Question about Microsoft Xbox 360 Controller
My wireless controller is constantly losing its connection
Hi, my wireless controller, after only a couple of weeks of having my console, constantly loses its connection, but comes on again for a while after i restart my controller.  the batteries show a full charge.
Posted by lynn tucholski on
  • 3 more comments
  • demonzboy Feb 10, 2008
    My wireless controller gets disconnected after I start playing any game. I've tried turning off all other wireless devices but it still gets disconnected. What should I do!?!
  • chrispyb Mar 17, 2008
    same problem here even with the cord pluged into the controler it loses signal...how is that?
  • immatur3_u53 Jul 25, 2008
    having the same problem with my xbox and wireless controllers. the wireless controllers connect fine with my xbox. and then after about 5 minutes my controller starts to search but it is still working. this goes on for a good 10 min until it finally drops out every 3 seconds. i have 3 wireless controllers and have gone to my local store and even exchanged xboxs. so its really not solely the xbox or controllers by themselves. this problem only recently started to occur with no change in anything i can think of, and i have played the same xbox with the same controllers for over a year. PLZ HELP DRIVING ME INSANE!
  • Anonymous Mar 20, 2009
    my wireless controller keeps turnin off and the bATTERIES ARE NEW AND IM ONLY 3 FEET FROM THE 360
  • Anonymous May 01, 2009
    I have tried everything, turned off cable box moved all cordless phones away, or unplugged the phone altogher ive tried differnt battery brands i tried playing with the controller practically touching the signal receiver.....it makes me regret buying xbox
Anonymous
    Problem Solver:
  • 6 Answers
If you are using regular batteries try turning off the "vibration". I tried this and it works well no more problems.
I don't believe a wireless network would cause you to lose signal , i am sure Microsoft thought of this before the console was released. It could also be that your batteries are low and in need of replacement.
Posted on Mar 24, 2008
Anonymous
    New Friend:
It's not the batteries and it's not the signal connection. Jiggle the battery pack and see if it loses it's signal when you touch it. It's in the design of the pack, it's loose.
Posted on Oct 26, 2010
  • sooperdooper Apr 05, 2011
    Thanks, a couple pieces of tape tightened up the battery pack and now no more disconnects.
Anonymous
    Problem Solver:
  • 6 Answers
All wirless controllers run on i think its a 2.6 hrz signal if you have things like bluetooth radios and even romotecontrolls that run on the same hrz lvl it can dissrubt the signal try turning every think off when playing the console of course only turn wireless things off whilst playing as wired items use a covered signal
Posted on Oct 19, 2007
Anonymous
I recently had the same problem. turns out- it was my wireless router being only 2 feet from the xbox. same distance and/or a metal plate should help if you have a similar setup.
Posted on May 04, 2009
Anonymous
Okay if its constantly disconnecting and then reconnecting to only disconnect a few moments later, you might have had the same problem as me. I had took apart my 360 controller to fix something only to have this problem appear. If you have the problem similar to mine, well what i did to fix it was to remove the sync button and then it worked fine the only down side being that the only way to sync it would be to use the plug and play kit or find something small enough to fit in that small hole and press the button.
Posted on May 10, 2009
Anonymous
    New Friend:
If you have disassembled your controller, then vedtak has the answer, is on the right track, except that you don't have to remove the connect button. After trying it it was continuously disconnecting/connecting. When I tried the connect button, I noticed that it wasn't pushing in (you can feel a little click).
When you reassemble it, I noticed that it's very easy to push the circuit board and and jamb the connect button. Once I realized that, I was able to reassemble it such that the connect button worked and I proceeded to use it for a few hours this evening without a hitch.
