Digital Camera
Pentax Optio E10
You don't need any software.
Jun 25, 2008 | Pentax Optio E10 Digital Camera
Optio S4i will not turn on?
Your problem is part of the dreaded A90 error code these cameras get. My camera had this last year and updated firmware cured it till this month when my wife let the battery go dead and the problem returned, but firmware update won't fix it this time around.Go to Pentax site and download new firmware for camera. Follow instructions that come from Pentax on the download to install software. Its pretty easy. These are cheap cameras as far as Pentax is concerned. They only work for about 2 years, based on other users and my experience. Good luck
Jan 25, 2008 | Pentax Optio S4i Digital Camera
Aug 19, 2007 | Pentax Optio S4i Digital Camera
Installing digital camera drivers from Nikon View 5 or 6 CD on Windows OS
This document assumes that your computer did not recognize your digital camera after you have installed Nikon View version 5 or version 6 (5/6) using "Easy Install" and then restarted your computer. Nikon View 5/6 compatibility: Windows 98 SE Windows ME Windows 2000 Windows XP Home Edition/Professional Note: Log on as Computer Administrator when installing drivers on Windows XP Home Edition/Professional or as Administrator when installing drivers on Windows 2000 Professional. Cameras that are not supported by Nikon View 5/6 Nikon View 5/6 does not support direct connection of COOLPIX 950, 910, 900, 800 or 700 digital cameras however it will support a Compact Flash card reader which contains images taken with these cameras. Before installation - Before installing Nikon device drivers, make sure the camera is disconnected from the computer. If the Device Wizard launches when you connect a camera, click Cancel to exit the Wizard. - You have turned off any virus-checking software that may be running. - You have exited all other applications. Procedure for driver installation First DISCONNECT THE CAMERA FROM THE COMPUTER and follow the instructions below. Insert the Nikon View CD into the CD-ROM drive, the Select Language dialog box appears. Select a language Select the language of your choice from the pull-down menu. After you select a language, click Next to display the Install Center window. Custom Install Step 1: Select the software to be installed. Select the programs you want to install from the list in the Custom Install tab. Step 2: Install the driver Choose the camera driver you wish to install and click Install. If you have chosen more than one program, the programs are installed in the order of display. - PTP Drivers Select this check box to install PTP drivers. This check box is only displayed if you are using Windows XP. - COOLPIX Camera Drivers (all models except 990 and 880) Select this check box to install the driver for COOLPIX series cameras (excluding 990/880). This check box only appears if you are using Windows 98 Second Edition. - Drivers for COOLPIX 990 and 880 Select this check box to install the drivers for the COOLPIX 990/880 - Drivers for D1 series cameras Select this check box to install the drivers for the D1/D1X/D1H cameras. Install PTP Driver (Windows XP only) Check that the camera is disconnected If you selected the PTP Driver, the installation of the driver will start. The Setup dialog box below is displayed, asking you to confirm that a camera is not connected to your computer. Make sure a camera is not connected, and click OK to begin installation. Windows 98 SE If you are using Windows 98 SE, drivers for all COOLPIX cameras (all models except 990 and 880) will be installed if selected. The dialog box shown right will be displayed. Click OK to continue. When you install the device driver, the dialog box shown below may be displaye
Aug 30, 2005 | Nikon Coolpix 3200 Digital Camera
Aug 29, 2005 | Nikon Coolpix 5700 Digital Camera
Pentax Optio S4i Digital Camera Logo
54 people viewed this question
Top Pentax Cameras Experts
Muntejaya Ginting
Muntejaya Ginting
Ekse
halotheracer
halotheracer
Are you a Pentax Camera Expert? Answer questions, earn points and help others
