How do I reset the change oil warning light on an 02 Suburban?
Look in you owners manual if you have one, It should tell you there.
If not call one of your local jiffy lube or minit lube, they should be able to tell you how to reset it.
Good luck
Disconnect the battery terminals, touch the two cables together for 12 seconds, then reconnect cables to battery posts. start engine, oil change light should be reset.
Simple way, disconnect the negative from your battery. Down fall is you lose all your presets and everything else, and make sure if you have a security device on your vehicle/key ring...make sure that is near you when you reconnect. Leave it disconnected for about 2 minutes or so.