Posted on Mar 24, 2010
Anonymous
    New Friend:
It's not a signal problem or anything like that. It's the controllers battery pack design. Did you try touching the battery pack to see if it loses connection or jiggleing it. I figured out quickly that mine is very slightly loose and if touched much it disconnects.
infomaniac_n
    New Friend:
I tried all of these and none of them worked, but for me this did...
take the battery pack off and remove batteries, the connectors inside the pack are not always touching the batteries properly, so push in the button that removes the pack and you should see the connectors get pushed slightly... just keep the pressure on there as much as you can to get those connectors back in touch with the batteries and you should be fine
Posted on Mar 31, 2013
Philip Alderman
    New Friend:
I am having the same problem could some one help as i don't want to start taking my controller as i know it is not that because i have used 3 other controllers and they all do the same thing? :/
Posted on Dec 02, 2011
My printers keeps losing its connection to my laptop and Ipad and I have to keep reinstalling every time I want to use them together.
It may be losing its IP address. Check the DHCP address affectation of your router. And leave your printer constantly connected to the router. You should also let your printer get the IP address automatically upon booting.
Nov 07, 2013 | Canon PIXMA MX712 Wireless Inkjet Office...
Hi. i have a NHL 10 for ps3. at the start of almost every game after it loads for online, it says "lost connection to opponent". it is really frustrating as it happens a lot. i can never connect to...
Sounds like either a week server provided by EA (the ones that update and control the online network) or you have a week internet signal. If your using wireless that would probably be the biggest issue. Hope I helped.
Jun 21, 2010 | Sony PlayStation 2 (PS2) Console
Wireless controller won't stay connected
This could be that your batteries are losing it's power.
Try changing them and see what happens.
May 19, 2010 | Microsoft Xbox 360 Wireless Controller
Keep losing connection with controller and console
try getting new batteries if you have a rechargeable battery pack plug in the charger then dissconnect. If this doesn't work it could be two things either your controller or the 360 cant sent out wireless signals for yor 360. To fix this try a different controller or send it in if you still have a warrenty
Apr 11, 2010 | Microsoft Xbox 360 Console
Xboc controller constantly disconnects from console
If the controller is continually disconnecting from the xbox, the battery is probably dying. Have you tried installing fresh batteries into the controller ?
Nov 16, 2009 | Microsoft Xbox 360 Wireless Controller
Controller will not connect to game
To connect a controller to Xbox 360 console:
Wired Controller:
1) Simply plug in the controller into one of the three USB ports avaiable on the system. Two of which are on the front of the console( next to the power button, there is a small door, it is marked by two dots on top, open it and you will find the two USB ports, the third USB port is on the back of the system)
Wireless Controller:
1)Press and hold the Xbox guide button until the controller turns on.
2) Make sure that the console is on, then press and release the connect button on the console( the button next to the memory card slots)
3) Press and release the connect button on the Xbox wireless controller, if connected the ring of lights on the controller will stop blinking, one of which will now be constantly lit, The same will occur on the ring of lights on the console itself
Mar 16, 2009 | Microsoft Xbox 360 Console
My wireless contoller wont connect
If so, it really sounds like your controller keeps losing sync with the 360.
- turn them both off
- turn on the 360 with the power button on the console
- wait for it to start up, then press the sync button next to the usb flap on front.
- then press the sync button on the controller (by the recharge connection slot)
That should reset it.
Oct 16, 2008 | Microsoft Xbox 360 Wireless Controller
Connectivity
sounds like your wireless board went bad. Call SONY if you still have warranty.
If not find a wireless board (I sell them sometimes on ebay). It is really easy to replace.
Contact me at [email protected] if interested in purchasing a wireless board.
Sep 16, 2008 | Sony Playstation 3 (PS3) Console
Cant use ps3 controller wirelessly
it sounds like it has been droped you will have to get it looked at it could be a lose battery conneion or lose wire
Jan 03, 2008 | Sony Playstation 3 (PS3) Console
Microsoft Xbox 360 Controller Logo
15,285 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Ekse
James Bradburn
James Bradburn
Lee Hodgson
Lee Hodgson
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
