Question about Sony Cyber-shot DSC-W55 Digital Camera
Need help with sony cyber-shot dsc-h2
When i turn the cam on it says access then it comes up with please turn the camera off then on again. i have charged the batteries and it still did this so i bought new batteries and fully charged those ones and it`s still doing it. how do i fix this problem. it will not let me take pictures an di`m getting upset.
  • Anonymous Oct 18, 2007
    thanks for trying but this was not helpful. it is still showing turn camera off and on again. do you have another idea?
  • Anonymous Oct 19, 2007
    my camera is a sony cyber-shot DSC-H2. according to the manual it has to do with the telescopic lense and i don`t know how to remove it to check it out. after i shut it off the lens keeps moving back and forth for about a minute before it finally stops.
Jawad Hassan
    Problem Solver:
  • 30 Answers
Please eject camera battery and clean with a pin your battery tip in your camera with care fully.
Hope its helpful to you
Posted on Oct 18, 2007
  • Jawad Hassan
    Jawad Hassan Oct 19, 2007
    Please wrote your camera name and camera model
    I’ll try my best
  • Jawad Hassan
    this is your camera i read this all feature its so sensitive camera.
    i advise you to clean its button to open your camera or concern sony department there is problem in your power button.
    if not it is hardware problem. its also solved the recomended engineer.
Canon powershot a3300
If nothing is wrong with the camera, the battery is placed correctly, the battery cover is closed correctly then only one thing can be wrong. Even when you don't believe it is possible, the battery can be flat again.
So to make sure everything is as you think. Charge the battery again, and look if the charger acts as usually. The charging lamp turns orange and charging begins. When the charging is finished, the lamp turns green. Last time you charged, it could have taken 4 hours, before the lamp went green. If the battery is recently charged, it only will take a fraction of that time. If it still takes a long time, your battery was empty. It is recommended, to charge not longer than for 24 hours. After charging, please wait till the battery is cooled down. Then insert it again and close the battery cover. Check the cover closes correctly. And now switch on again.
If you charged with an USB cambs connected to the camera. Don't forget to remove the cable, because the camera won't start as long as an USB cable is connected.
Feb 25, 2014 | Cameras
Sony dsc w50 quit working
I think the memory card is full , try first taking off the battery and putting it back.
If the camera still does not work, try a different memory card.
If you still have problems, try going to setting menu and reset camera settings.
Sep 22, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
MY CAMERA WONT COME ON THE TELESCOPE LENSE WONT GO BACK IN IT DOSNT SEEM TO CHARGE
Please try the following: Don't forget if you're charging though the computer NOT to turn the camera on. 1. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Turn the camera on. 2. Without the memory card, turn your camera on. (If it works then it?s your memory card that is faulty) 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a no power repair with KODAK or a new cable.
Jan 27, 2010 | Kodak EASYSHARE M1063 Digital Camera
It won't turn on it drop from me once and now it won't turn on
In order to clearly determine the fault the model of your KODAK camera is needed However I hope this will help: If your cam use AA batteries: Here are the steps for the no power problem: 1. Make sure you will install a new or fully charged battery/batteries into your camera. Please use lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher). 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera 3. Turn on your camera without the memory card. If your camera model requires the manufactures batteries: Here are the steps: 1. Make sure you will install a new or fully charged battery/batteries into your camera. 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Without the memory card, turn your camera on. 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a No power repair or a new cable. In order to organise your repair or Trade up please Contact KODAK: http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Jan 03, 2010 | Kodak EasyShare One Digital Camera
Hello
Jan 02, 2010 | Kodak EASYSHARE M1063 Digital Camera
Kodak 8.2 will not turn on i've only had the camera for a couple of months . I have charges the camera for a day or two and it still will not come on
I think you mean the camera and not the ESS software. Since you have only noted the kond of the software and not the model of the camera I have written 2 possible solutions for you:
If your cam use AA batt.:
Pls. use lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher).
Battery support : KAA2HR,CRV3, 2xAA Ni-MH and 2xAA Lithium-Ion
Here are the steps:
3. Without the memory card,turn on your camera.
Contact KODAK:
If your cam use manufactors rechargeble batt.:
Make sure that you are installing a fresh/ full charge battery
Here are the steps:
4. Pls test with an alt. batt.
If you do not have access to a dif. battery.
Pls. take the batt out of the camera. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the batt. If not you will need to order a No power repair.
Contact KODAK:
Nov 25, 2009 | Kodak EasyShare One Digital Camera
When i power the camera up it won't come but the word access pops up and after a minute the message on the back of the camera will read "turn the power off and on again" . what could be the problem .
If the camera doesn't turn on when you move the power switch, remove the batteries from the camera, re-insert them and connect the camera to a camera dock--if you have one. Check the LED lights on the dock and make sure the batteries are charging. Refer to your manual to learn which lights should be on when the batteries are charging. If they are not, try powering the camera back on after inserting new batteries.
Also try cleaning the battery contacts in the battery compartment using a clean,dry lint-free cloth. Sometimes, little particles can cause short-circuits in the battery compartment. If the camera still does not turn on after you clean the contacts, your camera may have had a power failure. Contact the manufacturer.hope this helps you
please do rate me on this issue
Nov 21, 2009 | Cameras
Everytime i turn on my camra it turns off again
Remove the battery
Clean the metal contacts on the battery using a clean cloth
Contact KODAK:
Oct 04, 2009 | Kodak EasyShare M863 Digital Camera
My kodak digital camera wont stay on!
Your problem could be the result of corrosion on the battery terminals inside the camera. Remove the batteries and clean the battery contacts inside the camera with a soft cloth (a heavy buildup on the contacts may require cleaning with a fine wire brush, steel wool, or sandpaper). Remove any residue that the cleaning leaves in the camera, clean both ends of each battery, and then reinstall the batteries. This clears most power-on problems, but if yours persists, check the Kodak troubleshooting guide at:
http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=6198
Aug 16, 2009 | Kodak EasyShare CX7530 Digital Camera
NO POWER - TOTALLY DEAD!
i have the same problem . it sometimes comes on and just suddenly stops working . won't turn on whatever you do . and after a few days works again and it happens again . i love this cam and want to fix it .
Aug 27, 2007 | Panasonic NV-GS17 Mini DV Digital...
Sony Cyber-shot  DSC-W55 Digital Camera Logo
216 people viewed this question
Top Sony Cameras Experts
Muntejaya Ginting
Muntejaya Ginting
Harrie
NOEL
NOEL
Are you a Sony Camera Expert? Answer questions, earn points and help others
