Question about Airtemp B6D30E7A Air Conditioner
Fan does not work
I replaced the fan motor after original fan developed a sqeal (worn bearing). It was recommended I replace the capacitor so I did this as well. After replacement fan and a.c. ran fine for 30 minutes and then fan stopped. I ran wires to old fan and this will not run either. I went back to old capacitor but the fan will still not run. I have checked and rechecked wiring and connections but all is in order there. I have tried to cycle the fan through all three speeds (high, med., low) without results. Any thoughts?
    Scholar:
  • 72 Answers
Check resistance through the fuse and the actual control switch and see if it's registering anything. Usually wiring doesn't go bad unless it gets a nick in it or is overloaded and burns out. If it all looks good then check to see if you're getting voltage to the fan motor when turned on. Be sure not to let leads or live wires go to ground or touch you, it can hurt you or your wallet worse. That should be a good start, tell me if it works out.
Posted on Jan 28, 2008
6ya staff
SOURCE:
I have a Bryant AC when it gets hot the fan stops, when it cools down the fan starts back again.
The fan motor is going bad... replace the motor...
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
Jul 12, 2011 | Bryant Heating & Cooling
Kenmore 12000 btu turns on fine but after a few minutes fans shut off and compressor keeps running this is a heat and air model
First replace fan capacitor and try, if not, bearings worn out in your fan motor. Replace bearings or motor with new capacitor.
Jan 14, 2011 | Kenmore 76081 Wall/Window Air Conditioner
After about 5 minutes the unit stops working. No sound or even a fan noise. I just cleaned the filter to see if that helps, but it didn't.
Is the fan running and stopping before the unit completely quits?
If the fan quits the compressor won't run very long.
I would start with the fan motor or capacitor.
Shut the power off to the unit, spin the blower wheel to see if it spins freely. If it doesn't spin freely, (there appears to be a little drag when you spin it),the bearings are bad, if it does spin freely, then try moving the motor shaft from side to side if there’s any play in the shaft side to side then the bearings are worn and motor needs replaced. Then, check the capacitor, if it’s bulging even slightly, the capacitor is bad and needs replaced. Most of the time people replace the capacitor if motor seems ok. If capacitor is ok, turn power on to see if the motor is getting the proper voltage, if it is and not trying to run, then the windings are probably open, the motor's bad and needs replaced.
r.
Aug 21, 2009 | Dehumidifiers
Two units, one works fine the other unit fan does not come on.
Shut the power off to the unit, spin the fan blade to see if it spins freely. If it doesn't spin freely, (there appears to be a little drag when you spin it),the bearings are bad, if it does spin freely, then try moving the motor shaft from side to side if there’s any play in the shaft side to side then the bearings are worn and motor needs replaced. Then, check the capacitor, if it’s bulging even slightly, the capacitor is bad and needs replaced. Most of the time people replace the capacitor if motor seems ok. If capacitor is ok, turn power on to see if the motor is getting the proper voltage, if it is and not trying to run, then the windings are probably open, the motor's bad and needs replaced.
Aug 16, 2009 | Heating & Cooling
Duo Therm kicking on the compressor, getting cold, but no fan!
Aug 12, 2009 | Dometic Rooftop RV Air Conditioner
Fan does not operate in my 54501 Kenmore dehumidifier; therefore, unit gets very hot.
Aug 11, 2009 | Kenmore 54501 Dehumidifier
She was a little noisy with the fan sounding like it was rubbing, today i found no working at all but it was real hot. I opened the back and the fan spins freely and there is a canister that looks like a...
The capacitor should not be hot, so the motor could be drawing high amps do to a worn bearing which could cause the rubbing sound.
With the power off try to move the motor shaft from side to side, it shouldn't move any that way, if it does the bearings are worn and you need to replace the motor and the capacitor. The other cause for the hot capacitor would be a bad capacitor.
If the motor is bad you should also replace the capacitor at the same time.
Aug 05, 2009 | LG LD40E Dehumidifier
The fan seem to have quit working and the unit got loud. i oiled the fan but it doenst turn on but the compressor comes on but overheats quickly.
Jul 31, 2009 | Dehumidifiers
Fan not working
Jul 31, 2009 | Fedders A7DH65B2A Dehumidifier
A/C not working, outside fan not turning without assistance
is fan spinning fast enough it has to have alot of velocity to cool condensor coils if you haft to push fan to get going its probably shot and get new motor the ac is a sealed system and hardly ever will leak freon!!!Best of Luck to You!!! :)
Jul 02, 2009 | Bryant 462AJC021BA Air Conditioner
Airtemp B6D30E7A Air Conditioner Logo
57 people viewed this question
Top Airtemp Heating & Cooling Experts
Mike
Joseph Hoffmann
Todd B
Are you an Airtemp Heating and Cooling Expert? Answer questions, earn points and help others
