Question about E-Machines eMachines Desktop PC
Reseting the BIOS on eMachines 270
My PC recently under went a change of Operating System (Windows Vista to Windows XP). All seemed to work well for about 20 mins until it came to restarting my PC, it shut down correctly, and seemed to start ok, but
the startup (when i press the power button);
black screen with some info about the graphics card and some versions.
Then an eMachines logo splash image pops up (Being eMachines this is normal) but then this apears: "Error : The system fan has failed, have system serviced immediately. System will power down in 5 seconds"
I know for a fact that there is a setting in bios that should disable the system fan detection, and that by defualt, the system fan detection should be disabled. I think it has somehow been re-enabled and since the system fan is not controlled by the system, the BIOS checks it as failed,
Where can i find the BIOS reset on my motherboard to make sure that these settings are as they should be? The motherboard is the original board that came with the machine from the store but i cant find any info on it, much less where the BIOS reset is.
Can anyone help me here?
Posted by Serris on
  • Serris Oct 18, 2007
    The problem has already been rectified, thanks anyway
Anonymous
    New Friend:
I have installed a usb wireless adapter to my emachine 270 pc but it isnt picking up any networks?
Posted on Feb 05, 2011
Anonymous
  • 42 Answers
Brand and type of ur mobo, in moust of the time a restore to factory defaults is the solution, or go to hardware monitor and disable the fan speed  sensor, or check on the mobo that the cpu fan conector is in the right place, if this will not fix le't me to know
Posted on Oct 18, 2007
Forgot password emachine
Reset My eMachine password
EMachines is a brand of entry level, affordable computers now owned by Acer.
The computers come with the Windows operating system.
To keep your computer secure, it is a smart idea to continually reset and change your password. Changing the password will take only a moment.
Log in to your user account.
Press "Ctrl" plus "Alt" plus "Delete" simultaneously.
Click "Change Password" from the list of options.
Enter your old password.
Enter your new password twice to confirm.
Press "Enter" to save the changes.
Reset An eMachine
eMachines manufacturers a series of netbooks, desktops and laptop computers.
Certain applications and circumstances will require you to reset your computer.
Resetting your eMachine computer is a quick process that can be used to fix problems, complete program installations and access the BIOS or other Windows tools, such as Safe Mode.
Click "Start" in the Windows taskbar.
Click "Shut Down."
Click "Restart."
Normal Restart for Windows Vista/7
Click the "Start" orb in the Windows taskbar.
Click the arrow next to "Shut Down."
Click "Restart."
Change your Windows password
http://windows.microsoft.com/en-US/windows-vista/Change-your-Windows-password
May 15, 2013 | E-Machines eMachines Desktop PC
Maxtor slave
Reset An eMachine
Click "Shut Down."
Click "Restart."
Click "Restart."
May 05, 2013 | E-Machines eMachines Desktop PC
Where do i change my emachine password at?
EMachines is a brand of entry-level, affordable computers now owned by Acer.
Reset An eMachine
Click "Shut Down."
Click "Restart."
Click "Restart."
or
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
Windows Advanced Options Menu
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice
select safe mode with command prompt
Click start run type cmd press Enter
black screen should open DOS mode
this will vary depending on your operating system
type in net user username
For eg. If you want to change administrator password , type net user Administrator
It will prompt you to enter the new password.
Enter the new password and the password is changed
http://wiki.ljackson.us/Control_Userpasswords2
if this fails you will need to
Select safe mode with networking to download
you could download all of these or just one save them to a usb drive for later use if one fails to remove the password
Windows Password Recovery Basic
http://majorgeeks.com/CmosPwd_d239.html
A CMOS BIOS password recovery tool
Editors note: This tool should only be used by experienced computer users.
Please see the enclosed read me if you would like to run it from Windows.
Failure to follow instructions (from Windows) will cause your anti-virus to flag this as a virus.
May 05, 2013 | Computers & Internet
Boot sequence for emachine M6811
As SOON as you press the Power On button, start tapping on the DELete key.
Tap in 2 second intervals.
You may hear beeps. This is a Stuck Key Error Beep. (Or beeps)
Ignore the beeps.
You will now be in the BIOS Setup utility.
The BIOS program is made by Phoenix.
