Transam motor has seized trying to remove engine but still connected to torque convertor cant turn motor over to undo nuts to separate do i have to take transmission out as well
If you can slide the engine forward a little, you may gain enough access to remove your torque converter bolts. You have to be careful, because if you put pressure on the trans gears, you can break the pump, and when running it will leak trans fluid very fast. Your situation may be in your best interest to remove the trans as well. I hope this helps you, and I do wish you luck on your repair.
Is it front wheel or rear? if front you have to take down the motor and trans together by unbolting the 4-6 very large bolts and drop the entire front assembly.
if rear drive disconnect the drive shaft and unbolt the crossmember get a trans jack or one with wheels that work and unbolt trans from motor.
remember to SPIN the torque con when reinstalling.
Fig. Remove the starter motor and bolts
torque convertor overheating and inlet and uotlet torque converter pressures the same and above specifications
