SOURCE: HAZARD LIGHTS ON BUT NOT
HI,
I have the same problem - it is the relay switch attached to and behind the hazard warning triangle on the dashboard. Pull it all out (gently and replace (£60 ish). The indicators and hazard lights are on the same relay circuit. This is a well known problem for this car (amongst others - how about the wipers sticking)
SOURCE: Cam Belt on Outlander 2.4 litre Petrol - 2004
The vehicle has a belt and should be changed every 60,000 miles.
SOURCE: Vauxhall/Opel frontera indicators not working
thats a relay thats is not working propperly, must be replaced to fix the problem, just go to your dealiship and ask for a turn indicator relay for your model and ask your part sales man to show you where is located, if not...just follow that click...
have fun
SOURCE: renault kangoo indicators and hazard lights have
Most common cause is a failed indicator relay. Just swap it with a known good one to confirm whether it's faulty but ensure it's correctly rated for your Kangoo.
After that, the next most common causes are more expensive: the indicator switch and the hazard light switch.
