Check cd player wiring. What did you tap into to get power? On today's cars, if you tap into the wrong place you can cause immediate electrical problems. If it was running and just shut down, chances are that's what happened here. If the doors were open during install and it would not start when you were finished, then you have likely drained the battery ...recharge it and have it load tested. Sometimes if the battery was marginal it will not jump and will not re-charge. If that's the case change the battery. ALWAYS test first.
what is the other posible reason a 99 plymouth breeze wont start it rolls over well i change the crank sensor,camshft sensor,ignation coil but won't start
that would'nt make any difference to water pressure! may be possible that your vehicle was overheating! overheating caused excessive pressure in the system, which popped(The noise you heard) one of the hoses, or a connection!
not related to stall check fuel pressure and fuel filter first then pressure if no pressure bang on fuel tank with rubber hammer if starts replace fuelpump if dont start check fuel pressure if ok then check crank sensor
we tried a jump last nite n it still wouldnt do it my cousin was puttin a cd player n it n as he was taping the lose wires it cut off
