Question about Microsoft Windows Xp Home Edition Sp2 English Mlp Na Only Additional License (n0901086) for PC
Booting problem I hv windows xp wid 128 mb of ram.the problem is that whenever I insert any cd in the rom,the system reboots automatically.plz suggest a solution.
Anonymous
    Problem Solver:
  • 19 Answers
That reboot error has to do with the power supply. Inserting a cd requires power which your power supply cannot give and the pc restarts.
Posted on Mar 09, 2008
Anonymous
    Problem Solver:
  • 7 Answers
First increase the RAM as win xp needs min of 128MB of ram. So do that first then even it happens plz check the ram. If it continues plz format the system and re-install the OS
Posted on Oct 18, 2007
Anonymous
    Scholar:
  • 51 Answers
RIGHT Click...
My Computer
From the menu choose Properties
Click the Advanced tab
Click Startup and Recovery
Under the system failure area take the check OUT of the box that says Automatically Restart.
Windows XP sucks on 128MB, get yourself more memory, go to 1 Gig.
Your problem could also be hardware such as a power supply so re-comment if the suggestion did not work for you.
**Please add a comment before giving a rating other than Solved
  • Anonymous Oct 18, 2007
    Reinstalling the os in my opinion is not necessary. It's alot of work and sometimes impossible for the average user to do properly. That solution is way too overused and general.
    This problem, like many requires the user to come back here and provide more details and to try a few things. It could be a software problem or any number of hardware issues, some trial and error and back and forth is necessary to solve this.
How to reboot a XP4 computer
1 first insert the windows cd in cd/dvd rom 2 chek in the bios if the first boot device is the cd/dvd rom 3 vhen it boots it will say press any key to boot from cd 4 after loading all the data you must format drive C 5 after formating it will restart instaling windows you must insert the windows cd key thats all
May 16, 2011 | Microsoft Windows XP Professional
Need saystem requirements
System Requirements:
  • Windows 98/2000/Me/XP
  • Pentium 200 processor (Pentium II 300 or greater for Windows XP)
  • 64 MB RAM (128 MB RAM for Windows XP)
  • 800x600 display (16-bit high-color)
  • Minimum 720 MB hard drive space
  • 4X CD-ROM drive or faster
  • Windows compatible soundcard and speakers
Jan 26, 2011 | The Learning Company PrintMaster Platinum...
Installing the jumpstart advanced 1stgrade cd rom that has 4 cds to it and I can't get it to install.
Jumpstart advanced 1stgrade cd rom installation.
System Requirements
Windows: 98/ME/2000/XP; Pentium II 266MHz (Pentium II 300MHz or faster for XP); 64 MB RAM (128 MB RAM for XP); 100 MB HD; 12x CD-ROM drive; 16-Bit color; Windows compatible sound card
If you are installing on a newer OS ie Vista, or Win 7, due to software incompatibility the software might not install, or even you can install the software might no work.
You can try using the "compatibility mode" in Vista or Win 7 to install the programs as "administrator" but no guarante this will work.
Alternatively, you can get a newer version which is compatible to your Operating System.
Hope it helps.
Jul 25, 2010 | Jump Start JUMPSTART ADVANCED 1ST GRADE...
Pentium III 500 mhz will support windows XP
Here is Windows Xp requirements:
PC with 300 megahertz or higher processor clock speed recommended; 233 MHz minimum required (single or dual processor system);* Intel Pentium/Celeron family, or AMD K6/Athlon/Duron family, or compatible processor recommended
128 megabytes (MB) of RAM or higher recommended (64 MB minimum supported; may limit performance and some features)
1.5 gigabytes (GB) of available hard disk space*
Super VGA (800 x 600) or higher-resolution video adapter and monitor
CD-ROM or DVD drive
Keyboard and Microsoft Mouse or compatible pointing device
Jul 28, 2009 | Intel Pentium III Xeon , 500Mhz...
