Question about kawasaki PVS-10921 Portable DVD Player
Alba portable DVD player keeps restarting disc
Hi  I have a portable Alba DVD player DVDP722, bought 8 months ago.  It worked fine for a while but now, everytime we put a disc in it starts over and over again.  I lost the receipt when I moved house and the manufacturer and supplier won't help.  Any ideas please?
thanks
5 Related Answers
Anonymous
SOURCE: invalid disc
we also used my husbands converter (little black and decker he has for the "office" in his truck) and we had no problems the last time we used ours
Posted on Dec 29, 2007
Templarius
Davor Krstevski
  • 86 Answers
SOURCE: Not recognizing disc
Thry to clean laser lens DO that very carefull
Posted on May 26, 2008
ginko
Ginko
  • 19396 Answers
SOURCE: PORTABLE DVD PLAYER NOT SPINNING DISCS AND SAYING NO DISC
When it is region lock it will say it on the display, if the player is not reading any disk, it is more likely a lens problem, see below:
Try first using a lens cleaner disk, like the ones here.
If that does not work, the unit must be disassembled, and lense cleaned with q tips and isopropyl alcohol or cleaning solution. See below:
How to Clean the Laser Pickup Lens on your DVD Player
How to safely clean a DVD lens?
Clean DVD lens, or replace player?
Clean CD or DVD ROM lens with a brush?
Cleaning your DVD drive
How to clean a DVD player
How do I clean my DVD player optical lens isoproponol alcohol
Posted on Feb 10, 2009
Anonymous
  • 563 Answers
SOURCE: No valid disc message displayed. Disc is spinning.
When a DVD player starts doing that, it either needs to be cleaned, or something is going wrong with the DVD mechanism inside of it. You can purchase DVD lens cleaner from any large retail store that has an electronics section. However, if you clean it and the problem persists, it will likely be cheaper to replace the unit rather than trying to have it repaired unless you're under warranty in which case any repair or exchange will be covered by said warranty. If you call the manufacturer they will give you your full range of options.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please post a comment if you need additional assistance so that I can help you further.
Posted on Aug 04, 2009
Grubhead
Grubhead
  • 5700 Answers
SOURCE: my alba dvdp722 will not reconise any disc
Clean the lens with a brand name Lens cleaner for DVD.
Posted on Mar 01, 2010
Hi, I have an Alba DVDP722, it only turns on when plugged into mains charger, can you help with this as it is no longer portable.
The rechargeable battery probably needs to be replaced, but the charger needs to be checked, that it is putting out a charge.
Apr 22, 2012 | Televison & Video
My alba dvdp722 will not reconise any disc
Feb 28, 2010 | Televison & Video
Dvd player keeps saying no disc when I try to play a dvd.what can i do? worked fine until about 3 months ago. started to say no disc when disc inserted but after opening and closing 3 to 6 times it would...
dvd player keeps saying no disc when I try to play a dvd.what can i do? worked fine until about 3 months ago. started to say no disc when disc inserted but after opening and closing 3 to 6 times it would read.now it just wont read. any ideas?
Oct 12, 2009 | Cyberhome CH-DVD 300 DVD Player
Alba dvdp722 does not play dvd any more but will play cds.
the dvd player lens has developed a fault.
jon
Aug 05, 2009 | Televison & Video
Feb 10, 2009 | Televison & Video
Do not read the movies
dvds and cd's have new format out now for anti piracy you have to go out and buy new dvd drive 8 months ago bought a dvd player not just a month ago found out they changed the formats on dvd's and cd's this cant be changed or modified
Jul 07, 2008 | Cyberhome CH-LDV 700B Portable DVD Player
Suddenly quit working
Looks like the lens of the player is dirty or damaged. Try a lens cleaner CD first.
http://www.buy.com/prod/maxell-cd-340-cd-lens-cleaner-lens-cleaner/q/loc/111/90049765.html
If it doesn't work then you will have to get the lens replaced. Since the Player is still under warranty use while you still can..
Jun 17, 2008 | Mintek MDP-1770 Portable DVD Player
Problem with portable dvd player
i would return the item to your retailer as it should hold a 12 month warranty, as if it cannot read cds or dvd, the lens is faulty, and trying to repair it yourself will void your warranty. Please dont forget your ratings are important, thank you
Jun 05, 2007 | Dynex DX-DVDR100 (DXDVDR100) Internal DVD...
have you tried useing a cd/dvd cleaner disc sounds like the laser is dirty
Apr 19, 2007 | kawasaki PVS-10921 Portable DVD Player
kawasaki PVS-10921 Portable DVD Player Logo
96 people viewed this question
Top kawasaki Televison & Video Experts
Ekse
ray gallant
Are you a kawasaki Televison and Video Expert? Answer questions, earn points and help others
