Show me a ******* electric trailer brake wiring diagram or schematic PLEASE
Trailer Wiring Color Code Connector Function Color Suggested Minimum Wire Gauge Where To Attach - Vehicle Side Where To Attach - Trailer Side 4 Way & 5 Way 6 Way & 7 Way 7 Way 6 Way 5 Way 4 Way Right Turn Green 18 16 Right turn of vehicle's wiring harness Trailer's right turn signal Left Turn Yellow 18 16 Left turn of vehicle's wiring harness Trailer's left turn signal Ground White 16 12 Vehicle ground point - metal, uncoated, rustproof Trailer ground point - metal, uncoated, rustproof Tail / Marker Brown 18 16 Taillight of vehicle's wiring harness Trailer's taillights Brake Blue 18 12 Electric brake control, power for brakes Break away switch Battery Red (or Black) 12 Fuse block or FUSED battery Lead Break away kit, interior lights and battery charger. Back Up Purple 16 Back up circuit of vehicle's wiring harness Back up lights (if available) / Hydraulic coupler. This chart is a typical guide, wire colors may vary based on manufacturers. Use a circuit tester to verify connections.
Not knowing the year or model makes this impossible to answer.
Hi Anonymous, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
Go to manufacturer of brake control.
