The blinkers or the hazard lights are not working. what could it be
Here is some extra information on replacing the Daewoo Lanos indicator / hazard lights relay. Open the driver door, on the side of the dashboard there is an access panel. Flip it open with a screwdriver.
Now you can pull out a violet connector block. The relay is plugged into this block, it is green. You can just pull it out of the connector block and replace it by a new one. The part number is 96312545, and it has three pins, numbered 31, 49 and 49A.
Other specifications: 12V 2/4x21W. It is made by Daewoo / DECO. The same type of relay is used in the Daewoo Matiz. I picked up a used relay from an old Matiz for 2 euros and the indicator/hazard lights work like
a charm again. The whole replacement took about 2 minutes, but it took me days to get the used part. Probably other relays with these three pins will work too: google for "31 49 49A". Hope this is useful to other people who run into problems with the Daewoo Lanos indicator lights!
The flasher unit...a little silver colored can possibly mounted near the fuse block
