Question about Dell UltraSharp 1704FPT 17" Flat Panel LCD Monitor
Dell 1704fpt Screen turns white
I have a Dell 1704FPT that turns white.  When you initially turn on the screen you can see a picture but within seconds Horizontal lines form and the display "bleeds" to white.  This happens no matter what port (DVI/VGA).  It will even do it when not connected to the computer.  I have been told it is the power supply, the LCD, or the driver card.  Since that pretty much covers everything inside, does anyone know how to narrow it down?  Seems like the Power supply voltages are right.  Don't know how to test the LCD/ Driver.
Thanks
  • mbzoutlaw Oct 19, 2007
    So that is the driver board.  The LCD should be fine?
  • 93 Answers
Ok,your monitor has a defective vertical ic.when vertical ic is defective you can see the horizontal line.
Posted on Oct 19, 2007
I think that the back light had burned out, your best bet is to buy a new moniter
Posted on Dec 25, 2007
6ya staff
SOURCE:
Can I use the USB ports on the left side of my Dell 1704FPT monitor to connect devices? (e.g., Logitech webcam)
yes you can use the usb port but let me tell you one thing very clearly there is problem with these ports either they dont recognize your usb or maybe your monitor screen flickers... so use monitor port with a lot of care and i advised you to atlest read the manual before you do anything.
Jan 08, 2011 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
Dell 1704fpt usb ports: how do you find the
you should not need drivers for a usb port is the cable hooked up ? if so they are probably broken
Nov 27, 2009 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
Dell 1704 monitor goes to black screen after one
Hi my name is Rain.
Ok so that im clear on the problem. your monitor will come on but in a matter of seconds it goes to a black screen?
If this is the problem. The answers you seek will most likely
be in your video card.
Try this test:
  • Unplug monitor from the computer.
  • Turn on monitor .
  • Look for monitor self test screen.
If you see the monitors self test screen then your problem indeed is
the video card . You will need to replace the video card inside of the computer.
Nov 23, 2009 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
Dell 1704FPT LCD will not turn on.
The adapter you have been using might be faulty. Make sure the cable is inserted fully. If that does not work, try the VGA or the DVI adapter you have not been using. Verify also the socket to which its connected (the power source) is not faulty either.
Hope it helps.
Aug 29, 2009 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
Dell 1704FPT Flat Screen Monitor USB ports
you need to run the usb to your computer first have you done that
May 08, 2008 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
Dell 1704FPT Display Problem
It is your inverter/power supply board. Costs around $62.00 with shipping. Not a hard replacement if you have electronic maintenance experience.
Jan 22, 2008 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
Dell ultrasharp 1704fpt vertical line
i have tried to fix these problem before but no good i did find a web site that will also stat that this can not be fixed but rather they will replace the lcd film at a not so bad price
Nov 04, 2007 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
Open Questions:
Dell UltraSharp 1704FPT 17" Flat Panel LCD Monitor Logo
357 people viewed this question
Ekse
Clive
Clive
Alun Cox