It is Version NSF03.P0
Release date - 07/28/2004
http://www.notebookreview.com/default.asp?newsID=2170#specs
Scroll the page down a little, until you come to the bold heading -
EMachines Desktop Replacement Notebook Specs
Scroll down until you see the sub-heading - Detailed specs
Left-click on - Click here to See appendix for detailed specs
Now look under the bold heading - DMI, and [ BIOS ]
When you are in the BIOS Setup utility, you CANNOT use your mouse
anymore. You have to use your Keyboard.
At the top of the BIOS Setup utility you will see headings;
Main, Advanced, Security, Power, Boot, and Exit.
The BIOS Setup utility automatically opens to the Main screen.
Use the Right Arrow key, and stop on the - Boot - tab
What is listed is a Boot Order.
In the list of the Boot Order are Boot Devices.
What is at the TOP is the first boot device the laptop will boot from.
Should be;
1) CD-ROM Drive
2) Removable Devices
3) Hard Drive
4) Network
Having CD-ROM Drive at the top allows you to install a different Operating System, that the laptop did not have from the factory.
ALSO; Windows DOES NOT like to be written over, with a lesser operating system, or the SAME version of operating system.
Examples;
Trying to install Windows 98SE, on a Windows computer that has Windows XP on it.
Trying to install Windows XP, on a Windows computer that has Windows XP already on it.
Using CD-ROM Drive as the first boot device, will allow you to install what you wish.
[ Doesn't work for installing Windows XP over Windows Vista. There is a special procedure ]
If I haven't answered your question, or you have additional questions, please post in a Comment.
Regards,
joecoolvette
May 04, 2012 | eMachines M6811 Notebook
My emachine wont boot up its resets while trying to boot windows i tryed reinstalling windows with the back up disk but it keeps reseting..its a t5248 model with windows vista.. any ideas??
Go into bios and set it to boot first to the hdd - also set it to default in the bios - and - make sure the TIME is set correctly - sometimes the time get's out of wack and windows will not work right over two hours out of right times
Apr 01, 2010 | E-Machines eMachines Desktop PC
How to downgrade from windows 7 to xp on emachine laptop
If it is a new emachine, then it proberly will not let you. There is a problem with drivers. certain pieces of the hardware might no have any drivers that are supported by XP.. The best thing you can do is check the emachine website to see if any drivers XP. If so then follow this basic guide to format and re-install XP on your PC.
http://simontodd.com/2010/02/how-to-format-a-pc-and-reinstall-windows/
Thanks
Mar 01, 2010 | E-Machines eMachines Desktop PC
Recently I switched from an XP operating system to a Vista. My new PC is an emachine. I am having trouble installing on new emachine. Perhaps the new connections are slightly different? I emachines didn't...
I have just bee to Driverguide and the Vista driver is not there. I have requested it for information purposes, but you should request it yourself, to be sure. If it turns up, I will check to see you have it. Ian.
Sep 18, 2009 | Office Equipment & Supplies
Changing operating system from windows vista to windows xp; how to install a bluetooth device
You can change your OS from Vista to XP by try to follow the ff. steps:
1. turn on your computer then press Delete key to enter in BIOS Setup as to set your system 1st boot to CD thru the BIOS advance feature or you may press F8 key to select the CD 1st boot device. then F10 to save changes in your BIOS setup.
2. then, insert you CD with XP operating system in your computer CD/DVD device & just read / follow the next steps that will appear on Screen.
Hope this would help. Best regards.
Apr 22, 2009 | Computers & Internet
Remove vista
insert xp disk restart computer while restarting pressF8 & on the appeared menu select cd /dvd rom and press enter now xp will setup in ur computer
Nov 28, 2008 | Computers & Internet
Only getting EMachines/Windows XP Logo when boot up T3882
you have not set the cdrom as first boot device in the bios (press F2 or Del on boot up to get in bios), choose cd as first boot device, save settings and restart the pc with your cd in the drive and then when prompted press enter
Aug 18, 2008 | E-Machines eMachines Desktop PC
E-Machines eMachines Desktop PC Logo
414 people viewed this question
Top E-Machines Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Michael Thomas
Michael Thomas
efs_perpends
efs_perpends
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
