Question about Canon DC210 DVD Camcorder
Can't read a DVD-R that was produced by Canon DC210 DVD Camcorder
I have recorded something on a DVD-R using the Canon DC210 DVD, then I take the DVD-R disk and try to read from a computer DVD ROM that reads DVD-R and the disk comes up empty I don't know what to do to read the disk from a computer any help is very welcome
  • 8 more comments
  • alinc Dec 18, 2007
    Cannot finalize DVD-R. XP thinks disc is audio. Do I need additional software?
  • DairyGoats Apr 22, 2008
    I have done the same thing. I recorded with a Canon DC210 on a DVD-R and I finalized the disc. I tried putting it my computer who reads DVD's but it does not read the disc. I want to edit and clip this video can it be done? Do I need a driver for Canon DC210 before my computer will let me see it?
  • italianmom May 03, 2008
    Does anyone know a specific program/driver that can be bought for this?
  • Sickskate Jun 12, 2008
    My video clips are not working with ny video software i have on my computer! does anyone know of a package that can be used with this camera?
  • vijaymaray Jul 01, 2008
    i am also having same problem with canon dc 210 camcoder
  • Anonymous Jul 05, 2008
    yes i have the same problem.
    [email protected]
  • Anonymous Jul 30, 2008
    tes yried to connct cam to pc by wire
  • omar mohammad Nov 03, 2008
    i can not see my record on my computer
  • Anonymous Nov 30, 2008
    same issue
  • Anonymous Mar 08, 2009
    I have the same problem, the mini disk won't read in the computer or in the DVD player
Canon DC210...To finalize the disk, you first probably want to have the AC adapter plugged in even if your camera does not require it in order to access the finalize menu option, as the process can be quite lengthy and use battery power -wouldn't want to run out in the middle of the operation....THEN....Make sure you are in VIEW mode -not record mode...THEN...Press the FUNC button on the side of the camera -you should then notice the FINALIZE option -among others -navigate to the actual finalize command using the joystick, then press it down and let it work its magic - try not to move it until it is finished. After it is finished -it can be removed and will be recognized by a dvd player, recorder or drive that is compatible with this type of disk in the first place, Apparently, this camcorder records video to the .VRO file type -so be sure any video editor/converter/player software on your computer recognizes this file type.
Posted on Dec 20, 2007
  • 3 Answers
Have you finalized your disk? It does need to be finalized first. If you have, you can use Windows Media and you should be able to view it and even burn it, but am trying to solve the problem of burning it so that it can be played on a DVD/VCR player.
Good luck
Posted on Oct 24, 2007
Premiere Elements will import your video ok and let you edit from the Canon format
Posted on Sep 03, 2008
    New Friend:
The Canon DC 210 cannot read any disks (even those already recorded). The camera is plugged in to the outlet. Tried new and previously used disks to no avail.
Any ideas would be greatly appreciated!
Posted on Apr 07, 2010
I found this link, should help if you have Toast.
http://www.macosxhints.com/article.php?story=20061124153410554
Last night I was presented with a DVD-RW that had a recording (of a portion of a local television news broadcast) created with a DVD video recorder. I've heard people talk about not being able to play these disks in other devices (such as computers or regular DVD players). I slapped it into my MacBook Pro and, when it mounted almost immediately on my Desktop, I thought I was home free. Not so much.
The mounted volume contained one folder that appeared to be locked (it had the "locked" badge on it). I could open it in the Finder, but it appeared to contain no files. I launched Terminal and cd'ed into the folder. When I tried to ls, I was told I had insuffiecient privileges. A quick sudo (via !!) later I was greeted with two files: VR_MOVIE.INF and VR_MOVIE.VRO. The first of these was something like 16KB, while the other was just over 1GB. Bingo. But no. All attempts to copy the .VRO file were in vain.
I tried VLC, Handbrake, Mac the Ripper, DVD Player, Disk Utility, iSquint, and maybe a couple other things ... all to no avail.
