Question about Sony CDX-M630 CD Player
I pluged the radio in me car an it says code in before itl work i got it off a friend an he had it workin in his car before i tuck it ou an he said e lost the code he only used the code once an didn n
Trouble
Posted by mula on
Anonymous
Code
Posted on Apr 03, 2008
Mitch
  • 752 Answers
You need to enter the code using the remote. Try these codes.
You need to press reset after each attempt.
CODE 1: MODE SOUND OPEN ATT
CODE 2: ENTER OPEN meNU 6
CODE 3: OPEN DISC+ 1 LIST
CODE 4: SEEK- SEEK+ 3 OPEN
CODE 5: OFF 4 OPEN SOURCE
CODE 6: 2 OPEN DSPL SOUND
CODE 7: OPEN 5 ATT SEEK+
CODE 8: DISC- DSPL OFF OPEN
CODE 9: SEEK+ SOUND OPEN ENTER
CODE 10: DISC- LIST SEEK- OPEN
CODE 11: OPEN 4 LIST OFF
CODE 12: DSPL SOURCE OPEN 1
CODE 13: MENU 2 MODE OPEN
CODE 14: 5 DISC+ OPEN ATT
CODE 15: 3 MENU SEEK- OPEN
Posted on Nov 08, 2007
1 Related Answer
Eagleeyes
Mark Waller
  • 199 Answers
SOURCE: i pluged the radio in me car an it says code in before itl work i got it off a friend an he had it workin in his car before i tuck it ou an he said e lost the code he only used the code once an didn n
use your remote and enter the following:
* enter - 5415 enter *
Regards
Mark
Blue ICE
Posted on Feb 28, 2008
Code couleur radio
bonjours a vous !
es ce que quelqu'un connait le code de couleur derriere le radio,ou un site ou je pourrais trouver ca ,car j'ai fait des recherche sans aucune reponse ,pi mon dealer ne peut pas me les fournir
merci
Sep 11, 2012 | 2001 Chrysler Concorde
Battery went dead in my bmw its ok now, radio not workin need code for 1998 R reg bmw E42 318i. can u help
These older BMW radios require further special advice in order to see if a code is available.
Try asking here and mention this forum CLICK HERE
Apr 02, 2011 | Car Audio & Video
Radio not workin
ur friend permenently locked your radio. you will need to see a dealer to have it unlocked
Apr 11, 2009 | 1992 Hyundai Sonata
Acura car stereo lock codes my stereo needs a code is a Acura 3.0CL now it says err-3 can some one help
err-3 means you have entered incorrect anti-theft radio code more that three times.If you do not have radio code you can most of the time find the code card tucked away in the owners manual pouch.(looks like a bussiness card)If you are unable to find card you would have to pull radio from dash and retrive stereo serial number,which is on bottom side of radio.once you have s/n you can take s/n to any acura dealership(has to be a dealer)and they can get radio code for that stereo through Honda Corp.once you have correct radio code you will need to first unplug radio,or disconnect battery to reset radio memory,then type in radio code.again if entered incorrectly 3x ,radio would need to be reset again too clear error codes.good luck!
Mar 30, 2009 | 1998 Acura CL
I need the code radio for acura integra ls 1997
Mar 26, 2009 | 2001 Acura Integra
2001 pontiac aztec will not start all the time
you have 2 computers under your consal one is the body controle and the other is the main computer. They are pluged in to eachother i had same problem and replaced both and every thing is workin fine other than getting my stereo codes back in so i can listin to it. hope this helps
Dec 29, 2008 | 2001 Pontiac Aztek
Cannot use radio after battery change, I have the code,not workin
you can only try the code install 3 times before the radio locks up.
you will have to disconnect the battery for 10 seconds if that happens. the 5 digit code gets entered where the station select buttons are 1 2 3 4 5 6 enter the code there.
Dec 18, 2008 | 1998 Honda CR-V
Powerlocks
i shoul not afect any thing unless you replace the batterie with the car runing, and some radios have antitheft code if batterie die or disconect the radio will ask you to type a code in order to work again but most of times it display the worl code on the digital screen
Jun 11, 2008 | 2004 Dodge Neon
Sony CDX-M630 CD Player Logo
1,153 people viewed this question
Top Sony Car Audio & Video Experts
Larry Stiles
Larry Stiles
Marvin
Marvin
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
