Question about Dell Dimension 4100 (-JM0TB01) PC Desktop
No power to tower
Checked fuse; swapped power cable with that used to connect to screen.  LED lights do not come on on front of tower.  When turning on the main power, there is a "clunking" noise that comes from the area of the power supply unit.  Have taken off the cover and checked the seating of all cables.
Help!
Kind regards
Nigel Nelson
  • NigelN Oct 19, 2007
    The power supply and the motherboard are shot.  the machine is 7 years old, so I shouldn;y be too surprised/disappointed.
    Thanks for the advice anyway.
  • 65 Answers
Try replacing the power supply.
Posted on Oct 19, 2007
6ya staff
SOURCE:
Purchased a used compaq S5300NX desktop with monitor,keyboard,mouse, and other devices.First thing I did,was hookup the tower to my monitor,keyboard,mouse and internet connection. turned it on and it...
If there is noise "beep" then it has RAM issue/RAM port. If is not noising then it has motherboard issue. I guess you need to take it to the technician and ask him to fix or replace it.
Nov 04, 2013 | HP Compaq Presario S5300NX (DM174A#ABA) PC...
Computer was shut down and power turned off. When i restarted the system the printer and monitor came on but the tower is not getting any power. cords are all plugged in and checked outlet works. seems...
If the outlet is good and the cord is good, you may have indeed blown the fuse in the power supply. That is the only fuse. The fuse in the power supply is usually "hard-wired". Not necessarily, but usually. You would need someone familiar with them to replace it if it is blown.
Some computers have a green LED on the back of the computer near the power cord. Do you have one? Is it on? You can also look to see if the small green LED is on on the motherboard.
If you get no indication of power, the power supply is probably gone. A new on is about $25 and pretty simple to replace.
Hope this helps.
Thanks for using Fixya.
Feb 20, 2011 | HP Pavilion a705w PC Desktop
When my computer is turned on green light is not display and the screen does not display anything than what should i do ??
If the green light is not glowing in the tower check the status of the light on the back of the tower where the power cable goes.
If there is no light in the back of the tower than it might be an issue with the wall jack or surge protector so try connecting the power cable to a different jack and see what happens. if it remains the same than try with a different power cable and check.
If the light is glowing on the back of the tower but there is no light in the front than it may happen the power supply of the pc might have failed. try to open the tower reseat the RAM cards, reseat the Harddrive cables as wells as try to reseat the cables of the power supply. if the light on the back flickers and goes away than it might be a faulty motherboard. So do a Motherboard test by turning on the pc without the RAM cards, if the motherboard is fine you will hear beeping noise if not than motherboard is faulty.
Aug 02, 2010 | Smart Modular SV3170A
Screen will not come on hard drive light no light checked power supply is ok
Things to check:
  1. Power led on the front of the tower, it should be solid green when on. Flashing Amber is generally an indication of a bad power supply inside the tower
  2. Power LED Solid AMBER indicates system is not finishing the power on self test (POST) and you remove all connections from the tower except power and try turning on again. If no change, remove all PCI and PCI-E cards from system, try again, no change replace motherboard.
  3. On the back of the tower are 4 diagnostic LEDs near the ps2 ports marked ABCD, after the POST, during a normal boot the will flash in several sequences and with boot is finished all 4 should be green. If they stop an a different pattern, then that indicates a failure Yellow Yellow Green Green indicate bad RAM for example
  4. If the LEDs on front and back are Green then the system appears to be booting but the monitor display is not functional
Feb 05, 2010 | Dell Dimension 4600 PC Desktop
I turn on the computer and the screen will not come on.
check the power cable, swap it with the cpu tower cable if possible. try other power outlets. and also try connecting it on a different system or connect a different monitor to your system and that will determine if your monitor is faulty. hope it'll help.
Dec 03, 2009 | Computers & Internet
My Dell Dimension 4600 will not turn on. Steady Amber Light
Disconnect the Power cable / A/c adapter/Battery from computer.
Disconnect External peripherials.
Hold down the power button on the computer for 10 seconds.
Reconnect the power cable or A/c adapter and battery or the computer
Try to turn on the computer
check for Led's on the computer
If still no display ,shut down the computer,disconnect power cable.
Open the computer tower,remove memory modules,reconnect power cable and turn on the computer.If you get a beeping sound after turning on you should be getting beeping sound suggesting the mother board is not bad.Turn on the computer and disconnect power cable from computer.
Reseat 1 memory at a time if you have 2 memory module or if single memory module reseat in different memory slot,swap memory module.
Reconnect the power cable and turn on the computer if it boots to desktop possible issue with 1 of the memory module.
Disconnect the harddrive ide cable from the harddrive .Turn on the computer.
If still unable to power on .Shutdown the computer and disconnect power cable.Remove video card,sound card ,modem card if any .Connect just the vga cable from monitor to the integrated video port.
Connect power cable and turn on the computer.
If computer turns on possible issue with one of PCI or PCI express card.
If still unable to power on.Disconnect the power connector pin from the motherboard and reconnect it back.Turn on the computer check power power led on motherboard,also check if the processor fan is spinning. if no go then issue with motherboard.
Sep 03, 2009 | Dell Dimension 4600 PC Desktop
WHEN I PRESS POWER BUTTON NOTHING HAPPENS
If still unable to power on.Disconnect the power connector pin from the motherboard and reconnect it back.Turn on the computer check power power led on motherboard,also check if the processor fan is spinning. if no go then issue with motherboard. GOOD Luck.!!
Aug 27, 2009 | Insignia D400a PC Desktop
Asus p5b-mx motherboard no display no beep
when ever you are getting the beep messages after you remove the ram card and connecting the tower to the power cord it shows that mother board is functiong normally so no problem with the mother board .try this steps so that it may resolve the issue.
1. No Boot:
. Check the cables
. Check with the socket on the wall as well as surge protector
. Swap the power cable with the monitor
. Power drain ( after removing all the cables press and hold the power button on the tower for 10-15 sec and the re-insert the power cable and connect the monitor and check)
Monitor does not power on
Check with the power cable
Check with the cable from the monitor
Swap the cable
Power drain
If the cust gets the power on the monitor and even the tower but still if he cannot view anything on the screen
Dec 11, 2008 | E-Machines eMachines Desktop PC
VPR Matrix 226R-Blank screen when powered up,LED in front blinks
Not a power problem. Could a memory problem try changing the memory (DDR SDRAM), see if monitor comes on and if the system does a POST (power on self test) That should indacate any further problems if any.
Dec 06, 2008 | Matrix 226R (VPR226R) PC Desktop
Emachine with XP home edition doesn't start
Hi hearalso, down to the basic's. Replace power cord.
No help there than, remove the case's side panel to expose the motherboard. (Normally it is the left side panel while facing the front of the PC.)
Look closely for a small (green in color) led light. The power cord must be connected to the PC & connected to you're power strip but do not press the power on button on the PC.
The green led tell's you the board is receiving 5volts. Check all connections. Un-plug & reconnect every data & power connector in your PC. (Double check). There is a fuse inside your power supply that may have blown. Check you're manual page, Approva Statements B-1. Fuse Warning Instruction Caution.
Check fuse in power supply. (Unplug power cord before opening).
If you can not power up the PC after all of the above than if possible, swap out the power supply.
Replacing the power supply is the last step.
If you have more questions, feel free to ask.
Good Luck!
Mike
Apr 09, 2008 | E-Machines eMachines Desktop PC
Dell Dimension 4100 (-JM0TB01) PC Desktop Logo
Ekse
Clive
Clive
Alun Cox