Computer hangs during xp installation
make sure you have met the minimum hardware requierments when installing your XP...which is
• PC with 300 megahertz or higher processor clock speed recommended; 233 MHz minimum required (single or dual processor system);* Intel Pentium/Celeron family, or AMD K6/Athlon/Duron family, or compatible processor recommended
• 128 megabytes (MB) of RAM or higher recommended (64 MB minimum supported; may limit performance and some features)
• 1.5 gigabytes (GB) of available hard disk space*
• Super VGA (800 x 600) or higher-resolution video adapter and monitor
• CD-ROM or DVD drive
• Keyboard and Microsoft Mouse or compatible pointing device
Apr 11, 2009 | Microsoft Windows XP Professional for PC
First bootable device
ok first u have press the delete or F2 and go to the BIOS setting and sellect the first bootable device CD rom after save and exit.. after that u insert the cd of win xp. and install the win xp... if any problem cont me...
Apr 07, 2009 | Intel D945GCL Motherboard
Graphics card
Then you probably need a new graphics card.. JTF requires these at a minimum to play:
Minimum System Specifications
  • Windows 2000/XP Home or Professional/x64
  • Intel Pentium 4 2 GHz or AMD Athlon XP 2000+
  • NVIDIA GeForce 4 (non-MX) or ATI Radeon 9500, DirectX 9.0c compliant videocard with 128 MB RAM
  • 512 MB RAM
  • 3 GB of uncompressed hard drive space
  • DirectX 9.0c compatible sound card
  • DirectX 9.0c (included)
  • 4x CD/DVD-ROM drive
  • Microsoft-compatible mouse and keyboard
  • 56 kbit/s dial-up modem for online play; 10 Mbit/s for LAN play
Oct 17, 2008 | Graphics BV200 BizView 128MB (128 MB) PCI...
How do i boot up a compaq presario off of win xp cd?
First insert your cd in the cd/dvd drive and then simply restart the computer and it will boot automatically. If it does not boot automatically then go to boot menu and select cd/dvd to the first in the booting order. It will then boot automatically.
Sep 20, 2008 | Compaq Computers & Internet
Hp desktop with black screen
ARE YOU USING WINDOWS XP...IF THATS THE OS THEN JUST REPAIR THE OS WITH WINDOWS XP CD BECAUSE WHAT LOOKS IS YOUR MBR (MASTER BOOT RECORD) HAS GONE CURRUPT. AFTER REPAIR THE SYSTEM WILL BOOT NORMALLY AND YOU WILL NOT LOSE ANY DATA.
Apr 26, 2008 | Linare Desktop, AMD Sempron 2200,40 GB HDD...
WINDOWS XP
Windows xp can run on any PC that has a 233 mhz processor and 64mb of ram. Here is a list of hardware requirements for windows xp taken from microsofts website : These are the minimum requirements for basic functionality. Actual requirements vary, depending on the system configuration and the programs and features that you choose to install. If you are installing Windows XP over a network, you may need additional available hard-disk space. The minimum hardware requirements for Windows XP Home Edition are: ? Pentium 233-megahertz (MHz) processor or faster (300 MHz is recommended) ? At least 64 megabytes (MB) of RAM (128 MB is recommended) ? At least 1.5 gigabytes (GB) of available space on the hard disk ? CD-ROM or DVD-ROM drive ? Keyboard and a Microsoft Mouse or some other compatible pointing device ? Video adapter and monitor with Super VGA (800 x 600)or higher resolution ? Sound card ? Speakers or headphones The minimum hardware requirements for Windows XP Professional include: ? Pentium 233-megahertz (MHz) processor or faster (300 MHz is recommended) ? At least 64 megabytes (MB) of RAM (128 MB is recommended) ? At least 1.5 gigabytes (GB) of available space on the hard disk ? CD-ROM or DVD-ROM drive ? Keyboard and a Microsoft Mouse or some other compatible pointing device ? Video adapter and monitor with Super VGA (800 x 600) or higher resolution ? Sound card ? Speakers or headphones
Aug 29, 2007 | Computers & Internet
Microsoft Windows Xp Home Edition Sp2 English Mlp Na Only Additional License (n0901086) for PC Logo
60 people viewed this question
Top Microsoft Computers & Internet Experts
Lee Hodgson
Lee Hodgson
efs_perpends
efs_perpends
ThaMp3Doctor
ThaMp3Doctor
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
