Question about iLO (2 GB) MP3 Player
Mp-556 player won't work
'flash error, back up data and format player' shows up on screen and player will not work.  I hooked it up to my computer and formatted it but it still won't work.  How can I fix it?
Posted by frankie334 on
  • ashandsue Nov 11, 2007
    i have the same error on my mp-556. pls help
    took out battery. fomatted/synched
  • Anonymous Jan 21, 2008
    I downloaded another song in it still wont work
ThaMp3Doctor
  • 8,597 Answers
There are two ways to format an Mp3 player - one on the computer itself, and one in Windows Media Player. Both methods will end up erasing all the songs on the player, but the player will be "good as new" after that. Sometimes reformatting in this manner will override the player's native formatting and cause problems - this can be reversed in most cases by updating the player's firmware. Firmware upgrades are available from most manufacturers' websites.
WARNING: The following procedures will erase all songs on the player.
Check if the file system is NTFS. If yes, format it to FAT or FAT32. - Connect player to computer, double-click my computer, right click on icon of mp3 player and select format. This only applies to Windows-based computers.
You can also format the player in Windows Media Player itself:
Connect your Mp3 player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "name of Mp3 player here 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
-Tha Mp3 Doctor
Posted on Jul 05, 2008
ILO MP-556 MP3/WMA player
Revised iLo instructions for Windows Media Player 11:
Connect the iLo to the computer
In Windows Media Player 11, Run the mouse over the Sync tab
Click the little black arrow that appears underneath the Sync tab
Select More Options
Click the Devices Tab
Highlight the iLo
Click Properties
Uncheck box, "Create Folder Hierarchy on Device"
Download the firmware file at: https://system.netsuite.com/core/media/media.nl?id=16076&c=432868&h=b25618a8ea7ead5c9573&_xt=.zip
then proceed with the rest of the directions
-Tha Mp3 Doctor
iLO Mp3 Player
"Flash Error"
1. Connect the player to the PC using the USB cable. 2. Open Windows Media Player. 3. Go to the Sync or Devices tab and delete all content from the player. 4. Go to the Tools menu and select Options. 5. Select the Devices tab, highlight the ILO or Siren player and click on Properties. 6. Uncheck the box "Create Folder Hierarchy on Device" ---- "Firmware Upgrade" (provided by jwmgotee):
I just repaired/reformatted my 1.0 GB Ilo following the instructions below with no problems:
Please connect the player to a rear USB port on the computer. The display should show “USB Connectedâ€
. (If not, please press the power button.) Please make sure that all unused programs and applications are closed. You can close the applications by closing as many of the icons in the lower right hand corner (by the clock) as possible. Download the correct Firmware Click here (https://system.netsuite.com/core/media/media.nl?id=16076&c=432868&h=b25618a8ea7ead5c9573&_xt=.zip) to download the ILO 116 Firmware Click Open to initiate the download Double click on the ILO or Siren folder icon. There will be 14 icons. There will be a Setup icon that looks like a box with a blue line on it; please double click on this. Then click Run - this will open the Install Wizard. The Install Wizard has the instructions on the screen as you go through it. Once the firmware has installed, please click the Start menu, then Programs. Look for the icon that says ILO or Siren, and then double click the Firmware Update to install to the player. Depending on how severe the corruption to the firmware on the player is, you might have to do this step 2 or 3 times in order for it to completely repair the firmware. It will now search for the ilo. This may take a while depending on how corrupted the firmware is, so be patient.
After it has found the ilo, it will say, "A device has been detected in recovery mode and is being initialized. Please wait."
The ilo should come back to life and start showing it's glorious "USB Connected" screen.
The "Firmware Update" window should appear. Select "Format Data Area" to rid the player of corrupted firmware data. And click "Start".
It can take anywhere from 2 to 4 minutes to re-flash the ilo and the program might appear to have locked up, but it hasn't. So don't close the program or disconnect the ilo!
If the program fails to find the ilo and gives you an error like, "Device Timeout" or something similar, you need to reinstall the ilo drivers. This can be done by inserting the ilo cable into a USB port it has never been plugged into before. Or you can reinstall the drivers by reinstalling the Rave-MP program. (Remove it, restart the computer, and then install it again).
Although, plugging it into a new USB port is the fastest and easiest option.
If your player won't even turn on, follow these instructions first and then those above:
First, remove the battery. While this isn't necessary to get the player into recovery mode, it insures the unit will not power on before the cable is inserted.
On the ilo, hold the "Power" button down while inserting the USB cable. Continue holding the power button down for 5 seconds more after the cable is inserted. The backlight on the ilo will remain off during this time, making the screen appear to be blank.
An hourglass should appear on your computer and Windows should say,
"Found new Hardware 'SMTP3500".
Jan 10, 2009 | iLO MP3 Player
Flash error ,back up data and format the player
it keeps saying format the player and back up the dta
Sep 04, 2008 | iLO (2 GB) MP3 Player
Have Question
the memory is corrupt and needs to be formated, plug the player into your computer, right click on the mp3 drive you see in my computer and select format.
Aug 25, 2008 | iLO MP3 Player
Wont show anything but white screen
hello,
try connecting the device to your computer, go to 'start' button, go to 'my computer' right click the 'removable disk' drive, click format, and follow formatting instructions. this will erase all the data on the device, disconnect mp3 player ,reset the device with reset hole on the back of the unit. reset whole actually renews the firmware on it, so it should restore the screen.
Aug 22, 2008 | Coby MP-C7085 MP3 Player
Problem on mp-556
-Tha Mp3 Doctor
Jan 19, 2008 | iLO (2 GB) MP3 Player
Ilo mp3 player model MP-556
connect your mp3 to the computer then right click on the drive click format. after that you mp3 is now good as new.
Jan 18, 2008 | iLO MP3 Player
Ilo mp3 model mp-556
you must insert your mp3 into your usb port then click on My Computer icon, right click on mp3 drive and click format disk, this will resolve this problem.
Nov 29, 2007 | iLO MP3 Player
Ilo mp-556 mp3/wma player
i have a problem when ever i wanted to switch from card to flash it shut self off,i had to take the card out to play other .i have 1G any idea?
Nov 25, 2007 | iLO MP3 Player
MP3 ilo
You should backup your data and format the player. Plug her in, copy your music onto your computer, then format it by right clicking the drive in My Computer, then going to Format, then clicking Start. After it's finished, copy your music back over to the player and it should be sorted.
Sep 07, 2007 | iLO MP3 Player
Problem with songs
http://www.lenoxx.com/2005/mp3player/mp556.htm if you have a ilo model mp-556 (on the back cover) this page has links to the firmware ... i follow the instruction and got mine working. u might need to use the reformat as well as the upgrade firmware to make your list read the same. reformating will set your storage area back to factory specs. i e delete all your songs on your player
Jul 24, 2007 | iLO MP3 Player
iLO (2 GB) MP3 Player Logo
88 people viewed this question
Top iLO Audio Players & Recorders Experts
ThaMp3Doctor
ThaMp3Doctor
Muntejaya Ginting
Muntejaya Ginting
Geoff
Are you an iLO Audio Player and Recorder Expert? Answer questions, earn points and help others
