NEEDING ACCESS CODE
GET A BWOUNDERFUL PICTURE WHEN WATCHING DVD OR VCR
BUT CAN NOT GET THE TV READS NEEDING ACCESS CODE
JUSTPUT IN A TICKET BEFORE BUT I MADE A MISTAKE AND PUT DOWN THAT IT WAS A STANDARD TV
PLEASE REACH THERESA CONKEY @512-291-4951
  • Anonymous Nov 18, 2007
    enterded access code
6ya staff
SOURCE:
Vista Electronics
  • 1694 Answers
SOURCE: connecting VCR/DVD combo
Confusing! TV with NO yellow,red white input ? Buy an RF
adapter Radio Shack about 30.00.....TV has input ? = yellow
video,audio R,L from Insignia source dvd/vcr out ( audio R,L,
video {yellow} ) You don't need to switch cables.As to record
feature,consult owners manual..................................T
Posted on Nov 21, 2007
Anonymous
  • 10 Answers
SOURCE: black & white picture on vcr & dvd playback
Check your VCR or DVD for correct region and standard. If I had a camcorder, VCR, or DVD player here in America on Pal standard or eupopean region the same thing would happen.In fact I accedently did that on an unknown switch on the camcorder.
Posted on Dec 05, 2007
Anonymous
  • 4 Answers
SOURCE: Need code for Emerson TV,DVD,VCR Combo
I don't have a code book for you, but I can tell you how to program the RCR660 using the automatic programming feature.
Programming RCA model RCR660 (no code search button)
While following these instructions, keep the following in mind:
device = the component you wish to control with your remote (TV, DVD, VCR, etc.)
DEVICE = the button labeled for the component you wish to program
1. Turn on the device you wish to program.
2. Turn off all other devices in the general vicinity.
2. Press and hold DEVICE
3. While holding DEVICE down, press ON/OFF and hold them both down until the LED turns on for that device.
4. Release both buttons.
5. Point the remote at the device, press and release PLAY and wait 5 seconds or until the LED stops flashing.
6. If the device does not turn off, then continue to press PLAY and wait the required interval (for a maximum of 20 times) until the device turns off.
7. When the device turns off, press REVERSE, wait two seconds and continue doing this until the device turns back on.
8. To finish programming, press and hold STOP until the LED turns off.
Posted on Dec 31, 2007
stick it
SOURCE: I need the codes for a Magnavox dvd vcr player and a Orion tv.
I have a one for all remote, i have no codes for a coby dvd player.Can some one help with the codes?
Thank you, Don
Posted on May 01, 2008
IrishDruid
Swilin Sampson
  • 2712 Answers
SOURCE: Picture Moved Up
Check the cable and connections between the TV and your cable line. Make sure the contacts are clean, no bent pins, etc. Try replacing the cable if possible.
Posted on Jun 01, 2008
No picture on tv when playing dvd or video
does it have a picture for regular TV watching .if so then the dvd player has gone bad
Nov 22, 2015 | Panasonic Pv-d734s Dvd Vhs Player Combo...
Good day: Our Tv picture is rolling when
Either the tracking will be off set on the VCR or the heads may need cleaned or the pinch roller in the VCR will be worn & need replaced.There could also be a possibility the guide arms are not fully in position in the VCR.
Oct 23, 2009 | Sylvania 6720FDG 20" TV/VCR/DVD
DVD disc reads that it is playing, but there is no
what tv connection are you using from the dvd make sure connection are fully pushed in, try another dvd player with the same tv and connections.
Aug 25, 2009 | Zenith XBR616
Connecting TV to DVD / VCR Recorder
Appreciate the direct "Ask Me".
I am assuming that what you intend to do is:
  • record a TV channel/program/show either on VCR or DVD;
  • while at the same time watching another TV channel/program/show directly on the TV.
Yes, but only if you are not using/needing a cable decoder box. To do this, the coaxial cable from your provider would have to be made to supply both the RF/ANT/CABLE IN of the VCR/DVD and the TV. To accomplish this, you would need a 2-way splitter. One input to the splitter, 2 outputs, one each for the DVD/VCR and the TV. The DVD/VCR would have to be connected to the TV using yellow, white & red RCA cables. To watch DVD, VCR and/or what is being recorded on the DVD/VCR, set the TV to Video mode. To watch regular TV, select the channels on the TV.
Good luck and Thank you for using FixYa.
Pls be informed that due to my current rank and rating, even a Helpful wouldbe detrimental to my status. Should this solution not address yourconcern, it would be appreciated if you could just not rate it at all. Cheers.
Dec 29, 2008 | LG RC797T
Tv/digital converter box & vcr-dvd hook-up
I have a vhs and dvd player all in one
I have a converter box hooked up to my tv and vcr , dvd player combined
I can play my movies on the tv. ok.
you have to have your tv and vcr set on channel 3. if that is what your main tv is set up with. Or 4 if you have your tv set up with that.
Mine plays ok. My settings are for channel 3
My suggestion would be to check your hook ups. maybe they are not hooked up correctly
I had to go to www.google.com and did searches to help with hook up.
I can also record station I am watching with vcr on vsh tapes. I do not have a dvd recorder.
I found out that you have to have 2 converter boxes hooked to one tv., in order to record on on station while watching another. I have not tried that, as I don't have 2 converter boxes for one tv. I found that by doing google search also. Good Luck
Dec 04, 2008 | Televison & Video
Taping to a VCR post converter hook-up
cant you just turn the channel on your DCB and then record on the vcr?
Jun 11, 2008 | Insignia Digital-to-Analog Converter for...
Picture Moved Up
Jun 01, 2008 | Samsung HCL4715W 47" Rear Projection...
Connecting up Digital TV, DVD recorder and VCR
You need to hook the VCR and the DVD recorder to the scart connections on your TV.
VCR to one scart on the TV
DVD recorder to the other scart on your TV
Jan 31, 2008 | Televison & Video
Black & white picture on vcr & dvd playback
Dec 04, 2007 | Televison & Video
Televison & Video Logo
44 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
