Question about Pioneer DV-373 DVD Player
Setting region codes to code 1
I can not get my player set to code 1, I do not know how or where to get help
    New Friend:
No id num
Posted on Dec 03, 2011
  • 376 Answers
*To convert this player to Multi-Region
1. Open the drive tray
2. Press the Setup button on your remote control
3. Press the buttons 1, 9 and 9, in order and one at a time on your remote control
4. Select the Region option from the menu and change to a specific region or all regions
To convert this player to Multi-Region if the above does not work
1. Press the 7 button on your remote control
2. Press the 6 button on your remote control
3. Press the Select button on your remote control
4. Highlight the Region option and press 1 for region 1, 2 for region 2, and so on, or 0 for multi-region playback
5. By visiting the next page of this hidden menu, you may be able to disabled Macrovision by setting an option to 0, although this particular setting does not survive power off
6. Press the Setup button on your remote control
Done!
Posted on Aug 07, 2008
6ya staff
SOURCE:
Tip
Region free code for Hitachi DVP515 DVD player
Power on your player whilst pressing both the Play and Stop buttons on the front player.
After a short while you should be presented with a set of language options.
Release the Play and Stop buttons on the player.
You will now need to select a language option between 1 and 6.
To convert this player to Multi-Region playback:
Press the Repeat button on the Remote Control.
Using the Remote enter the code below, note that you must know what Region your player is currently set to in order to know which code is appropriate.
For Region 1 use 2, 9, 3, 3 and 4.
For Region 2 use 3, 8, 7, 6 and 7.
For Region 3 use 5, 6, 7, 3 and 2.
For Region 4 use 7, 6, 8, 8 and 4.
For Region 5 use 5, 3, 8, 1 and 4.
For Region 6 use 2, 4, 4, 6 and 2.
A code should be displayed on the screen indicating the current Region setting of your unit.
Press the 9 button on the Remote Control for Region free, or 1 for Region 1, 2 for Region 2 and so on.
Press the Open button on your player.
Press the Standby button on the Remote Control.
If the player sticks on FBI Warning screens:
Press Forward Search x2 or faster, the disc should skip straight to the main feature.
on Mar 07, 2010 | Televison & Video
PHILIPS DVD player 616K, how to change region or get into right region. my player was working OK. Suddenly it stopped functioning and showed/diplayed '' wrong region'' on the TV screen.
Changing the region code for DVD616K :
1. Press OPEN/CLOSE, and wait for the tray to open.
2. Use the remote control to input digital key '1', '1', '1', '0' in that order
if that dont work go 1, 1 1, 1 in that
order.
Kindly leave a few seconds between each entry, the microprocessor is slow
with these entries.
3. Press number '7', '8' or '9' to display the current region code of the DVD
player.
OR
4. Press any number of '0' to '6' to set the required region code. The OSD
will display the new region code of the DVD player.
5. Region '0' will be the setting for multi region
6. The region setting will be saved in the FLASH memory.
7. Press OPEN/CLOSE again, the DVD player will return to normal operation.
note: you want to chose region 0 so u can use all regions
Nov 15, 2009 | Computers & Internet
I Can Not Find a YAMADA DVD-7600XTV Region Unlocker
I don't know if this will work but I can atleast try to help
1) Open the disc tray.
2) While the tray is open, enter the following code with the remote's numeric pad: 2812
3) To change the region code, press the "Enter" button repeatedly. "Region 9" means all regions will be enabled.
4) Close the tray to save the desired setting.
Other Zoran Vaddis 776 based players have other options on this screen (such as Macrovision Enable/Disable) but this player only offers the region code setting (note the unused available space for other menu options).
If you press "Display" on the remote, the firmware version will be displayed.
or
1. Press "Eject"
2. Press "Setup"
3. Press 3x on the right "Präferenzen-Setup"
4. Press 7x Down "Land"
5. Press 1, 3, 7, 9
6. And 0 for code free
7. Press "Play"
Mar 29, 2009 | Yamada DVD-5520 DVD Player
Tip
Region free code for Hitachi DVP515E
Tip
Region free code for Hitachi DV-P305U
Region problem and disc not reading
For your region problem:
1. Be sure there is no any disc inside the device.
2. Power on your player
3. Press <Menu> on remote
4. Using your remote control enter the code below, note that you must know what Region your player is CURRENTLY set to in order to know which code is appropriate:
for Region 1 use 2, 9, 3, 3, 4
for Region 2 use 3, 8, 7, 6, 7
for Region 3 use 5, 6, 7, 3, 2
for Region 4 use 7, 6, 8, 8, 4
for Region 5 use 5, 3, 8, 1, 4
for Region 6 use 2, 4, 4, 6, 2
5. A code should be displayed on the screen indicating the current Region setting of your unit.
4. Press the 9 (or 0) button on your remote control for Region free, or 1 for Region 1, 2 for Region 2 and so on...
5. Double press the <Menu> button on your remote
6. Enjoy :)
For vcd problem...Make sure that the Cd is written in a format which is compatible with the format with your dvd player. If you have a dvd player that can play formats like, avi, wma, etc. check that your cd writer is set on high quality mode and that the writing speed isn't set too fast. hope i was able to help^^
Jan 03, 2009 | Samsung DVD-R135
Tip
Region free code for Samsung DVD M105
Code 1:
Switch the player off and on.
Hold the play and stop buttons (for 10 seconds).
Press the Repeat button on your remote control.
Using your remote control enter the code below (note that you must know what Region your player is currently set to in order to know which code is appropriate):
For Region 1 use 2, 9, 3, 3 and 4;
For Region 2 use 3, 8, 7, 6 and 7;
For Region 3 use 5, 6, 7, 3 and 2;
For Region 4 use 7, 6, 8, 8 and 4;
For Region 5 use 5, 3, 8, 1 and 4;
For Region 6 use 2, 4, 4, 6 and 2;
Press the 9 button on your remote control for Region free, or 1 for Region 1, 2 for Region 2 and so on.
Press the Standby button on your remote control.
Code 2:
Power on.
Press the open/close button, the CD-tray will come out, remove DVD or other CD if present.
Press REPEAT button once.
Enter following numbers: 38767.
Yyou will then see '02' on the TV-Screen.
Press button number: 9.
Press the open/close button.
Power off, then on.
Tip
Region free code for Samsung DVD M405
Power on your player.
Press and hold both the Play and Stop buttons on the player.
You will now need to select a language option between 1 and 6 to convert this player to Multi-Region playback.
If the player sticks on FBI Warning screens press Forward Search x2 or faster, the disc should skip straight to the main feature.
Tip
Region free code for Samsung SV DVD1E
Code 1:
Make sure there is no disc in the machine.
Power the DVD on by the remote control (not by the on/off button on the actual player).
Press enter, 8,4,2,6,9.
Press enter.
The Tray will open, insert the DVD.
Code 2:
Always perform a Cold Start before applying the hack below:
Power on your player whilst pressing hold both the Play and Stop buttons on the front player.
Code 3:
Ffor Region 2 use 3, 8, 7, 6 and 7;
Tip
Region free code for Samsung DVD M103
Code 1:
Code 2:
Power on.
Power off, then on.
Pioneer DV-373 DVD Player Logo
379 people viewed this question
Top Pioneer Televison & Video Experts
Marvin
Marvin
Ekse
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
