Panasonic Lumix DMC-FH25 / DMC-FS35 Digital Camera Logo
A
Anonymous Posted on Feb 01, 2018
Panasonic Lumix TZ35
I bought a Panasonic Lumix DMC-TZ35 in November 2013 - a week later it got caught in rollers going through security screening and the LCD screen was cracked, I have been trying, without any success, to find a replacement Screen. I am also confused by the different Panasonic model numbers....
David
Level 2:
New Friend:
  • Expert 51 Answers
  • Posted on Feb 01, 2018
David
Expert
Level 2:
New Friend:
Answers
51
Questions
0
Helped
10438
Points
125
EBay is your best bet. Here is a quick listing I fould. Just search for your camera model and add "replacement screen". Most of these will ship directly from china.
New LCD Display Screen For Panasonic Lumix DMC TZ35 DMC ZS25 Camera Repair...
5 Related Answers
Anonymous
  • Posted on Feb 24, 2009
SOURCE: Cracked Screen for a Panasonic DMC-TZ4
I know this is a late response but I recently ran into the same problem and I bought a replacement display off of ebay. I purchased the display through D&H Cameras. It was around $55.00.
Anonymous
  • 98 Answers
  • Posted on Apr 30, 2009
SOURCE: My Panasonic DMC-Tz5 has cracked LCD screen. What is the least expensive way to get it repaired?
hi,
send an email to Rotronica in the Netherlands they can provide you an LCD screen cost around 60 or 70 Euro
Anonymous
  • Posted on Oct 12, 2009
SOURCE: Panasonic Lumix DMC-FX12 upsidedown screen
The issue is due to the data cable getting damaged due to the way of packing it inside the camera casing. The signal carrying traces on the edge of the felxible cable is getting damaged. Once the camera is opened and the cable is repositioned properly/replaced will solve this issue.
Rajeev Bose
Anonymous
  • 43 Answers
  • Posted on Nov 09, 2009
SOURCE: How do I replace the LCD screen on a Panasonic
find yourself a service manual, and normally there will be a section step by step how to replace.
Anonymous
  • 436 Answers
  • Posted on Jan 01, 2010
SOURCE: Got a Lumix DMC FS4. LCD screen has been broken
No it cannot be fixed by you because it has to be done with at most care.Only a skilled technician can do it.Please contact your nearest service center for a genuine accessory.
Panasonic LUMIX DMC-FH4 is showing system eror focus. How solve it ?
Can you tell exactly what is on the screen please. The system error focus is not supposed to be an real error that is displayed on your camera.
"System error" is possible. But if switching of and a few moments later switching on does not change the error on the dis[lay, you should contact a Panasonic certified repair centre.
Where do I load 2 batteries in the digipower rapid charger
Panasonic DMW-BCG10, DMW-BCG10E, DMW-BCG10PP Battery, Technical Specification: Battery Type: Li-ion, Voltage: 3.60V, Capacity: 895mAh. Dimension: 41.60 x 30.40 x 9.40 mm, Product Type: Replacement Battery (Brand New). Compatible with: Panasonic Lumix DMC-TZ10 Series, Panasonic Lumix DMC-TZ18 Series, Panasonic Lumix DMC-TZ20 Series, Panasonic Lumix DMC-ZR1 Series, Panasonic Lumix DMC-ZR3 Series, Panasonic Lumix DMC-ZS1 Series , Panasonic Lumix DMC-ZS10 Series, Panasonic Lumix DMC-ZS3 Series, Panasonic Lumix DMC-ZS8 Series, Panasonic Lumix DMC-ZX1 Series, Panasonic Lumix DMC-ZX3 Series. Panasonic Lumix DMC-TZ22, Panasonic Lumix DMC-TZ6, DMC-TZ8 and Panasonic Lumix DMC-ZS5, DMC-ZS7.
Panasonic DMW-BCG10 Battery
I dropped my Lumix DSC ZS3 and now there are
november 23 2010
i dropped my panasonic dmc-zs3 and now there are vertical lines on the view finder. also, these lines appear after taking a photo or video.
can this be repaired?
cost?
thank you in advance ;-(
2answers
Broken screen on panasonic lumix dmc-fx9. Is it
It is not worth fixing it because it will cost you alot . The cost of repairing screen will be around $70-100.
4helpful
2answers
I just need a user's manual for a Panasonic Lumix DMC-ZS3.
Go here:
http://www.dphotojournal.com/panasonic-lumix-dmc-tz7-zs3-review-samples-user-manual/
And click on the "manual" tab.
In reality, this is trivial to find, if you just type into google:
Panasonic DMC-ZS3 Manual PDF
It pops almost to the top. Probably would have been less effort than putting the question up here ;)
Hello pronlem with a panasonic lumix dmc-fx7 battery
help,i have solution panasonic lumix dmc-fx7 lcd blank water damage
Top Panasonic Cameras Experts
ZJ Limited
ZJ Limited
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
