Question about Toshiba Satellite A35-S159 Notebook
Laptop problems after changing cpu
I replaced the cpu with a compatible processor that was labeled to work in my laptop.  Now when it comes up, it starts to run, then the screen & text gets heavily distorted.  It does start out like everything is fine, but will not fully boot up.  Does this sound like I need to run the reboot disc to recognize the new processor?  Since I've had this laptop for four years through two moves, I cannot find my reboot disc.  How would I go about getting a new one?  Any help would be greatly appreciated.
[email protected]
Posted by Metro-Chris on
  • Metro-Chris Oct 18, 2007
    I have a satellite A35 S-159.
    I put a Pentium 4, like was originally installed, but it was a 2.8 GHz instead of 2.3.
    It was marked as being compatible with my model.
    Ok. Thats what I will do.
    Thank You for you help. I needed some advice from someone more experienced.
    Thanks,
    Chris
kRt uK
    Problem Solver:
  • 6 Answers
You can't change the celeron by p4 in this model. I have tried change my celeron 2.7 by p4 2.8 from a a45 and doesn't work. I researched so much and I work in my celeron yet.
Posted on Mar 01, 2008
  • kRt uK Jul 21, 2008
    The some situation above posted by Metro-Chris. I have got a A35-S1592 and tryied 2 different P4 CPUs (2.8 and 3.06) both working in my brother's laptop (A45). Seems a Toshiba MB issue.
Anonymous
    Problem Solver:
  • 6 Answers
Are you sure the CPU is compatible with your notebook?  What kind of notebook do you have?
Posted on Oct 18, 2007
  • Anonymous Oct 18, 2007
    I have never known a CPU to require any addtional installation steps other than just the physical install.  Did you purchase the CPU new or used?  Before using a recovery disc, I would first suggest getting a replacement CPU and trying again.
How to upgrade cpu
check the motherboard version and check on intel website for compatible processor. Changing processor in laptop is bit more complex but some computer shops can help in changing it
Nov 09, 2013 | Sony Vaio VPC-F Series Notebook (Intel...
Changing acer t690 processor
Yes, you can change the CPU, but your Motherboard will only support certain processors, Take a look at this Acer Support, you will see the compatible CPU's: http://support.acer.com/acerpanam/desktop/0000/Acer/AspireT690/AspireT690sp2.shtml Remember : Your machine's component work with one another, within parameters, one component,CPU, will not give you the improvement you might think. CPU, Memory, Graphics Card, Etc.,Upgrades, require more Power/Watts, therefore a new PSU. Which create more heat, new fan. One relies on the other. Do your research, their's a lot more to it than replacing one component. Do a comparison, what will all the components cost, to a new System? The prices for new Good Systems , are low due to slow sales of Desktops/Laptops.
Feb 05, 2013 | Acer Aspire T690 (AST690UP820A) PC...
In toshiba satellite a300 celeron processor is wotking, but with core2duo processor it's not working properly
You changed the CPU? Maybe it's not compatible? Is this the CPU , is it a Intel T5550
Feb 04, 2013 | Computers & Internet
Thermal faillure, processor is problem. how price? this processor?
Desktop? Laptop?
What manufacturer of motherboard?
What model of motherboard?
Intel or AMD CPU?
What model-number?
Search on www.eBay.com for a compatible CPU.
Jun 07, 2011 | Dell Pentium 3, 500 MHz Pentium III...
I want to upgrade my processor , how can i figure out a compatible processor for my aspire ?
download and install this software ..and it will map you all the components that you have inside it ..including the cpu ..and the socket it has ..and all cpu made for this kinda socket ...(you will find out in it ) ..will be compatible ..or ...get to the support site of Acer ..and ask them the exact model of the cpu that will fit and be compatible with your laptop ..
here is the program ...
http://www.mediafire.com/file/mezeoyv1z41/everest.rar
and here the support site where you can write them ...
http://support.acer.com/us/en/default.aspx
Have a nice day !
Mar 16, 2011 | Acer Aspire 5720 6497 Laptop
I got an aspire 4520 running on amd turion 64x2 processor and found that the processor is faulty. Can i replace the processor and where can i purchase the processor as i came to known its quit expensive.
You can replace the CPU if the new one is compatable with the computer.
Basically get the same CPU from a site like
  • newegg
  • ebay
then take the laptop apart and discharge yourselve after taking out the power supply and battery.
Make sure to apply new thermal compound to the CPU prior to starting the laptop back up.
Hope this helps
-Ryan
Mar 08, 2011 | Acer Aspire 6530-5143 Notebook PC
I want to come emachines 627 processor to a intel processor
If the processor in your laptop is an AMD, then sorry you cannot change it to an intel processor, the cpu socket on the motherboard is not compatible. If, however, you have an AMD processor and you want to upgrade it to a faster AMD processor.
Mar 07, 2011 | Computers & Internet
Can i upgrade the processor in a Packard Bell Butterfly M-EU-003UK?
yes you would be able to upgrade check out manufacturer website for cpu compatible list but it is not recommended to change the cpu of laptop
Jan 17, 2010 | Computers & Internet
Acer laptop upgrade
Need more info about laptop model number.
Ram and hd should be easy enough to upgrade but cpu unlikely and graphics very unlikely as its usually onboard vga.
Jan 14, 2008 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
Toshiba Satellite A35-S159 Notebook Logo
102 people viewed this question
Top Toshiba Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