I finally decided to try Toast and just burn a copy of the thing for later. Toast recognized the DVD, but informed me that I was not allowed to copy it. Toast also displayed a hint that I could add the titles via the Video -> Media tab. Sure enough, there is a pop-up menu in the media drawer that allows you to specify DVD. When I switched to that, I was presented with a list of chapters. I was able to grab the chapter I wanted and rip it directly to a Toast DVD image. Once the resulting image was mounted, it contained the standard VIDEO_TS folder and played normally in QuickTime Player. I was then able to transcode the chapter with HandBrake.
So there you have it. If you want to get video data off a DVD recorded in a DVD video recorder, Toast is the way to go.
Posted on Mar 29, 2009
Plugging the ac adapter does the trick! thanks!
Posted on Sep 22, 2008
Use Ulead VideoStudio 11 to import clip save copy
you can use the sowftwear only to import your clips without editing
Posted on Sep 21, 2008
Plug in the power cord then press the function key and finalize the disc and then you computer will be able to read the disc. I was making the same mistake and plug it in and the Finalize step will be allowed.
Posted on Jul 06, 2008
6ya staff
SOURCE:
My camcorder will not give me an option in disc operations to finalise a disc which I recorded on (which I did initialise before starting- I have also tried it on another disc, initialise, record etc) I...
Are you using the AC adapter when trying to finalize? You cannot finalize using battery power only.
Link to your manual:
Canon DC210 Manual
(What format discs are you using?)
Instructions for finalizing begin on page 61.
Hope this helps.
Thanks for using Fixya.
Mar 11, 2011 | Canon DC210 DVD Camcorder
Is there any way to finalize a mini dvd disc from a Canon DC210 without a working camcorder?
hi, i dont think so usely it as to be made by the camera,normally when you finish recording
you press pause and then stop and let it go for few minutes and the camera should finilize
the disk by chapter,then eject.
hope that will help
regards Alan
Jan 04, 2011 | Canon DC210 DVD Camcorder
Initialize the discs then record...but then it still wont play on the computer/dvd player Canon camcorder dc210
I have a Samsung recorder, and it requires you to "finalize" the disc before it will play on another unit. Check your manual for specifics, or look in your menu for the "finalize disk" option. Hope this helps...
Mar 14, 2010 | Canon DC210 DVD Camcorder
CANON DC210 CAMCORDER DRIVER CD LOST
I HAVE LOST MY INSTALLATION DISK FOR MY CANON DVD CAMCORDER DC210...CAN U HELP ME IN FINDING AND INSTALLING THE SOFTWARE FOR THIS CAMCORDER SO THAT I CAN SEE MY RECORDINGS ON MY COMPUTER
May 04, 2008 | Canon DC210 DVD Camcorder
Hey, I owned this camera since... Christmas and Ive had the same problem, I decided to look into it and I found something that helped Its called iSofter VOB Converter, and I just have the demo, and it seems to be working fine, Mind you I just got the program like 2 minutes ago... but I used Sony Vegas 8 to rip em at first, but you still couldnt edit them, but iSofter works on Windows Movie Maker, and probably other programs too... Hope this helped
May 04, 2008 | Video Cameras
Canon DC210 mini DVD Video Camcorder operation
Usually it asks you which mode u perfer to format in but possibly you might have bought the wrong kind of dvd's.This particular model only recognizes "minus" and not "plus" dvd's.
Apr 26, 2008 | Canon DC210 DVD Camcorder
Canon DC210 camcorder
The DC210 will only work with with Mini DVD -R or -RW. I had the same problem when the BestBuy salesman sold me +RW Mini DVD with the DC210. I went back to the store and got them changed for +RW and I was then able to use the DC210.
Jan 09, 2008 | Canon DC210 DVD Camcorder
Pauses during playback on home dvd player
Im using Verbatim discs and they work fine... try those
Jan 05, 2008 | Canon DC210 DVD Camcorder
Record on DC210 and playback on home DVD
You should absolutely be able to play the recorded DVDs from your camcorder in your DVD player, as long as you remember to finalize the disc and the disc is compatible with the player. If your DVD player is less than five years old or so, you should be fine, provided you're not using dual-layer discs.
Dec 02, 2007 | Canon DC210 DVD Camcorder
Canon DC210 DVD Camcorder Logo
2,072 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
